Nov 14, 2008, 01:09 PM
Personal Sales Rating: ( 11)
Drives: 2006 Evo IX GSR/SSL
what about Diverter valves? Is the oem ix good enough for 30psi on red?
I know I can't do a vta, but was wondering what everyone else with red's are using for DV/BOV ?
Offline
Nov 14, 2008, 01:22 PM
Personal Sales Rating: ( 9)
Drives: 2006 evo IX MR
Here's my setup below.... Im going to be porting my turbo. also my intake and exhaust mani soon and adding a aem ems to try to squeeze every drop out or her. Im hoping for 550whp.
__________________
Buscher ported/coated exhaust mani
works o2 housing
works 3" dp
works tbe
works test pipe
cosworth 272's
titanium valve springs and retainers
walbro fuel pump
works 65mm tb
forge mbc
ets licp(version 2)
ets uicp
ams frontmount
arp headstuds
precision 680cc
fp red/Buscher ported/coated hotside
shepherd 5speed conversion
Exedy triple disc
buscher intake
aquamist meth kit
Offline
Nov 14, 2008, 01:57 PM
Personal Sales Rating: ( 0)
Drives: 85 Yugo
Injector sizing is relative to fuel properties/differential pressure, max engine RPM (available inj time per cycle), and ECU/induction strategy. While one car may be overkill on 850's another will be needing 1200's.
Offline
Nov 14, 2008, 02:03 PM
Personal Sales Rating: ( 3)
2003 Mitsubishi Lancer Evolution
Drives: '03 Evo 8, '02 FZ1
Some say that if you crush it, then it will hold 30 psi, but it will only hold 25-27 without crushing. I went with the Forge RS, much better!!!
Offline
Nov 14, 2008, 03:42 PM
Drives: the car pictured above ^
Quote:
I've been using Forge diverter valves on my turbo cars for years and years... they have always worked flawlessly.
Offline
Nov 14, 2008, 08:14 PM
Drives: 06 TB EVO IX SE
i did 379/313 on a mustang dyno that reads dead on with Buschurs dyno with a stock IC/block/ecu 93 oct at 26psi...
turned up the boost to 30psi 421/355.....93oct....so you can see with 4psi more i picked up almost on 40hp and torque went up...
If anybody planning on running boost levels lower than 25psi id stick with the green...the red does love boost but can still perform awsome in 25-30psi levels..
Offline
Nov 14, 2008, 08:18 PM
Personal Sales Rating: ( 8)
Drives: WW IX MR
Quote:
Going with the APS Twin.
__________________
Old car-03 Solar Yellow SRT-4-398/396 whp/tq
Ivey Tuned
Powered by Forced Performance
Offline
Nov 14, 2008, 08:28 PM
Drives: 2006 Evo IX / 1997 Mits Galant
SRT-TO-EVO How much do you expect to make with what you have in your sig and pump 93 vs E85?
Iam thinking of an fp Red as well but I have to get a shopping list together to prepare for it. My mods in my sig is just a start and Iam sure I have a lot more to add....
__________________
06 Apex Silver EVO IX
:::Mods:::
Megan TBE, Walbro FP, Apexi TT, RPS Turbo Max Clutch, Fidanza Flywheel, MGW Tune
Offline
Nov 14, 2008, 11:04 PM
Personal Sales Rating: ( 7)
Drives: 03 EVO. 07 Escalade. 08 G37s
i am still on stock clutch, syncro's, etc. 44,000 miles. mods below. (someone asked earlier if anyone was on stock clutch)
i had a plastic stock BOV, AMS recommended a billet samco sport DV. car is tuned for E85 holds boost fine with no bucking or drivability issues. AMS ftw.
__________________
2003 Lancer Evolution
-FP BLACK
-ETS 3.5" FMIC
-AMS 2.3L Stroker
-Oliver Rods
-PTE 1200 cc inj
-BR Double Pumper FP
-Nisei LICP
-BR ported/coated ex mani
-TBE/Test pipe
-ebay 02 housing
-Hallman Pro @ 34psi
-GSC 272i/272e
-AMS Cone filter kit/FP hard pipe
-Samco Sport DV
-ARP headstuds
-AMS poly front motor mount
-EXEDY HD twin disc clutch
-E85
-KW Variant 3 Coilovers
577 awhp, 547 awtq
-Tuned by AMS
Offline
Nov 15, 2008, 09:16 AM
Personal Sales Rating: ( 17)
Drives: his BBK on 26lbs
looks like i'll be running 880's or 1000's. i plan on adding the cams in the spring.
__________________
MidgetSpec.ENGLISH Racing////RoadRace Engineering
ACT / AEM / ARP / Borla / CBRD / ETS / GSC / HKS / Megan / Motul / NGK / OMORI / Precision / RalliArt / Redline / Rexpeed / RRE / Swift / Tanabe / Volk Racing / Walbro
Offline
Nov 16, 2008, 12:22 PM
Drives: WW IX MR
Well on E85 I know I should be REAL close if not at 500whp. But the RED isn't going in until cams get here, ported intake mani, TB, injectors etc. I'm still contemplating on the stock ECU or AEM EMS.
__________________
Ivey Tuned
Offline
Nov 16, 2008, 10:20 PM
Drives: VERY FAST EVO 8
PROFORMANCES MODS
aem tru boots(with upgrade)
walbro 255
Megan 02 housing
HKS 272 intake/EX
ARP head studs
hks 3in carbon ti ex
DC 3in downpipe
aquamist meth kit
Ported manifold from buschur
buschur racing fmic
HKS Dli-II
precision 880cc
DYNOFLASH tune 2morrow(he told me 500whp)
Offline
Nov 18, 2008, 10:36 AM
Quote:
Originally Posted by stikiller214
PROFORMANCES MODS
walbro 255
Megan 02 housing
HKS 272 intake/EX
ARP head studs
DC 3in downpipe
aquamist meth kit
buschur racing fmic
HKS Dli-II
precision 880cc
meth does wonders.
__________________
Offline
Nov 18, 2008, 11:29 AM
Does anyone have a side-by-side picture of the IX turbo and RED? Or IX -> Green -> RED...that would be neat to see all 3 size wise.
__________________
2006 Evo IX GSR w/SSL :)
Offline
Nov 18, 2008, 12:57 PM
Personal Sales Rating: ( 27)
Drives: '08 GG X & '05 Civic R.I.P '05 WW Evo 8
Anyone using bigger oil feed lines for the Red? Or is everyone using the OEM oil feed hard lines?
__________________
"This won't increase my ability to mate?!?"
Offline
Tags
aem, boost, evo, flashing, fp, list, max, mods, motor, psi, red, started, stock, supporting, tru  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
