Blew my motor a week ago coming back from SEMA to LA. Motor comes out on Monday. Going with a 2.3L rebuild. I will post pre-rebuild and post-build dyno results after the rebuild & tune for both E85 and 91oct+50/50.
Here's a list of my current mods:
My current mods include:
FP Green ported turbo w/FP 18 PSI actuator
RC1000 injectors
Agency Fuel Rail
FULL RACE exhaust manifold (tubular)
HKS 272 MIVEC cams
65mm Mil Spec TB (ported)
Sparco Intercooler
Supertech Springs & Retainers
Horsepower Freaks LICP
UICP
AEM meth kit
ECU load boost control
HKS DLI II
TiTek O2 housing
Walbro Fuel Pump
Baker small battery w/modded AMS small battery kit
ARC Intake Box
Ingalls Stiffy Engine Torque Damper
Full exhaust w/test pipe
HKS Ti Carbon muffler
Buddy Club grounding kit
ACT HDSS Clutch w/ StreetLite Flywheel
DEFI gauges (EGT, Boost, Oil Pressure)
Labonte flow gauge (for meth)
AEM UEGO A/F gauge
GM boost solenoid
OMNI 4-bar map sensor (for logging)
Stock ECU (flash w/ alternative map switching functionality)
E85 & 91oct + 50/50 Meth/H2O tunes
NEW MOD SETUP:
FP Red 80mm inlet ported turbo w/FP 25 PSI actuator
FP Evo Oil Filter Housing Line Kit
FP Evo 3" Intake Pipe
2.3L Stroker Kit with Forged Pistons (Wiseco or Mahle) bored 0.20"
MAP ported and polished head w/ 1mm oversize valves
FIC Bluemax 1450cc injectors
MAP AFPR Install Kit with Fuelab Regulator
MAP External 02 Dump
MAP Crankcase Vacuum Kit
MAP Rev2 Intake Manifold (for 65mm TB)
Buschur Racing Double Pumper Fuel System w/Dual Fuel Feed Line Kit
GM AIT sensor bung and ECU wiring (for Speed Density ECU mod)
P2R Thermal Intake Manifold Gasket
TiAL Q Blow-off Valve
BLOX Racing Engine Roll Stopper
EGR blockoff plate w/EGR system disconnected
Agency Fuel Rail
HKS 272 MIVEC cams
Sparco Intercooler
UICP
AEM meth kit
Tephra/MrFred ECU gear-based PSI boost control
HKS DLI II
ARC Intake Box
AEM UEGO A/F gauge
GM boost solenoid
OMNI 4-bar map sensor (for logging/PSI controlled boost)
E85 & 91oct+50/50 meth/H2O tunes
