Nov 1, 2006, 05:54 PM
Personal Sales Rating: ( 0)
Drives: EVO 6 TME GSR
Several doubts about evo VI TME
Hi guys, i thought to post in here so i can get expert advises.
Right now i own an EVO VI TME, my actual setup is GT35R turbo, 750cc injectors, walbro FP, Huge FMIC, DNP exhaust manifold, 3.5" race downpipe and all the supporting mods.
As i still have the stock ECU, i had to install a fuel cut defencer to the MAF, boost cut in this model is MAF reading based, so i can boost more than 1.2 BAR, but fuel compensation is limited to about 480 WHP. Thats how much i'm pushing right now. (G-Tech Pro RR measured).
Well, here's the deal, i had some missfire at 1.3 bar, so gapped plugs to 0.65mm, missfire was solved and was abble to boost 1.7 bar. I know it's not the REAL solution, i know i need an ignition amplifier and i was looking at the HKS DLI2 amplifier, vendors says it for the EVO VIII +, and i need to know if it fits the EVO VI wiring. Plug n' Play would be ideal, but if a wiring change is needed, theres no problem, i can do it, but i need to know if i can use it.
That's my first doubt, my second one is that i need any kind of engine management, but here i really want a plug n play option.
Unfortunately there are no specific EVO VI parts for sale in USA, so i have to addapt to VII + parts.
Guys, i would really aprettiate your help, it's my only information source and i know there are plenty guys in here that know al lot about EVOs.
I'll be waiting for some answeres.
Thanks al lot.
Offline
Nov 6, 2006, 05:19 PM
Personal Sales Rating: ( 1)
Drives: Black IX
Good luck is all I can say. With the JDM ECU our USDM spec parts may not like eachother too well. Ive never worked on anyhting below a VII but I wish I could help.
__________________
Grab the bull by the balls....uh wait the horns
Offline
Nov 6, 2006, 07:37 PM
Personal Sales Rating: ( 5)
Drives: 03 E8 -- Previously 1st USA AWD 2Door Mirage
Tuning a 4-6 Here in the US is a problem, I've tried working with an E8-Ecu numerous times, and from what i've read oversea's a simple pin switch at the ecu solves the problem, but not here with the US spec E8 Ecu's, the immoblizer just gets in the way...Anyway, my goal was to just flash an E8 Ecu and run it...i realise that wont work for your application but my point is, that with this simple pin swap, which involves the main fuel relay being swaped with AC on an E7-9 car, you should be able to get the car running with an AEM, if that appeals to you, with reguards to the HKS Ignition amplifier...it will work just fine...the coil-pack set up is identical for all mitsubishi 4-cylinder cars that i've worked with, Mirage 1.8, Lancer 2.0, Evo...etc etc etc...same coils, same connectors, same pin layout...yada yada
-Adam
__________________
http://AdamJ39.onlineshowoff.com
Offline
Nov 7, 2006, 02:39 AM
Personal Sales Rating: ( 6)
Drives: Tarmac Black 05 GSR SSL
another possible solution is to check the UK forums, and ask them for parts as well. it's also so much easier to communicate w/ them as well.
Offline
Nov 10, 2006, 06:52 PM
Personal Sales Rating: ( 2)
Drives: Lancer Evolution SST
the HKS Dli version is swappable .. I've the harness for the older VI engines .. and the difference is simply a small plastic plug in the center of the adaptor .. I think it's a guide channel .. for the VII/VIII I have to remove mine to fit .. but it fits with no problems .. probably you can do the reverse ..
I believe the flash can be used on the VI TME .. just need to verify it
Good luck .. the TME is one of the best models of the Evos (lightest and most responsive of the series)
BTW your OE turbo is different from the rest of the mainstream and the same as mine
TD05HRA- 15GK2-10.5T
Offline
Nov 10, 2006, 07:02 PM
Drives: 04 white EVO,93 awd TSi
Quote:
-Adam
Dude ur car is sick. I saw you in it and talked to you at 7580 before it closed(I have a 6bolt green DSM ran mid 11s) . Do u have any pics of it on here? Also what are u using in ur car now? If u go to a US ECU wont u also lose ur anti lag?
__________________
Buschur Built: JE/Crower,stg 3 head, BF272s, 1K PTEs double pumper, tubular 82mm HTA with a.63 housing, newly installed BR Race Core.
480whp unfiltered BR MD Dyno, 544 whp Dynojet STD correction, 3rd gear, 31 psi, Stock ECU and MAF. Straight Shell 93 pump.
Currently running 94170015 V5.10 with SD Patch(Omni 4BAR) 531 whp 406 tq 4th gear, 519 386 3rd, CBRDs MD 33 psi straight pump Shell 93 Self Tuned
Offline
Jul 9, 2007, 11:41 PM
Personal Sales Rating: ( 8)
Drives: Evolution
my friend have a evo vi with AEM EMS so u can use tha ecu if u want
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
