Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Engine/Turbo
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 11, 2009, 06:08 PM   #16
Silver Sponsor
Personal Sales Rating: (80)
MitsuJoe's Avatar
Drives: 03 BBY EVO by PPI and 00 Civic SI
Send a message via AIM to MitsuJoe Send a message via MSN to MitsuJoe Send a message via Yahoo to MitsuJoe
Put a long breaker bar into the crank pulley. Make sure it is secure and this should stop it from moving. Also putting the car into gear will help this too as the motor will have to contend with moving the trans and clutch to spin. This should do it for you.
Also if you have not seen in it, this tool works great!
http://www.euroexportinc.com/product...ducts_id=44428
Honestly I would just pull the stuff on the side and redo the timing belt. This will give you the best truth in knowing that your not a tooth off. I have done the zip tie method a few times but it really only adds about an hour to the job and gives you a chance to know it is 100%. This would also be a great time to check your balance belt deflection if your still run those.
Since your not pulling the head then what is a little extra time spent to do things exacting. Best of luck.
Quote:
Originally Posted by nirvevo View Post
i've been searching for a while on the Spring Retainer Seat install. In the How to thread, several guys in the discussion section had the pistons move when applying pressure.
One guy tried leaving it in gear wit the emergency brake on etc.. and still had it move, screwing up his timing.
Is there a sure fire way to use the air compressor method without the the piaton(s) slipping timing?
I'm getting ready to do this with a Kelford cam install and would sure like to know.
Not interested in theories, just experience & proven results. Thanks!
__________________
Paradigm Performance Innovation
http://www.paradigmperformance.net
Michigan's EVO Club @ www.miEVO.net
Offline
Old Oct 31, 2009, 10:19 PM   #17
Personal Sales Rating: (0)
My Garage
DavesGSX's Avatar
Drives: 2006 Evo MR/1999 Eclipse GSX/1992 Eclipse GSX
I bought one of those tools for my 2G. It works like a charm, it only took 35 minutes to do all the springs and retainers with the head off the engine. If your going to do springs and retainers, I suggest getting one. I agree with MitsuJoe about just taking the head off. I would rather be safe than sorry, plus you can just throw on a new Head gasket and timing belt while your in there.
Offline
Old Oct 31, 2009, 10:41 PM   #18
Personal Sales Rating: (12)
Drives: 03 evo ,02 ws6 trans am
Send a message via AIM to 06ravenmr
just re do the timing when installing the cams.... this way u know its good
__________________
03 evo 8
turbo trix 50 trim turbo kit
1mm oversized valves
hks 272/272
aem ems
aem wideband
b&m short throw
soon to be kelford 280's with the new pte 5857..
Offline
Old Nov 3, 2009, 09:27 PM   #19
Personal Sales Rating: (1)
Drives: 03 Evo 8, 97 CBR600F3
Just a question about the Kelford 272's, Can you use stock springs/retainers as long as the RPM's are not kept high??(Under 6,000 RPM)
Getting these cams, but didn't know if I really needed to change other stuff.
__________________
Daily Driver:
187,000 miles and going
SMB 3" Downpipe
Greddy Full Titanium Cat Back
APS HV Dual Vent Blow Off
K&N Typhoon intake
Hallman Manual Boost Control
Brembo Cross drilled w Hawk HPS
HKS Turbo Timer
Carbon MR front brake guides
Walbro 255 Fuel pump
Kelford 272's
AMSoil fluids
Offline
Old Nov 9, 2009, 01:35 AM   #20
i did mine just to be safe cause its rele not that much more expensive
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
