Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Engine Management & Tuning
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Feb 9, 2009, 08:57 PM   #1
Personal Sales Rating: (1)
2004 Mitsubishi Lancer Evolution
Evo8=Life's Avatar
Drives: 2004 Evo 8
LC-1 Troubles
I having troubles with my LC-1 and XD-16. The wideband is show o2 then switch to 20.9 after it does the sensor warm up, I just tried replacing the o2 sensor and got the same sh!t, I did what it said to do on there quick start guide. Any help would be greatly appreciated.
(I do not have the software or the cables to check for a code, I purchased the car with out it. May get the software and cables this week)
Thanks
Offline
Old Feb 20, 2009, 10:42 AM   #2
Personal Sales Rating: (22)
Standing Z's Avatar
Drives: 2006 EVO SE, 1984 Camaro
LC-1s have some major problems with some of their units. It seems like they either work right or the dont half the time. We had one on our school's formula race car and the damn thing never gave an accurate reading. After sending it back and got a new one, it did the same thing. We just got a different wideband and it worked perfectly, I'd avoid LC-1s
Offline
Old Feb 20, 2009, 05:04 PM   #3
Evo8=Life's Avatar
Drives: 2004 Evo 8
I found a grounding problem in the unit. I going thru the ground on the whole system
Offline
Old Mar 4, 2009, 05:43 AM   #4
Personal Sales Rating: (7)
2003 Mitsubishi Lancer Evolution
Evo8Emperor's Avatar
Drives: 03 Evo 8, 05 Kawasaki 636RR, 08 Kawasaki KFX450R
Send a message via AIM to Evo8Emperor
Hmmm your problem sounds like my problem I think. Just recently I went to start up the car and leave and noticed my wideband was taking forever to warm up. After it finally warmed up it would just read 22.9 (maxed out) then go down to 7 and just jump back in between.
I havent had a problem with my lc-1 at all and now this. Im going to try and recalibrate and if that dont work hopefully find a bad ground.
__________________
CBRD Slim Rad~Ported Evo 9 16g~Labonte's ISG-S3~BR S.S. o2~HKS Ann. Ed. Ex~3" TP~HKS 272's~PPI PEM~PTE 780's~TTP Spec BBL~SuperTech Duals~4" TurboXS FM~BR LICP~TTR UICP~Sychronic BPV~GM BCS~ACT HDSS~ACT Pro-Lite Flywheel~S.S. -6AN Lines~AMS Full S.S. Clutch Line~Walbro 255~BLOX FMM~Carbon Trunk Lid~JDM Map~Self-Tuned-30psi
::My car on car domain here:: along with Evo/DSM Shoot Out and Some pics many more to come.
Offline
Old Mar 4, 2009, 06:01 AM   #5
Personal Sales Rating: (9)
Chemwarrior's Avatar
Drives: 2010 Bathurst Black Genesis Coupe V6 Track
I've had this problem before and all you have to do is recalibrate it.
Offline
Old Mar 4, 2009, 07:33 AM   #6
Ahh nice hopefully your right. The sensor isnt old at all so shouldnt be nothing wrong with it. Hasnt seen anything but 93. I was going say I have been very happy with my lc-1 and now this.
They were having problems but that was there producer in china. They have since came back to the U.S. and hopefully all should be good.
__________________
Offline
Old Mar 4, 2009, 09:57 AM   #7
I understand your concern but honestly it sounds like it needs recalibrating. Unfortunately you have to recalibrate these things every once in a while. I personally think it is a good thing though. It keeps your measurements more precise. My black calibration wire would accidently touch metal while I was driving and through off the readings. Stupid me didn't tape the end. I have since corrected the problem and have zero issues with it.
Offline
Old Mar 4, 2009, 10:25 AM   #8
Yah I wired in the recalibration button when i did my install. I just dont feel like going take the sensor out of the exhaust outside. Ill be at school later tonight and Im going to do it then.
__________________
Offline
Old Mar 5, 2009, 10:14 AM   #9
You can actually recalibrate while you are on the move, but your best bet is to remove the sensor. It only takes about five minutes. Just jack up the passenger side of the car, remove the sensor, let it heat up, recalibrate, reinstall sensor and you are done. As far as doing it on the move, find a length of road that you can coast on, put it in fifth gear, let off the gas, recalibrate, and you are done.
Offline
Old Mar 8, 2009, 09:52 AM   #10
Personal Sales Rating: (14)
jjm4life's Avatar
Drives: APAT tuned 8
Send a message via AIM to jjm4life
im having an issue with my lc-1 too. the gauge is functioning properly, but the output line doesnt send a signal. evoscan cant find it. we tested it back to back with another lc1 and his worked. any ideas?
__________________
cbrd bbk
Peteyturbo Tuned
krazyhousecustoms.com
infraction points:7
Offline
Old Mar 8, 2009, 10:19 AM   #11
Personal Sales Rating: (32)
SwiftEVO's Avatar
Quote:
Mine did the exact same thing. I had to send my lc1 in and they sent me a new one. BAM works perfect now.
--Josh
__________________
- 04 Evo 08 - Meth Addict -
- Built 2.4 - ETS Twin Scroll GT4088r - AEM EMS -
Offline
Old Mar 8, 2009, 10:43 AM   #12
jjm4life's Avatar
Quote:
--Josh
damn for real?cause this is already my second unit. the last one wouldnt calibrate.
__________________
cbrd bbk
Peteyturbo Tuned
infraction points:7
Offline
Old Mar 9, 2009, 11:27 AM   #13
Personal Sales Rating: (5)
DOUGLAS's Avatar
Drives: 2003 Evo VIII...........
Mine worked fine for the first few months I had the car and every so often it bagan to throw an e-4 and other times it would read......now it wont read at all and all I get is a e-4.....any ideas on what to try to fix this?.....I dont have enough money right now to replace the sensor.....
__________________
RIP Joshua French (2SloEvo)
2003 BBY Evolution VIII
Offline
Old Mar 9, 2009, 11:32 AM   #14
SwiftEVO's Avatar
Sensor is only like $65 from napa.
--Josh
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
