Apr 9, 2009, 12:22 AM
Personal Sales Rating: ( 0)
Drives: 2003 evo 8
WTF!?! Random misfire happening around 3k RPMs at 71-74 MPH in 5th gear only.
Okay, so the majority of my problem is listed in the title. Here is whats not. This happens randomly. It only happens at 71-73 MPH in 5th gear only. Here is the real kicker, I have had this problem before and I have since installed a new engine and the misfiring just started again today. I was not boosting at all, but it has happened under boost as well. Parts that I have checked are the coil packs, and spark plugs (ie: gapping, fouled) and everything looks to be ok. Does anyone have any idea what is wrong with my car, and how or why it followed after the engine swap? Fuel related? ECU related? Vacuum? Need some help here guys. Thanks in advance.
Dave
Offline
Apr 9, 2009, 01:29 AM
Drives: 2003 evo 8
Bump!
Offline
Apr 9, 2009, 01:45 AM
Drives: Evo IX MR
how about cam position sensor?
Offline
Apr 9, 2009, 01:46 AM
Personal Sales Rating: ( 1)
Immediately after misfire, try to check the spark plugs and see if you can spot the difference.
Is your ecu tuned or standard?
Have your tried changing the cam sensor?
Each time it misfires, how long does it last?
Offline
Apr 9, 2009, 06:06 AM
Drives: 2003 evo 8
I will pull the plugs tomorrow when I wake up. As for the ECU, it is very mildly tuned. (Email flash) I will say that I had the problem with the OEM tune as well. As I stated before, the problem followed with my engine swap. The new engine had a new cam sensor on it, but I will test it out. When the misfire occurs, it usually only lasts for the duration of the drive when it starts to misfire. I can also get it to stop misfiring by letting off the throttle and then gettting back into it. Here is the catch with that. If I accelerate back to 3K RPMs, it will immediately start to misfire again. If I accelerate past 3K it will run perfect. After being turned off for a while (12 hrs. +) the check engine light will automatically reset and everything goes back to normal.
Offline
Apr 9, 2009, 06:42 AM
Personal Sales Rating: ( 26)
Drives: EVO
who did you email flash through?
__________________
Tuned by Mellon
_____________
Quote:
Originally Posted by bboypuertoroc
If I was ghey, I would TOTALLY marry Mellon.
WTB: Passenger side Headlight w/ Fog light. PM Me with a price
Offline
Apr 9, 2009, 07:57 AM
Since your check engine light comes on, there must be engine check codes. Get the engine check codes.
Offline
Apr 9, 2009, 03:21 PM
Drives: 2003 evo 8
Noelsevo is the guy that tuned my ECU. The only code it throws is P0300 Random Misfire.
Offline
Apr 9, 2009, 06:14 PM
Drives: 2003 evo 8
Back to the top!
Offline
Apr 10, 2009, 06:16 PM
Drives: 2003 evo 8
Here is my only problem with that thread, they are talking about getting the p0300 with no real reason. With me, my car is misfiring badly and it basically sounds like a sick Subaru when this is happening. I do not think that the tranny would actually cause it to misfire rather than the stated "trick the ECU into thinking it is misfiring and pop the code" .
Offline
Apr 10, 2009, 10:59 PM
Drives: 2003 Evolution VIII
this is off the wall, but i had a misfire because i had an issue with fueling.
check injectors/fuel pump/etc...
Offline
Apr 11, 2009, 11:34 AM
Drives: 2003 evo 8
Noted ^^ I am working on getting a multimeter to test the injectors among other things.
Offline
Apr 11, 2009, 08:51 PM
Drives: 2003 evo 8
Bump!
Offline
Apr 12, 2009, 09:33 PM
Personal Sales Rating: ( 27)
Drives: 2005 evo 8
Quote:
when i had misfire like that it was my coil
__________________
(700hp)6.6@111mph on Stock SSL car, With a sunroof lol
762hp and 608tq on the stock ecu!
771hp & 606tq - New
800s are next
Sponsored by:
ETS
JM Fab
Force-Fed Performance
Offline
Tags
2003, 2004, 43, 74mph, cams, cel, check, codes, engine, evo, evo8, evolution, integra, misfire, p0300, random  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
