Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Engine/Turbo
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 23, 2009, 05:51 PM   #1
Personal Sales Rating: (3)
loofee's Avatar
Drives: 03-Evo
Timing belt noise.
Well after I install my new timing belt this past weekend.
Start-up was perfect, idle great, drive smooth, and boost fine.
but,..( yeah I know..) there's slightly more noise from the timing belt that happen only at idle..
Do you think that I put too much tension on the belt? should I be concern?
anyone experience this with theres??
I'm about to re-do, re-tension my belt. but if Its normal I might just leave it alone.
any info is greatly appreciate. C
__________________
Boost feels refreshing like.... waking up on a nice cool spring Sunday morning with a new pair of underwear and icy cold beer on the side of ur bed right by the beach.[
Offline
Old Jun 23, 2009, 06:19 PM   #2
Personal Sales Rating: (1)
Slovo's Avatar
Drives: 03 Evo 8 / 95 supra
Send a message via AIM to Slovo
Well what kinda noise is it? From my personal experience of timing belts, as working for toyota, belts that sounds like they are whining are tight, and belts that sounds like its flapping is loose. Kinda hard to explain but, when you feel the tension of the belt between the two cam gears, there should just be enough to move up and down about about a few cm's or so. Almost like if there were anymore tension right there you would know right away that its too tight. Might sound retarded but im not sure of exactly how to say it. Anyways hope that helps in any way!
Offline
Old Jun 24, 2009, 08:31 AM   #3
Personal Sales Rating: (7)
20gmr's Avatar
Drives: 06 gg mr
The evo has an automatic hydraulic tensioner. The tension is not adjustable. What parts/ pulleys did you replace when you serviced the T belt?
__________________
Quote:
Originally Posted by HobieKopek View Post
Technicallly it's French.
It's "douche".
GARAGE / EBAY turbo kit 428whp,350wtq. .......My EVO has a drinking problem
442whp CBRD Mustang Dynp 376 wtq
NEW NUMBERS 480whp 370 wtq Thanks to BLOUCH TURBO and CBRD!!!!
Next setup is in the works .....stay tuned
11.6 @ 120 mph....... IN A 6 SPEED
Online
Old Jun 25, 2009, 07:23 AM   #4
loofee's Avatar
Drives: 03-Evo
Quote:
Just the T-belt and balance belt. the pully and tensioner seem to be in good shape. C
__________________
Offline
Old Jun 25, 2009, 07:41 AM   #5
Personal Sales Rating: (13)
rcheung's Avatar
Drives: 2003 Evo 8
Replacing the belts without the pulleys, water pump and tensioner is just asking for trouble. You may have to do the work all over again and replace the tensioner.
__________________
2003 GSR EVO
HFC, Greddy SP2 Exhaust, HKS intake, Megan Exaust manifold , Megan O2 turbo outlet, reflash, AVC-R@21 PSI, walbro 255, HKS 264 I/E, Shep stage 2 Transfer Case with Ralliart LSD. Blox polyurethane front engine mount.
Offline
Old Jun 26, 2009, 07:08 AM   #6
loofee's Avatar
Drives: 03-Evo
well, re-did the belt and play with teh tension a lil more on both the T-belt and balance belt.from start to finish under 4 hours with about hour n a half of do, and re-do. the noise is now GONE. run and idle quite like it supposed to. C
__________________
Offline
Tags
beer, belt, cold, idle, noise, noises, noisy, timing
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
