Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Engine/Turbo
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 24, 2009, 01:23 PM   #1
Personal Sales Rating: (0)
Drives: 1998 eclipse gst
Head Gasket Issues
I am working on a 2004 Evo 8 and Mods are as listed.
-Built 2.4 4G64 bored over .020" 9.0:1
-4G63 head with oversize valves crower valvetrain and BR 272 cams
-L19 ARP headstuds
I cannot get this thing to hold over 30 psi with the cometic 4G64 head gasket, Power Enterprises makes a 4G64 overbore gasket for this setup. Has anyone used this gasket before, I am looking to push 40psi on race gas.
Also the head has been milled .015". Is the head still ok to use?
Please anyone who has any experience with the 4G64 please chime in, any help or constructive thoughts are greatly appreciated.
Offline
Old Jun 24, 2009, 03:14 PM   #2
dastallion951's Avatar
Drives: 03 evo 8 bby
ive heard stories of 4g64 head gasket issues....as long as the head studs arent coming loose...i would say try the power enterprises gasket....but be careful how much they take off the deck of the head because if they take too much off it will have an effect on ur compression ratio....and u also need to make sure the surface of the block where the head bolts on to is even and also clean so u make a good tight seal....gl
__________________
espelir catback dc sports cat delete downpipe titek 3" 02 housing hks 272 cams xs engin fmic and piping 880 injectors 255 pump dejon tool greddy type rs bov tein lowering springs built 2.0 block je pistons eagle rods acl race bearings arp main head rod studs brian crower valvesprings and retainers stock valves fp red turbo balance shaft eliminator kit aem wideband gauge milspec exhaust manifold high pressure throttle body seals aem intake optima battery relocated to trunk
Offline
Old Jun 24, 2009, 03:19 PM   #3
Ive heard that once the head gets thinner than 5.180" deck to valve cover surface it is time to replace. Im not worried too much on the comp ratio .015" is not going to change it enough to matter on my setup
Offline
Old Jun 26, 2009, 04:56 PM   #4
BUMP does anyone run a 2.4?
Offline
Old Jun 26, 2009, 05:53 PM   #5
Personal Sales Rating: (11)
Drives: 03'Evo8, 93' RX-7, 95' TSI, 92'TSI, 91'TSI x2, 92'GSX, 97'Civic EX, 08' GSX-R, 03' ZX6R 636, 03' Chevy Express van
I have had several issues with the Cometic head gaskets holding up on a 2.4L build. The tune could have been a factor as well but in the end, we ended up doing a 2.3 to get rid of that block. Good luck.
Aaron
Offline
Old Jul 3, 2009, 12:49 PM   #6
Personal Sales Rating: (14)
dsevo's Avatar
Drives: 2003 RR Evo
I'm just finishing up my 87mm 4G64 build right now with a PE head gasket, so I don't have any real info for you yet. I have heard very good things about the PE hg though, and that is why I chose it. Supposedly it is very similar to the HKS, just .5mm bigger bore. FWIW, Norris designs runs 1k+ hp through a 4g64 with an HKS gasket, so we know it can work.
edit: And btw, I've never heard of anyone having good luck with a Cometic on a 4G64 block.
Offline
Old Jul 3, 2009, 01:37 PM   #7
dsevo's Avatar
Drives: 2003 RR Evo
One more question, what did you torque your L19's to? Mine are at 100ft/lbs.
Offline
Old Jul 5, 2009, 11:02 AM   #8
thebluesky's Avatar
Drives: faster than the cops can clock
Send a message via Yahoo to thebluesky
Quote:
For some reason, that sounds a little high. What is the manufacturers recommended torque?
__________________
Horsepower is no substitute for brains, f@#kers!!
Offline
Old Jul 5, 2009, 11:08 AM   #9
dsevo's Avatar
Drives: 2003 RR Evo
Quote:
Thats what ARP old me to torque them to, but I never found it in writing. I just called and thats what they told me. Keep in mind they are L19's.
Offline
Old Jul 6, 2009, 07:44 AM   #10
They told me 110-119
Offline
Old Jul 6, 2009, 09:02 AM   #11
Cometic Gasket is the problem. I had several blow coolant and around 25-30psi and in the 500-600whp range. I would have had the PE gasket but the 6bolt version that I need is unobtainable so I ended up with a FelPro gasket. Good luck and throw that cometic in the garbage.
Offline
Old Jul 6, 2009, 09:32 AM   #12
dsevo's Avatar
Drives: 2003 RR Evo
Quote:
Now I'm wondering if I should up mine. I really don't want to f with the head gasket.
Offline
Old Jul 6, 2009, 05:28 PM   #13
Did you o-ring the head and if you did who did it and how much??? The problem that im finding is that no one wants to o-ring a 4G63 head for a 4G64 let me know.
Offline
Old Jul 6, 2009, 10:35 PM   #14
dsevo's Avatar
Drives: 2003 RR Evo
No I did not o-ring the head. I was told it was not necessary with a good hg. John Bradley is building a 4g63/4g64 combo using the PE hg and he is not o-ringing it either. The shop that built my head would have done it though. Millenium Motorsports in Temecula, CA.
Offline
Tags
4g63, 4g64, 636, arp, cometic, gasket, head, issue, issues, milled, problem, replacement, stud, temecula, thinner, zx636
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
