Jul 26, 2009, 03:55 PM
Personal Sales Rating: ( 2)
2003 Mitsubishi Lancer Evolution
Drives: 03 Evo8
Adj Cams?
I running Adj Cams set at 0 right now. I am thinking about trying to squeeze alittle more power out of my current setup. What would be some advantages/ dis-advantages of adjusting of adjusting the cams?
Im goin to put the Int -2 / Ext 0 just to see how it does. Just alittle testing and tuning. I know Dyno would be best but we only have 1 AWDyno and its expensive. I also hear evos like to run +2/+2? any info to verify this?
any input would be nice.
__________________
Quest for 700hp!! Buschur UICP,4" Intake, RNR GT35R, 3" Exhaust, HKS272/272, Skunk 2 Cam Gears, RC 1000cc inj, 255fp, AMS FPR, JMF Intake Manifold, SuperTech 1mm Valves, BC Valve Springs/Retainers, ETS FMIC, Full Race Head,
Comming soon.. ETS 3.5" Exhaust, Built 2.0
Offline
Jul 26, 2009, 05:10 PM
Personal Sales Rating: ( 0)
Drives: Evo VIII US-Spec '05
Adjusting camgears often gives you more tq, and hp too but mostly for the wideness of the powerband. There is just no excuse for not doing it - especially fi you're going for the big numbers
__________________
____________________________________
Dedicated Evo VIII Driver
Now in an '05 US-Spec GSR (My 2nd Evo 8)
Power mods: Blitz drop-in, 10.5 hotside w/MeganRacing O2housing, TME-Cams(some timing adjusted),
Mongoose 3" TBE w/high flow cat, Walbro 255l/h, HKS M40G Spark plugs, APS Twin Vent BOV (2 hold boost), EcuTek tune
Weight reduction: No crash beams, exhaust, ETS mini battery kit, 100% clean trunk
Offline
Jul 27, 2009, 12:01 PM
Personal Sales Rating: ( 6)
Drives: 05 EB evo
i dont think I have ever seen cam gears give an output worth the work and money they are. I have just seen them move the powerband to the left or right, but same numbers overall
__________________
AKA: PM-Performance
APAT Tuned
05 EB VIII
345WHP/322TQ on 23PSi on the "HeartBreaker" Mustang Dyno (old numbers)
Offline
Jul 27, 2009, 03:15 PM
Drives: 03 Evo8
ok cool. ill check it out and see how it goes.
__________________
Offline
Aug 1, 2009, 08:51 AM
Personal Sales Rating: ( 1)
Drives: 2006 EVO IXMR
If you want more power I personally would go with a bit more agressive cam, like the S2s or Kelford 272s. On your 35R you will see 30+hp probs. You also have all the supporting mods! Good luck with the ETS3.5" exhaust. Its mean as ****!
__________________
Mikey's 2006 EVO IX MR: ER VIII 5speed, Magnus v5, 3.8" Garrett FMIC, ETS Short Route UICP, TurboSmart RacePort BOV, RC 880cc Injectors, Perrin Fuel Rail, Walbro 255, ARP Head Studs, HKS 272/280, HKS EBC, R/TErnie Ported Exhaust Manifold, R/TErnie Full 3" V-Band External Dump O2 housing, R/TErnie Modified Perrin 3" V-Band Downpipe, Nesei LICP, FP 25psi Wastegate, Apexi N1 Test-Back, AEM Meth kit (M15), Exedy Twin Plate, FP Red+30lbs+ER Tune = 520hp/406tq
http://www.myspace.com/blkcarbonevo
Offline
Aug 1, 2009, 08:54 AM
Personal Sales Rating: ( 24)
Drives: El ocho
__________________
"Failure Is Not An Option"
Offline
Aug 8, 2009, 02:15 AM
Drives: Lancer Evo IX SE
good luck
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
