Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Engine Management & Tuning
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 27, 2009, 07:12 PM   #1
Personal Sales Rating: (0)
jucelavri's Avatar
Drives: EVO IX Silver '06
Send a message via MSN to jucelavri
Knock sum...need some help
Hi, My EVO 9 is doing a lot of knock...I did 3 data logging, and all of them shows more than 15 Knock sum @ WOT...25psi tappering to 22psi...I'm with Stock Turbine & Injectors...
I was reading some threads, most of them guides to reduce the timming...but reducing timming only? do i need to adjust for fuel as well?
Please provide some guidance...
See attached my actual ROM and datalogings...
thanks in advance for your help...
mod's:
Greddy FMIC and piping
INJEN intake
HKS & Helix Cat Delete Exhaust
HKS downpipe
GSC stage 1 camshafts
25psi
Walbro FP
Forge Actuator
__________________
JUN's APEX SILVER Evolution IX GSR
________________________________
http://www.cardomain.com/ride/2913578
Offline
Old Aug 30, 2009, 02:59 PM   #2
Drives: Lancer Evolution VIII
Your fuel map doesn't look too aggressive since it goes pretty rich towards high engine load. I think you can just try lowering timing advance in the areas where you are encountering knock and see if there is a reduction. (try to keep a nice flow to your maps)
Normally if you encounter knock people might recommend increasing fuel mixture (a lower AFR) and reducing timing (1-2 degrees might actually be enough) for the affected areas. (but since your AFR maps seems ok I don't think that's necessary)
Offline
Old Aug 30, 2009, 03:59 PM   #3
hediki12's Avatar
Drives: 95 eclipse gsx
do a map trace and make sure that its real knock. compare the expected timing with actual timing that you logged.
Offline
Old Aug 30, 2009, 05:02 PM   #4
agreed
Quote:
Offline
Old Aug 31, 2009, 03:19 PM   #5
jucelavri's Avatar
What you meant by "map trace "...
__________________
Offline
Old Aug 31, 2009, 03:33 PM   #6
Personal Sales Rating: (2)
nonschlont's Avatar
Drives: AS 06 EVO IX
map tracing isnt gonna help w/ this issue...
You need to post up a log, so we can better pinpoint the issue! Do u have a WB? We need to know your AFR, before we can give any advice... You can knock from being overly rich, as well as running lean....
Just looked at your Fuel and Mivec maps...
MIVEC MAP: 28.8* is the MAX, so having 30's is useless!
FUEL MAP: I dont like your fuel map! it goes from 11.6 @ 180 load (I think it was) and the next cell over is low 9's... So the transition from that load cell to the next will be quite drastic, which could cause knock... Also looks like theres some "block tuning" going on...
__________________
330whp / 340tq @ 26 psi (Dynojet)
320whp / 325tq @ 25 psi (D.L.L)
350whp / 335tq @ 25 psi (Evoscan)
335whp / 301tq @ 24 psi VDR 5.71 (EvoM Mode)
Self Tuned
GM BCS / JDM / EVO X Map Sensor / Ets 3 1/2" intercooler / Injen intake w/ UICP & LICP / Works DP (jetcoated) / JUN B.L. cat back / Mil.Spec 100 cell / Walbro 255 /
Advan RS 18 x 9 +29 in SBC wrapped in Falken RT-615's
245/40/18
Offline
Old Aug 31, 2009, 04:05 PM   #7
I noticed that too, it should have a nice flow and not jump too much.
If you can post one of your logs with AFR, timing advance and knock sum we can move to the next step.
Offline
Old Sep 1, 2009, 12:05 PM   #8
jucelavri's Avatar
I have a WB, but is not set for datalogging...but what I saw from it is that the AFR is oscillating from 11.0-11.4
the datalogging already shows the timing and knock sum info.
thanks for the help.
__________________
Offline
Old Sep 1, 2009, 04:07 PM   #9
jucelavri's Avatar
Datalogings uploaded...thanks in advance for your help!
__________________
Offline
Old Sep 1, 2009, 04:59 PM   #10
Personal Sales Rating: (1)
xxblazexx's Avatar
Drives: 06 ww evo 9
Send a message via AIM to xxblazexx Send a message via Yahoo to xxblazexx
i think the last map is weird.. mine goes down to about 2 degress then slowly goes to 8 or 9 i think
Offline
Old Sep 3, 2009, 09:47 AM   #11
jucelavri's Avatar
Hi...I eliminated the Knock...
but see how the maps are now...I tried to remove the jumps in numbers...Any inputs? Also the log is provided...
File Type: jpg 09022009 Knock elimination-fuel Update 4.jpg (86.9 KB, 0 views)
File Type: jpg 09022009 Knock elimination-ignition Update 4.jpg (87.8 KB, 0 views)
File Type: jpg 09022009 Knock elimination-mivec Update 4.jpg (86.9 KB, 0 views)
__________________
Offline
Tags
engine, knock, lower, mivec, sum, tuning
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
