Dec 29, 2008, 09:21 PM
Personal Sales Rating: ( 8)
Drives: JDM Evo VII
Which Cams Combo?
Hello im new into the evo's and cams things..Im looking to install some HKS cams on my car and want to retain the stock valve springs etc..
Some Ppl tell me to go with the 264 on both int,exhaust..But I see that some ppl run 264/272..
What are the pro and cons on using different types and running the same on both..thanks
Oh btw I drive a VII JDM GSR
Offline
Dec 31, 2008, 08:38 PM
Personal Sales Rating: ( 0)
Drives: CT9A (MR/9) - Hopefully AE86 Soon
wow no one was helpful.
I was looking at cams too..
Offline
Jan 2, 2009, 02:22 PM
Drives: JDM Evo VII
No one aparently...
__________________
JDM VII GSR
3' Kakimoto Exhaust,FP WGA-Custom Intake-HKS Grounding-D-Jetro Power Fc-LICP-ACT Clutch-Manifold-Downpipe-o2 Housing
Hks 272/272 Walbro 255
368 Awhp @ 24Psi Tuned By C-Works Performance
Offline
Jan 2, 2009, 02:30 PM
Personal Sales Rating: ( 7)
Drives: 2003 Mitsubishi Lancer Evolution
I just got HKS 280s after many days of research. You can still retain the stock valve springs, pm me for any other q's.
Offline
Jan 2, 2009, 02:34 PM
Personal Sales Rating: ( 2)
Drives: AUDI A3 S-Line, 05 Evo 8 SOLD
264's are a waste. Go 272's or 280's...
Offline
Jan 2, 2009, 02:36 PM
Drives: EB IX
GSC S1's or S2's are great cams imho. There is a lot of research you can do to find what you think you would like best.
__________________
371whp/333wtq at 25psi/pump gas
Offline
Jan 2, 2009, 05:12 PM
I don't want to lose any low end power because most of my driving is granny/daily driving. I only like to have fun now and then.
Offline
Jan 2, 2009, 05:17 PM
Drives: JDM Evo VII
If I go with the 272 or 280 wont I have the Humpy idle or the car will not be street friendly...
__________________
JDM VII GSR
Offline
Jan 2, 2009, 05:28 PM
Drives: 03 RR VIII
HKS 272's doesn't lope that bad
Offline
Jan 2, 2009, 07:05 PM
Personal Sales Rating: ( 5)
Drives: 05 lancer evolution 8 ssl / 96 Eclipse GST
I have HKS 272/272 on otherwise stock head. Not to agressive imo, but they are more agressive than the BC 272/272 I was running. There is a huge thread somewhere on the fourms that dyno tested several different cams. Just do alot of research. There is also a very imformational video I used to help me with my instillation. http://videos.streetfire.net/video/H...-on_138721.htm . Thats for an VIII, im not sure if its the same as doing it on a VII but you get the point.
__________________
520awhp 388ft/lbs torque
Offline
Feb 1, 2009, 02:06 PM
Drives: '03 Evo VIII, '91 240sx HB
search evo cam test, AMS took alot of time to test various cam shafts and give the results. It sounds to me like the Kelford 272's might be a good choice for you, however normally you would want to upgrade the valve springs. If you don't run the car at high RPM all the time you might be ok though. Just know that eventually you will have to change the springs because with any upgraded cam shaft you are going to wear out the stock springs quicker then normal. If you absolutely don't want to change the springs, look into either the WORKS 269 or the greddy easy cams.
Offline
Feb 14, 2009, 08:23 PM
Drives: 05 evo8 & 07 tacoma
i got hks 264 in/272 ex .i like them alot u still get low end a lil loping ,and no stalling at idle on stock valvetrain.just purchased fpred so im upgrading cams for the jun 272's w/springs and retainers..i would go with 264/272 imo..i made 415whp and 393trq on 100 oct.w/hks cams and 381whp/363trq on 91 oct.its all in the tune ..
Offline
Feb 27, 2009, 01:22 PM
Im running Hks 264/272 combo i love em....good for smaller turbo setups
__________________
HKS TBE
HKS 264/272
UICP/LICP
AMS FMIC
Tial 50 Bov
ETS equal mani
GT35r
Fic 750's
Walbro 255
Numbers coming soon....
Offline
Apr 6, 2009, 12:45 PM
I just bought GSC S2's for my Mivec IX, should work good with the 3076 I bought I hope.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
