Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Engine/Turbo
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 17, 2009, 04:30 PM   #16
Personal Sales Rating: (36)
Evoryder's Avatar
Drives: EVO METH MACHINE
you're probably running too much timing at cruise(economy tuning) or you have shot spark plugs
__________________
TEMEVO
"I'm addicted to 100% Methanol : ) "
MACHINES GONE WILD
FOR SALE: FORGE WASTGATE/PERRIN INTAKE CLICK ME
Offline
Old Apr 17, 2009, 04:36 PM   #17
Personal Sales Rating: (11)
JordanS4's Avatar
Drives: Audi S4, 2006 TB IX MR
didn't the 03's have a problem with the transmission causing P0300?
__________________
JAM Stroked. HeadGames. FP White. DTM Built
Offline
Old Apr 23, 2009, 10:04 PM   #18
Personal Sales Rating: (0)
dave3kgt's Avatar
Drives: 2003 evo 8
Sorry I have not been on to updated later, I just got back from a detachment. Anyhow, I changed out the coil packs and it has not misfired again. .... Yet. So hopefully it is good to go. I will post back up if something happens.
Offline
Old May 2, 2009, 08:39 PM   #19
dave3kgt's Avatar
Drives: 2003 evo 8
Well, I guess the coil packs did not fix the problem. My car started misfiring again today. It is happening the same as before and this time I tried holding the RPMs steady at 3 to 3.5K in 3rd, 4th, and 5th gear. It misfired in all gears. I have no idea what is wrong. Does anyone else have any ideas?
Offline
Old May 4, 2009, 08:40 AM   #20
dave3kgt's Avatar
Drives: 2003 evo 8
bumpo!
Offline
Old May 5, 2009, 01:53 AM   #21
dave3kgt's Avatar
Drives: 2003 evo 8
Wow. Did the forum shut down and I didn't hear about it? (cricket sounds) Bump again.
Offline
Old May 7, 2009, 02:55 PM   #22
Personal Sales Rating: (1)
M4Lki3r's Avatar
Drives: 2003 Evo VIII
Send a message via AIM to M4Lki3r Send a message via MSN to M4Lki3r Send a message via Yahoo to M4Lki3r
How do you know that you are misfiring??
Unless I miss my guess your knock sensor is hearing the transmission and thinks that it is knock and retards the timing to save the engine. Releasing the throttle and getting back on it will temporarily fix this while driving, correct?
I believe there is a TSB for this, but the dealership will want to reflash your ECU first. The other option to fix this, would be a transmission rebuild. I'm not exactly sure what it is that needs replaced in the transmission. Hope this helps.
__________________
Works TBE (no cat), FP Green, FP O2 Housing, AEM EMS, RC 1200s, K&N Filter, AMS FMIC, Mini-batt, 255 Fuel Pump, HKS 272s, ARP Head Studs, Works Alum Flywheel, Works Clutch Kit 1, Halman MBC, Works Brake Package 2...plus little stuff.
Offline
Old May 8, 2009, 06:43 AM   #23
dave3kgt's Avatar
Drives: 2003 evo 8
So if your guess is right, I should be able to unplug the knock sensor and be great then right? The TSB is listed here, and from what I can tell, it is to fix the P0300 code that randomly pops. http://www.lancerlogic.com/forum/eng...m-misfire.html I also tried the troubleshooting listed in this TSB (disengage/re-engage the clutch at highway speed to trigger the "code") This did not work. But, I will try driving with the knock sensor unplugged the next couple times that I go driving and see if the misfiring stops.
Offline
Old May 15, 2009, 12:54 PM   #24
Personal Sales Rating: (40)
subrwho's Avatar
Drives: 2004 Dodge ram 2500, 2003 TB Evo 8(Sold), Acura Integra (DD), Yamaha R6 Raven edition
Quote:
did this work for you? I just developed the same problem!
__________________
AMS 50 trim kit, AMS Down pipe, AMS fuel rail, Fic 850cc injectors, Hks cat back, Hks intake, BC 272's, Walbro 255fp, Quartermaster Twin Disc, Hallman Mbc, Forge dv, Injen Uicp, XS Fmic, 4WS tuned, Jdm rear, Evo IX front bumper with ralliart lip, Bronze Rota boosts, Jdm headlights, Evo 9 Uk tails, Defi boost and egt, Aem wideband, plus much more....
The evo is now SOLD :(
Offline
Old May 15, 2009, 06:33 PM   #25
dave3kgt's Avatar
Drives: 2003 evo 8
I have not tried unplugging the knock sensor, but I intend to. Does your car actually start misfiring or does it just pop the P0300 code?
Offline
Old May 15, 2009, 08:41 PM   #26
Personal Sales Rating: (26)
gsrboi80's Avatar
Drives: 03 TB VIII
Have you tried upgrading your ROM from 0008 to 0015?
This was Mitsu's fix for the P0300 back in 04 when all the 03's were going back to the dealer for the code. Mitsu found out that the code is actually triggered by drivetrain harmonics.
A couple other cause were as other stated. Large jumps in timing from one cel to another. Too much timing in those cruising load cells. If it comes down to it just disable the test routine in the ROM and you'll never see the code again
__________________
4WS TUNED VIII
Quote:
Originally Posted by Evoryder View Post
Its' the turbo punching out for the day
Offline
Old May 16, 2009, 05:12 PM   #27
dave3kgt's Avatar
Drives: 2003 evo 8
Well, thats the problem. I am not only experiencing the code, but also the associated misfire. The car literally loses power, and starts to sound like a sick Subaru. Still think it can be the ROM? If so, where could I download a 0015 ROM?
Offline
Old Jun 7, 2009, 11:46 AM   #28
Personal Sales Rating: (3)
Monochrome's Avatar
Drives: 05 Apexi Silver EVO VIII w/ SSL
How old is your fuel filter? Any holes in your exhaust before the 1st O2 sensor (cracked manifold, leaky exhaust gasket)?
__________________
05 Apexi Silver EVO VIII with SSL
Non-Stop Mixes By Monochrome <- click to listen! (Updated 9-7-09)
Offline
Old Jun 7, 2009, 11:56 AM   #29
Personal Sales Rating: (42)
xspsi4's Avatar
Drives: evo 1 gsr/ evo ix mr 5spd
Mine does the same thing, What clutch do you have?
I have a real good theory on this but need to find out what clutch you are running first but driveline harmonics are the root cause as stated above
Where can we get 0015 for download?
__________________
The good die young and the pricks live forever!
-Lewis black
Offline
Old Jun 8, 2009, 06:39 AM   #30
Personal Sales Rating: (7)
20gmr's Avatar
Drives: 06 gg mr
definately not the rom. I did not read through the entire thread but from what I have gathered the car drops a cylinder under load. I know you mentioned getting new coil packs but did you replace plugs and wires? Plugs are kind of obvious but if you ever pulled the plug wires off the plugs by the wire you can ruin them ( learned the hard way ) it is nearly impossible to spot where they are damaged but id be willing to bet plug wires is your issue
__________________
Quote:
Originally Posted by HobieKopek View Post
Technicallly it's French.
It's "douche".
GARAGE / EBAY turbo kit 428whp,350wtq. .......My EVO has a drinking problem
442whp CBRD Mustang Dynp 376 wtq
NEW NUMBERS 480whp 370 wtq Thanks to BLOUCH TURBO and CBRD!!!!
Next setup is in the works .....stay tuned
11.6 @ 120 mph....... IN A 6 SPEED
Offline
Tags
2003, 2004, 43, 74mph, cams, cel, check, codes, engine, evo, evo8, evolution, integra, misfire, p0300, random
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
