Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Engine/Turbo
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 2, 2009, 04:36 PM   #1
Personal Sales Rating: (0)
Drives: 05 evo
possible immobilizer issue
i just did a complete rebuild on my 8 and after about 250 -300 miles a quiet tick developed from the CRANK pulley area and did some poking around and everything checked out as far as timing and the pulleys. i took it out for a drive the other day and the car just died i pulled into a parking lot and tried starting it and it would idle up to 1900 rpm or so the die. the next morning i started it and it idled normal for 5 seconds or so then died again. it is not throwing any codes what so ever. i checked the fuel system and it has plenty, then i pulled the ignition harness and it had no voltage. now with that in mind i have heard that the only things that might cause that are the crank position sensor and the cam position sensor. but wouldnt either one of those throw a code? and as of last night the car wont start . does anyone have some input as to where i might start troubleshooting? or how i would reset the immobilizer? or better yet what would have caused this?
Offline
Old Jul 3, 2009, 12:43 PM   #2
Personal Sales Rating: (14)
dsevo's Avatar
Drives: 2003 RR Evo
That definitely doesn't sound like an immobilizer issue, because it would have never ran or started.
Offline
Old Jul 3, 2009, 03:18 PM   #3
Drives: 05 evo
i got power back to the ignition it starts, but will not stay running so it isn't the immobilizer. someone was saying that the iat sensor could cause this to happen i will check that next if anyone has any other ideas please let me hear them.
Offline
Old Jul 9, 2009, 03:03 PM   #4
Personal Sales Rating: (3)
Drives: 05 VIII
this happened to me when i used my spare key. it would start and stay running for a lil bit then die. if i would go to start it again it would not start. if i used my regular key it would start right away n run fine. did you ever figure out what it was? im curious if it is the immobilizer because im about to do remote start
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
