Dec 1, 2008, 07:54 PM
Personal Sales Rating: ( 11)
Drives: 2006 Evo IX GSR/SSL
two mods = lean afr
I added a o2 dump and a perrin intake and I think my afr has leaned out to damn near 11.8-12.0
I was running low 11's high 10's.
I've been staying out of the gas.. I noticed this pretty much right after the intake install. Didn't notice to much afr change with the dump.
I turned boost down, but still kind of lean to me. I'm kind of scared to even log a pull.
Can this perrin intake make that much difference in afr? Previously I had stock intake maf pipe with apexi filter.
Offline
Dec 1, 2008, 08:00 PM
Personal Sales Rating: ( 7)
Drives: 2004 mitsubishi evolution RS
this kind of scares me, because i used to run the same set up as you except hks filter, and i just put on the hks pipe and havent had a wideband hooked up since then, and when i started taking my car apart when i put it in the garage, i kind of thought i had white smoke coming out of the exhaust, but i talked myself into it being fog from the cold
__________________
Quote:
Originally Posted by Rin Tin Tin
WTH? Serious? At age 15, i had problems handling my penor. I wouldn't have ever been able to handle the raw power of an Evo. I would always try to be hiding it when walking around: putting books in front, walking sideways, trying to draw attention away from my crotch. And when they do see it, they look at me and say, "What the hell, Tin?" and I would respond, "I don't know man! It has a mind of its own.".
Offline
Dec 19, 2008, 04:45 PM
Personal Sales Rating: ( 8)
Drives: 91 Eclipse, 92 talon, 91gvr4, 05 evo
the intake will make a big difference. Put the stock one. Or get the flashed.
Offline
Dec 23, 2008, 01:51 PM
Personal Sales Rating: ( 1)
Drives: Evo Vi Rs2
11.8 -12.0 sounds great just adjust timing to suit and you should be good to go. This is the ratio we usually tune for
Offline
Dec 23, 2008, 03:27 PM
Silver Sponsor
Personal Sales Rating: ( 6)
Drives: Drag Evo 8, DG built Evo X, 05 Cadillac Escalade, 07 Ninja zx6r
Quote:
I do not think so. Especially if he/she can not tune the car. Is this on 93 Octane? On C-16 this would be fine with the proper tuning, but i would never recommend that kind of a/f to anyone running pump gas alone. You might as well tell him to drain the oil out of the car and floor it.
__________________
DG Motors
In-house DYNO DYNAMICS
Tuning specials for evo 8's 9's and X's
Ecuflash Specialists/Aem Certified Tuners
WWW.DGMotorsNY.COM
1-631-957-8464 -Ask for Pete
Internet Flash Packages!
Tuner Of Worlds Highest Whp "Stock Ecu"Stock Block Evo X 629whp!
Tuner Of Worlds Highest Whp Evo X On 93 Octane 629whp!
DG Drag Evo 8: 9.06 @ 164mph!
DG Drag Evo 8 In Action: http://www.youtube.com/watch?v=ASZIiklA0Ow
Offline
Dec 23, 2008, 03:31 PM
Silver Sponsor
Get the tune fixed up...A little fuel/timing here and there and you are good to go. Do not listen to anyone. That is a lean air fuel for pump gas, anyone will tell you that.
PM me and i will get you where you need to be.
__________________
DG Motors
WWW.DGMotorsNY.COM
Offline
Dec 23, 2008, 04:12 PM
Personal Sales Rating: ( 20)
Drives: E-85
The filter made it leaner! The 02 dump does not change a/f. But evo8604 is right you need to get a tune!!
__________________
E85 Guru and stock ecu Guru!!!
Offline
Dec 23, 2008, 05:57 PM
Personal Sales Rating: ( 9)
Drives: RX7 GSL-SE turbo, 05 MR Graphite Gray,02 GSXR-750, 88 supra turbo
What are your boost levels??
Offline
Jan 3, 2009, 05:41 PM
Drives: GG 8
since stock is so rich, it wont matter with the intake no?
you still need tune
__________________
338whp 350lb.ft. @ 23psi
new setup RED installed awaiting parts for tune, #'s 2 come soon
Offline
Jan 4, 2009, 01:26 AM
Personal Sales Rating: ( 0)
Drives: couier ute evo x RS x3 2 x evo 8 rs
they will cop 12.5 afr @ 1.5 bar of boost all day long so long as they don't detonate . cheers from oz
__________________
evo x rs 4.5 hr's to do engine swap getting quicker
Offline
Jan 9, 2009, 05:30 PM
2003 Mitsubishi Lancer Evolution
Drives: '03 Evo 8, '04 WRX, 89 Honda Civic
I've run that lean before but I also tuned all the knock completely out of the map via timing. I honestly wouldn't recommend it for a daily driven car though, as variables from things like air temperature or even the quality of gas at the pump can take something that's on the edge of safe to very dangerous in a matter of seconds. Richer is safer, and while you're at it you might consider adjusting your throttle crossover points too, as factory settings seem to keep things lean at the crossover point up until a certain throttle percentage regardless of boost pressure.
__________________
10+ years of tuning and boost drove me to drink
EcuFlash tuned by me @ 28psi with Speed Density conversion, no spike w/open dump mod on 93oct and no knock with all the bolt-on's...Holset/top mount/2.3 coming soon...
Offline
Jan 14, 2009, 09:01 PM
Drives: 03 evo 8/ 06 R6
what gear are you getting those afrs? If its 3rd then you are still safe on 93 at your elevation. 4th will richen up to just about 11.3. I have had mine on 91 pump piss @ 12.0 in 3rd and 22psi with no problems. If you are still uncertain use wideband and get 3rd gear afrs to 11.6-11.5 4th will rechen up to just about 11.1-10.9. Now this is what I have seen on my car and many others.
__________________
The measure of a good car is how well it reacts in all road situations, NOT just how fast it goes straight.
Offline
Jan 15, 2009, 03:19 PM
Personal Sales Rating: ( 13)
Drives: an evo, duh...
tune...
__________________
"... I still don't know any better, I just don't have a mushroom haircut..."
WWW.IVEYTUNE.COM
AMSautowerks
Offline
Jul 7, 2009, 08:54 AM
Personal Sales Rating: ( 14)
Drives: 2003 RR Evo
I'd be happy it leaned out, that means your mods actually made the motor flow more air. Just get a re-tune and you should net some power.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
