Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Engine/Turbo
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 7, 2009, 08:26 PM   #46
Personal Sales Rating: (0)
death1969's Avatar
Drives: 2003 Lancer Evolution
hmmm... i had the same thing happen, most of the time my cel was not on but i checked with my obd2 reader and found that i had that a P0300 i cleared it an have had not issues.. no clue
Offline
Old Nov 8, 2009, 10:56 AM   #47
Personal Sales Rating: (1)
evosoh's Avatar
It is definitely a misfire. This is shown from your AFR going lean. You could check if your cam sensors are faulty. Why not disconnect the knock sensor to see if the problem goes away.
Quote:
Originally Posted by darkside4G63 View Post
i am having the exact same problem as the OP. i have replaced the plugs (several times actually), i got the Spark Tech non cdi COP so my coils are replaced, and i had the 2 vacuum lines pop off the EGR and i put them back on and zip tied them up. i cleared the codes and it stopped for a while (2000 mi.) then it happened again. i checked and the vacuum hoses are still good. i noticed that i was picking up crazy knock when it happens and my wideband bottoms out lean. i dont think it is a fuel issue. im leaning more towards that phantom knock coming from the drivetrain via the input shaft. has anyone had any luck altering the knock filters in ECU Flash in the 3000 rpm, low load area to fix this. if so what direction do you go with the values to de-sensitze the knock sensor? Tephra, do you have any input? any help would be greatly appreceiated as i do not have the funds to rebuild my tranny at this time.
Offline
Old Nov 17, 2009, 06:07 PM   #48
mt057's Avatar
Drives: 03 lancer evolution 8
If you are throwing a p0300 and drive an Evo 8. You should check out the p0300 disable test. It will get rid of the shuttering that happens on the highway related to the p0300.
Changing periphery bit 2 to e7cf will stop it I believe, but I recommend reading the thread it is very informative if you have not already.
disable P0300 test
__________________
3" tbe, GSC S1's, Aquamist hfs-1 100% meth, Greddy cam gears, Injen IC hard pipes & intake, ACT hdss clutch w/ Prolight flywheel, Walbro 255 lph, Greddy Profec B Spec 2 ebc, Fp Red 80mm, Syncronic BPV, ETS 3.5" IC
Offline
Tags
2003, 2004, 43, 74mph, cams, cel, check, codes, engine, evo, evo8, evolution, integra, misfire, p0300, random
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
