Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Engine Management & Tuning
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 10, 2009, 02:37 PM   #1
Personal Sales Rating: (1)
2003 Mitsubishi Lancer Evolution
[GBU]Moon's Avatar
Drives: 2003 Lancer EVO VIII
Send a message via AIM to [GBU]Moon
Sputter Sputter (video incl.)
I recently had a huge exhaust leak in my downpipe, and when my car would get over 10 lbs of boost, it would fart and sputter. I had the leak fixed and my car made it up to 15 lbs of boost before the farting and sputtering.
video:
http://www.fire-pixel.com/temp/sputter.mov
One thing that has happened that may be to blame is my Idle Air Control Valve stopped working properly so my car wouldn't idle. Once the temp was up it would idle extremely low (400-500rpm) and usually conk-out. to mask the problem until my new ICV shows up, i turned the screw on the throttle body out ~3 turns. now the idle is good when the car is warm and i'm waiting on my new ICV before i turn it back.
my question is, is changing the screw setting probably related to the sputtering and farting over 15 lbs of boost? my air/fuel ratio is right at around 15.2 while idling. i'll know once my new ICV is installed, but for right now i'm just looking for piece of mind.
Thanks!
__________________
Here is my MySpace
Partner: Fire Pixel Marketing
Member: EDI Projektz Car Club
Affiliated: Beyond Redline Performance
Offline
Old Mar 13, 2009, 11:15 AM   #2
[GBU]Moon's Avatar
installing new IAC Valve this weekend, i'll post the result
__________________
Here is my MySpace
Offline
Old Mar 16, 2009, 10:19 AM   #3
[GBU]Moon's Avatar
still sputtering, boost leak?
__________________
Here is my MySpace
Offline
Old Mar 16, 2009, 10:21 AM   #4
Personal Sales Rating: (29)
DaWorstPlaya's Avatar
Drives: Thats MR to U!
Did you mess with your TPS sensor? Eg: take it out of the throttle body?
__________________
GTWorx-www.GTWorx.com
Jestrtuning-www.jestrtuning.com
Better slow in fast out, than fast in dead out!
Forza 3 Discussion: Click here
Forza 3 Racing League:Click here
FS: Misc suspension bushings: Click here
Offline
Old Mar 16, 2009, 10:21 AM   #5
Personal Sales Rating: (14)
idriveanevo's Avatar
Drives: 2003 evolution
try changing your plugs? had the same issue and it was sparkplugs
Offline
Old Mar 16, 2009, 10:43 AM   #6
[GBU]Moon's Avatar
Quote:
yes, had a misfire in cyl 1 and that was taken out during the trouble shooting.
__________________
Here is my MySpace
Offline
Old Mar 16, 2009, 04:01 PM   #7
Quote:
Did you mark the TPS sensor when you took it out and put it back together the same way? The TPS sensor is calibrated to the throttlebody and changes values when it is moved left or right during mounting. If it isn't put back the same way, it will misread and give incorrect values to the ECU.
__________________
Offline
Old Mar 17, 2009, 12:37 AM   #8
[GBU]Moon's Avatar
my mistake, after looking more closely at what a "TPS Sensor" is, we didn't take that off.
__________________
Here is my MySpace
Offline
Old Mar 17, 2009, 09:36 AM   #9
Then it might be your spark plugs, try changing those (as idriveanevo suggested). Make sure you have them gapped correctly.
__________________
Offline
Old Mar 17, 2009, 11:22 AM   #10
[GBU]Moon's Avatar
will do, i'll post my results, thanks.
__________________
Here is my MySpace
Offline
Old Mar 24, 2009, 07:46 PM   #11
[GBU]Moon's Avatar
bad plug was the issue! I was using some Autolite XPs from Advanced Auto for one month. i installed them while i was troubleshooting a different issue, but now i threw some $2.00 NGKs in there and all is good! thanks for your posts!
__________________
Here is my MySpace
Offline
Old Mar 24, 2009, 08:08 PM   #12
No prob, glad it helped
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
