Mitsubishi OEM Turbo Specifications
Flow Rates @ 15psi:
TDO4-9B-6CM2 265 CFM
TDO5-12A-8CM2 320 CFM
TDO4-13G-5CM2 360 CFM
TEO4-13C-6CM2 360 CFM
TDO4L-13G-6CM2 360 CFM
TDO4L-15C-8.5CM2 390 CFM
TDO5H-14B-6CM2 405 CFM
TDO5H-14G-8CM2 465 CFM
TDO5H-16G-7CM2 505 CFM
TDO5H-16G-10CM2 505 CFM
TDO6-17C-8CM2 550 CFM
TDO6H-20G-14CM2 650 CFM
TDO7S-25G-17CM2 850 CFM
TFO8L-30V-18CM2 1200 CFM
Max Output:
TD05-14B (stock 1st gen) 275-300hp @ 21 psi
TD05-16G (small) 345-365hp @ 22 psi
TD06-16G (large) 365-385hp @ 22 psi
TD06-20G 430-450hp @ 22 psi
T25 (stock 2nd gen) 235-250hp @ ?? psi
T3 (super 60)/T2.5 hybrid 265-280hp @ ?? psi
T3 (super 60)/T2.8 hybrid 270-320hp @ ?? psi
Evolution 1
Turbo = TDO5H–16G-7
Nozzle Area (cm2) = 7
Exhaust turbine = Inconel (steel alloy)
Compressor = Aluminium, 60mm wide
Evolution 2
Turbo = TDO5H–16G-7
Turbine = Inconel (steel alloy)
Evolution 3
Turbo = TD05H–16G6-7
Compressor = Aluminium, 68mm wide
Evolution 4
Turbo = TD05HR-16G6-9T
Nozzle Area (cm2) = 9
Evolution 5
Turbo = TD05HR-16G6-10.5T (GSR)
TD05HRA-16G6-10.5T (RS)
Nozzle Area (cm2) = 10.5
Turbine = Inconel (steel alloy), Titanium alloy (RS)
Evolution 6
TD05HRA-16G6-10.5T (RS/rs2)
Turbine = GSR - Inconel (steel alloy), Titanium alloy (RS/RS2)
Evolution 6 : Tommi Makinen Edition
Turbo = TD05RA-15GK2-10.5T (GSR)
Turbine = Titanium alloy for both RS/RS2/GSR!
Compressor = Aluminium, 65mm (gsr) - 68mm(rs) wide
Evolution 7
Turbo = TD05HR-16G6-9.8T (GSR)
TD05HRA-16G6-9.8T (RS/RS2)
Nozzle Area (cm2) = 9.8
Turbine = GSR - Inconel (steel alloy), RS/Rs2=Titanium alloy
Evolution 7 GTA
Turbo = TD05-15GK2-9.0T
Nozzle Area (cm2) = 9.0
Compressor = Aluminium, 65mm wide
Evolution 8
Turbo = TD05HR-16G6-9.8T (GSR / USDM)
TD05HRA-16G6-9.8T (RS/RS2 & NZDM) or 6MT:TD05HRA-16G6-10.5T (model unknown)
Turbine = USDM EVO 8 & JDM GSR =Inconel (steel alloy),
RS=Titanium alloy.
Evolution MR aka "8.5"
GSR = TD05HR-16G6-10.5T or TD05HRA-16G6-10.5T (Ti Alloy option)
RS = 6MT:TD05HRA-16G6-10.5T or 5MT:TD05HRA-16G6-9.8T
Nozzle Area (cm2) = 10.5 or 9.8(RS-5speed)
Evolution 9
USDM & JDM = TD05HRA-16G6C-10.5T
Turbine: GSR / GT = Inconel alloy, RS = Titanium alloy
Compressor: GSR / GT = Aluminium, RS = Magnesium Alloy
(??) mm wide (to be verified.)
Nozzle Area (cm2) = 10.5 (note: to be confirmed that RS 5MT has 10.5)
RS E9 turbo part number 1515A059 (approx cost 250,000 yen from Mitsi Japan).
*Warning* There are reports of RS magnesium compressor wheel failing if boosted above stock boost.
More Evo 9 Turbo info:
... * New more efficient & larger Compressor preventing compressor surge
... * Better pump gas efficiency
... * Turbine Nozzle Area (cm2) = Large 10.5 Hotside (single flapper)
... * Improve actuator design
Side by side comparison E8 v E9 turbos (E9 is on the left and E8 on the right):
Twin scroll design
All Evo 4-8 Turbos are twin scroll designs meaning that the engines exhaust is divided into two channels (see first pic). As the engine exhausts in pulses.. its supposed to result in quicker spooling. From the Evo 4 onwards, the Turbo spins in the opposite direction, i.e. Anticlockwise (hence the R in the turbo name). The Titanium Alumnide alloy used in the RS/RS2 and some GSRS (factory option) has less inertia and thus spins up around 500 rpm sooner. These Titanium turbos can be indentified by the A in their name.
Primary source of data:
http://www.nzevo.com/index.php?name=...iewtopic&p=188
