Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Engine Management & Tuning
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 2, 2007, 02:53 PM   #1
Personal Sales Rating: (4)
Drives: RR Evo IX SSL
sensor signal conversion, any electronics gurus?
GM makes a fuel composition sensor that sits along the fuel line and detects the ethanol content of the fuel. It outputs a 5V square wave at 50-150Hz relative to the ethanol content. 50Hz = 0%, 150Hz = 100%, etc. The AEM EMS has 0-5V inputs and a user definable fuel trim table. It would be pretty easy to have the EMS use the input from the sensor to automatically adjust fuel for E70-E85 if the sensor output could be converted to 0-5V. Then you could safely buy E85 out of the pump all year long making great power without worrying about your AFR going rich or lean on different blends.
Anyone know a shop that could make a converter? Would obviously have inputs for 12V & signal in, and outputs for signal out and ground.
Offline
Old Apr 3, 2007, 01:03 PM   #2
Well I found a huge step in the right direction.. they actually make frequency to voltage converters. Duh right?
http://pdf1.alldatasheet.com/datashe...SC/LM2907.html
http://pdf1.alldatasheet.com/datashe...A/TA8029S.html
Getting closer..
Offline
Old Apr 3, 2007, 02:55 PM   #3
Silver Sponsor
Personal Sales Rating: (40)
2003 Mitsubishi Lancer Evolution
My Garage
KevinD's Avatar
Drives: '04 evo8 daily driver, '03 evo8 time attack car, 08 outlander
Send a message via AIM to KevinD
yup frequency to voltage converter and then likely some voltage bias to make the 50hz = 0v. there are circuit diagrams all over the interweb for them. and when i do custom one off jobs like that, i always just request a "sample" chip and its free
edit* i'm not a electrical engineer though... and only a few of the circuits i make actually work. i've worked with the frequency to voltage ICs though in both traction control system i made, and a LED tachometer.
__________________
EVOLUTION DYNAMICS LLC
Tuning, Custom Fabrication, and installs in the DFW area.
www.evodynamics.com
email: evokevin@gmail.com
Phone + Text messages: 817-776-2170
Kelford, mil.spec, ACT, Aquamist, FIC, ShepTrans, Zeitronix, + many others
Evo Dynamics Unlimited Time Attack Build
3-Port PnP Boost controllers for Evo 8/9/X and RA
Join us on FaceBook!
Offline
Old Apr 3, 2007, 03:21 PM   #4
Personal Sales Rating: (5)
MalibuJack's Avatar
Drives: 03 Evolution VIII, 03 G35 6MT Coupe, 78 Malibu, 05 Dodge Durango
Send a message via AIM to MalibuJack Send a message via Yahoo to MalibuJack
http://www.aktivematrix.com/forum/viewtopic.php?t=166
This might be of interest to you.. Its a discussion on how to integrate the GM Fuel composition sensor with the mitsubishi ECU..
I've been researching this for quite some time.
__________________
MitsuLogger V2.0 beta 1a - a Free MUT-II logger using the Tactrix Cable - Supported widebands: AEM, Zeitronix ZT-2, TurboXS UTEC and Tuner.. Download from http://www.aktivematrix.com
Offline
Old Apr 3, 2007, 03:23 PM   #5
MalibuJack's Avatar
BTW, the GM Fuel composition sensor outputs a frequency for Ethanol concentration and also pulsewidth for fuel temp.. Just some additional information for you to chew on.
__________________
Offline
Old Apr 3, 2007, 05:03 PM   #6
cool, I'll join you over there. great to hear people are working on making this happen with the stock ecu, I was just going to dish out the cash for an AEM.. now I'll hold off on that
Offline
Old Oct 16, 2007, 09:55 PM   #7
Drives: Evo VIII, 330i Dinan3 ESS
A microcontroller would be your best bet. It would give you the ability to write a simple program to achieve this goal. The company that set my car up does a lot of electronics engineering. I can run it by then and see what they think. If your willing to spend the money I’m sure the will develop it for you.
Offline
Old Oct 16, 2007, 10:00 PM   #8
Thanks, I already found a shop to design and create the components, have had it in the car for a while as just a gauge - works great
__________________
rockin the stock turbo
Offline
Old Oct 16, 2007, 11:38 PM   #9
Offline
Old Nov 1, 2007, 11:53 AM   #10
Personal Sales Rating: (0)
lemmonhead's Avatar
Drives: evo 9, 4g Eclipse
huh didn't know those content sensors exist. As an electrical engineer I can whipe up a circuit in lickady split. This would make a sweet meth/water injection redundency fail safe system... fun fun
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
