Fp Green turbo hot side
Old Mar 13, 2009, 01:49 AM
LION evo's Avatar
I have a problem with the turbine housing of my fp green. The turbocharger does not spool up. The trouble is in the wastegate of the turbine housing. It was milled by previous owner and now it leaks. I need new turbine housing. Is Fp green turbine housing the same with evo 9 turbine housing? Will Evo 9 turbine housing fit without fabrication?
thank you for replies
Old Mar 13, 2009, 04:14 AM
EVO8LTW's Avatar
The FP Green has a larger turbine, so the housing will not be the same as the stock Evo9.
Old Mar 13, 2009, 04:17 AM
str8kor's Avatar
just order one from fp
Old Mar 13, 2009, 05:04 AM
Appauldd's Avatar
Are you sure it just does not need an WG actuator arm adjustment? I ask because I had the same problem. I tore it all apart only to discover that the actuator rod was holding the flap valve open ever so slightly.
Easy enough to check....give it a shot.
Old Mar 13, 2009, 06:25 PM
LION evo's Avatar
We adjusted the actiator arm. It helped little but the trouble was not shot. the Turbocharger still did not spool up properly. I think it ileaks s due to a flap valve hole burn through
Old Mar 13, 2009, 06:27 PM
LION evo's Avatar
Is it possible to take turbine side from an evo 9 turocharger and mill it to fit to my Fp green?
Old Mar 13, 2009, 06:29 PM
LION evo's Avatar
I asked my local vendor. It will take much time and money to get it
Old Mar 19, 2009, 11:24 AM
stockEvoIX's Avatar
The turbine housing will need to be machined out for the green. A good machine shop would be able to do it. If you take the bad hotside in they should be able to machine the other 10.5 hotside to the same tolerances.
Brigganator
Feb 28, 2013 05:28 PM
midegade
15
Mar 9, 2011 06:45 PM
twista
May 18, 2010 07:53 AM
LION evo
Mar 13, 2009 05:36 AM
Evo11V
11
Oct 31, 2007 10:12 AM
Quick Reply: Fp Green turbo hot side
