Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Engine/Turbo
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 30, 2006, 06:07 AM   #16
Personal Sales Rating: (0)
Drives: in the bike lane.
Quote:
Originally Posted by Mike@Forge
Speed Density systems are typically setup as closed-loop systems from the factory, but they can typically use either a recirculating OR atmospheric valve without any major detriment to the system.
MAP based systems (manifold absolute pressure) are typically capable of allowing for the use of either valve as well, but most MAP-based systems are fully stand-alone and require significant tuning to overcome any changes.
MAP = Speed-Density
BPV function is simple: when there is a large pressure-drop across the throttle, the engine is eating much less air than the turbo wants to feed it, so the surplus air must go somewhere.
For small changes in throttle, it can just temporarily build up as pressure in the pre-throttle pipe until the turbo slows down. For large changes, it has to be vented somewhere to prevent compressor surge.
Simple, eh?
__________________
Hello, you have reached an imaginary signature.
Please rotate your screen 90 degrees and try again.
(Joke hint: roots of unity.)
Ahh, electronics- the field of study where, though the voltage is sometimes imaginary, the pain is always real.
Offline
Old Oct 1, 2006, 05:33 PM   #17
Personal Sales Rating: (5)
boostinjuice's Avatar
Drives: 03 RR 8
I have a stock evo 8 with the MAF system running18 psi and then tappering off by redline.. If I plan on running 22psi..and getting a mail in flash.. Would it be possible to run VTA valve after the mail in flash? Amd if so.. What "bypass valve" should I use?
Offline
Old Oct 1, 2006, 05:57 PM   #18
Personal Sales Rating: (7)
Drives: 06 GG Evo IX SE, 09 Mercedes ML 350
Send a message via AIM to PA-silver03evo
Good write up! So often there is mis information floating around here so its nice to get a good truthful write up that can educate everyone.
Offline
Old Oct 1, 2006, 06:22 PM   #19
Personal Sales Rating: (8)
2003 Mitsubishi Lancer Evolution
cfdfireman1's Avatar
Drives: EVO IX
No!!
Quote:
NO
Offline
Old Oct 1, 2006, 06:44 PM   #20
Personal Sales Rating: (1)
Drives: Evo MR
Mike, I will be running a 50 trim turbo kit on the stock ECU / MAF(?) with a piggy-back (UTEC). I am looking for a BOV that can hold high levels of boost (30 psi). I also don't want any stalling, fluttering, or driveablility issues. What BOV would you recommend for my application?
Offline
Old Oct 1, 2006, 06:56 PM   #21
Drives: EVO IX
Cool mike from FORGE
i wonder what mike from FORGE wil say?
Offline
Old Oct 1, 2006, 07:32 PM   #22
Drives: 03 RR 8
Quote:
Originally Posted by cfdfireman1
NO
y?
Offline
Old Oct 1, 2006, 07:42 PM   #23
Drives: EVO IX
Question http://forums.evolutionm.net/search.php?
y?
VTA valve & "bypass valve" 2 dif things. read my friend till your eyes bleed.
Offline
Old Oct 2, 2006, 12:04 AM   #24
Drives: 06' BMW 325i, 04' EVO VIII (SOLD)
Send a message via AIM to NiteRider
I put an HKS SSQ BOV on a few days ago and ran it for a day and noticed my car was running rich. I took it off the next day and put my stock DV back on and I'm noticing a flutter from the stocker. I never heard anything before I put the HKS on and now my mileage is not as good anymore and I am still feeling jerkiness. I have reset the ECU, I don't know what else to do. This thread has definitely helped me to realize the advantages/disadvantages to using certain valves.
Offline
Old Oct 2, 2006, 08:16 AM   #25
Drives: 03 RR 8
so i need a re circulating valve whether or not i have it tuned ..becuase i have a MAF?
Offline
Old Oct 2, 2006, 08:46 AM   #26
Drives: EVO IX
yepper
Offline
Old Oct 2, 2006, 01:33 PM   #27
Drives: 03 RR 8
I'm so confused. I thought you could get a VTA as long as you had your ecu tuned to a VTA valve.. And I have seen other evos with VTA valves and runnin just fine becuase they got it tuned
Offline
Old Oct 3, 2006, 06:26 AM   #28
troe666's Avatar
Drives: Red 2006 Evo IX
Send a message via MSN to troe666
whether this is relevant or not, hopefully it adds something, generally if it's VTA, you obviously adjust the spring tension so that the BOV does not open from idle rpm pulses and yet opens sufficiently when coming off the throttle at all on-boost rpm points. Some people alter spring tensions to adjust the sound of the valve independently of the nozzle/outlet. This is because at a tighter spring tension you'll get a shorter, sharper sound, whereas with a looser spring tension you will encourage actual turbo 'flutter' sound through the air intake as well as cause a lower frequency and often sporadic/staged exit of air through the BOV.
Any BOV without a spring tension adjustment should not really be moved from car to car as compromises will be the sound will change when you move it (at best) or the car will stall badly as you pull up to idle
Trav
__________________
'EVOLVE'
Click Here for my Evolution 9's Photographs!!
Rally Red 2006 Mitsubishi Evolution IX
Mods: Tein SS Coilovers, BBS lightweight rims
__________________
Last edited by Fourdoor; Oct 7, 2006 at 09:38 AM. Reason: remove reference to crap in thread
Offline
Old Oct 6, 2006, 05:18 PM   #29
Personal Sales Rating: (2)
bluevo8urV8's Avatar
Drives: Evo 8
Send a message via AIM to bluevo8urV8
is it posible to "crush" the mr bov to get it to hold more boost? i remember on my 1g talon i crushed the stocker and it held alot more boost.
Offline
Old Oct 6, 2006, 07:33 PM   #30
Personal Sales Rating: (12)
yes it is but you likely wouldn't need to and wouldn't want to for applications beyond the mr valve's capabilities you'd want to do something like a dejon tools leak stop kit mod.
why does anyone think that a leak at idle is good or is normal?
__________________
for sale:
stuff off an 04 gsr. pms are welcome.
front open differential. stock front strut tower bar. stock front crash beam. stock rear crash beam. stock rear sway bar. brass shifter bushings.
Offline
Tags
adjust, diverter, elevation, engine, evo, fluttering, function, maf, management, map, oem, turbo, valve, valves, works
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
