Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Engine Management & Tuning
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 30, 2006, 11:57 AM   #1
Personal Sales Rating: (5)
Smogrunner's Avatar
Drives: 03 Evo VIII bought new, orignal owner
Game over for AEM EMS?
I’ll preface this by saying that if you want to run over 600whp (dynojet), a stand alone is, IMHO, still the way go. However, it seems to me that the vast majority of folks getting the AEM simply don’t need it, and I challenge you to prove otherwise!
Fact: I make 585whp/527wtq at 31psi on the stock ECU, stock MAF, stock ignition, stock head with hks 272s, stock intake manifold, stock throttle body, and a very simple fuel system on only 880cc injectors. That is on a regular Vishnu 3” inch exhaust with 24” resonator added and a magnaflow muffler. No gimmicks, no tricks. My total cost for engine management is $89 for the Tactrix cable for ECUFlash.
Fact: The fastest regularly road raced Evo in the states is the Muellerized Evo driven by Kent Jordan. It uses the stock ECU with just a SAFC (according to the John M.)
Fact: Evoscan logging software for ECUFlash is now available for only $15, making AEM’s logging capabilities less of an advantage.
Fact: The AEM is still not available for the Evo 9.
Cost:
AEM with everything needed to run it: $2400
Many also buy ignition amps: $500
AEM injector drivers to (apparently) make up for less efficient driver in AEM box: $325
Total if you go this route: ~$3225 + installation if you don’t know how to do it yourself.
Stock systems: FREE. They come with your car. Also, tuning with this system is widely available and less complicated and trouble free than AEM Tuning.
Question: Why introduce complicated and expensive new systems that only present more possible areas for failure to your Evo when they are not needed?
Answer: to send vendors' kids to college.
__________________
584whp & 527wtq -- Stock ECU
3rd place 2008 Sport Compact Car's Ultimate Street Car Challenge
1st place Import Tuner Evo v Sti Shootout 2007 fastest lap & five lap challenge
2nd place Redline Time Attack mod class@Cal Speedway 2007
Tuned & Built by Tuning Tech -- AMS 2.3 stroker, Tuning Tech HTA35R Turbo kit -- Stock ECU -- stock head with HKS 272s -- AMS VSR intake manifold & MilSpec 65mm throttle body -- Gerrard Tuned Ohlin's Suspension -- Exedy Triple Carbon -- Nisei Comp Intercooler
Offline
Old Jul 30, 2006, 12:03 PM   #2
Personal Sales Rating: (4)
razorlab's Avatar
Drives: a laptop connected to your ECU.
I believe Kent/John used to use SAFC but now use a standalone with full datalogging and diagnostic capabilities. However I could be wrong and they might just run datalogging.
__________________
Bryan - 05 MR - E85 and FPgreen powered
E85 Army
Offline
Old Jul 30, 2006, 12:07 PM   #3
Personal Sales Rating: (2)
R/TErnie's Avatar
Drives: TB Evo IX
Send a message via AIM to R/TErnie
have you ever used an AEM EMS before? or for that matter something comprable...IE Hydra? and your prices on the AEM are a weee bit high...obviously because you're bashing on the aem unit. Maybe this outburst came because you feel you're not getting enough attention because you made 500+whp on a stock ecu. Fact of the matter is no one cares.
I didn't know you could do additional pmw's with a stock ecu? control nitrous solenoids, WI solenoids, 3 step, additional maps for switching between pump and race gas, does the stock ecu have a target and self learn function for CL operation? The list goes on and on.
If your tuner cant tune an AEM unit...I dont think he should be tuning your car.
__________________
11.1@129mph - 521whp via Dynojet
Offline
Old Jul 30, 2006, 12:09 PM   #4
Personal Sales Rating: (3)
NoTec's Avatar
Drives: like the Slowskys!!!
Send a message via AIM to NoTec
For a NON race car, carefully set up with a big turbo and some type of protection or safety net helping the maf, it would seem Smoggie is correct. But, if you have a hardcore time attack vehicle (Buscher, AMS, GSC, Meuller, Robi), I would think that some form of aftermarket management (piggyback or stand alone) would be a smart investment and a great tool.
__________________
Not racing on public roads = my flawless driving record!!
Keep it safe!!
Engine and Exhaust components:
http://forums.evolutionm.net/sale-en...ml#post7046697
Desiring a 996+ 911 turbo or D16rr.... can't wait for 2010!!!
Ducati Lover!
Offline
Old Jul 30, 2006, 12:17 PM   #5
Personal Sales Rating: (1)
Drives: 02/06ram35004x4diesel 03evo8
what are the limits on the maf?
Offline
Old Jul 30, 2006, 12:17 PM   #6
R/TErnie's Avatar
Drives: TB Evo IX
can you switch to different saved maps? can you save maps? minimum pulse width? Does this just alter open loop maps? or can you make adjustments to closed loop maps? STT LTT adjustment? Can you control the IAC duty cycle?
__________________
Offline
Old Jul 30, 2006, 12:19 PM   #7
R/TErnie's Avatar
Drives: TB Evo IX
how about switching over to a MAP only unit? issues with MAF sensors? can you rescale the MAF sensor signal with the stock ecu? And how bad does that hurt your resolution of your maps? Excessive rich/ lean spots in the mid throttle section because of extreme MAF scaling? Can the new datalogging software datalog wideband readings? And can your stock ecu read a wideband to map to makes its CL adjustments?
__________________
Offline
Old Jul 30, 2006, 12:20 PM   #8
Silver Sponsor
Personal Sales Rating: (13)
Sean@Iveytune's Avatar
Drives: Ford F150HD Supercharged, R35 GTR 2010, 9 sec Fullweight evo8.
stock ecu map resolution for rpm stops at 7500.
stock ecu resolution for ignition timing and such over a certain load which can maxed on a stock turbo, doesn't allow you to diffrentiate between 30psi and 35psi. No resolution. I am sure it can make power as I have done the same but in no way is that the optimum way to do things.
Anything over 450 wheel HP and anything over a gt3076 turbo and higher boost the AEM or some other standalone is the way to go.
Sean
__________________
WWW.IVEYTUNE.COM
DYNOJET AWD ON PREMISES!!!
2003 EVO8 9.17@159.6 MPH 3055 lb NO NITROUS! Full street!
1992 Talon AWD 9.41@151MPH (Oct 2005) Full exhaust, full glass 3122lb
1993.5 Supra 9.6@148 (Stock Auto, drag radials) 9.73@153mph 6 Speed!
Brandon's 1993.5 Supra 8.78@157.17 Slicks and BL400
HKS PRO DEALER!
Cobb Protuner "Live Data!"
Ecutek dealer, reflashes available for all yrs of evos.
Factory Trained Tuner FCON V-PRO, AEM EMS
, Haltech, Motec, Autronic.
Offline
Old Jul 30, 2006, 12:39 PM   #9
Smogrunner's Avatar
Sean
Sean,
I respect your opinion more than almost anyone on this forum. However, I have repeatedly seen simple reflashed 35Rs make perfectly smooth power up to 540whp at around 8000rpms with stable AFRs on the stock block and 30Rs make 500 on the stock bottom end with reflashes.
I understand resolution issues at high boost and high rpms, but for whatever reason, I don't see these issues actually manifesting themselves in real life.
My point is this: Get the AEM only after it is apparent by actual observation that you have gone beyond the stock systems. I think that several of us have now proven that the AEM isn't needed until much later in the modification process than was previously reported.
So, assuming that money is limited:
Why not get a rebuilt Shepard tranny AND a Quaiffe LSD for the same money.
-or-
Get a brand new Buschur Turbo Kit for the same money
-or-
Get get a set of Muellerized coilovers (I'd say Vishnu Ohlins but they cost more than an AEM)
-or-
Get a set of very nice wheels with race rubber
-or- etc, etc
__________________
Offline
Old Jul 30, 2006, 12:45 PM   #10
Personal Sales Rating: (37)
Blue Evo 8's Avatar
Drives: a ~500 AWHP 05 LY EVO 8 like a grandma
Send a message via AIM to Blue Evo 8 Send a message via Yahoo to Blue Evo 8
Quote:
Originally Posted by Smogrunner
Sean,
-or-
-or-
-or-
-or- etc, etc
or a case of beer
or that plasma tv you've always wanted
or take that vacation you've always wanted to go on
Offline
Old Jul 30, 2006, 12:47 PM   #11
Quote:
Originally Posted by Blue Evo 8
or a case of beer
Offline
Old Jul 30, 2006, 12:48 PM   #12
R/TErnie's Avatar
Drives: TB Evo IX
so does that mean that you don't have any information?... or are you're just singing la-la-la-la while you shake your head side to side and tell yourself that the voices in your head aren't real?
__________________
Offline
Old Jul 30, 2006, 12:53 PM   #13
4-BNGR's Avatar
Drives: 03 Evo GSR 6.5 TME conversion
Magic Bullet Theory
__________________
Tomei/Buddy Club 264/272, JDM RS 6.5 TME turbo, RMR intake, Buschur MBC, SSA exhaust manifold, Buschur 2.5" DP, UR 2.5" HFC, Buschur 2.5" Muffler Delete, B&M Short Shifter, Fighters LICP, JDM MR BOV, VDO Boost Guage, SS Clutch Line, Hotchkis Springs, Walbro FP
"It stinks like sex in here..."
Offline
Old Jul 30, 2006, 12:56 PM   #14
Personal Sales Rating: (9)
mchuang's Avatar
Drives: 2000 honda si turbo..sold 03' Rally Red BPU+
ECU FLASH is a great program, and does the job just fine. But I agree with Sean after about 500hp I would opt for a full standalone. I mean AEM has too many usable features other than the ones mentioned, it also traces what load cell you are in and also lets you tune on the fly, big plus in my book especially when tuning for drivability. Also you keep stating that your motor is basically stock, but man you have a 2.3 stroker , so your motor is far from stock IMO. I not knocking on you love your accomplishments, but the bottom end is built.
__________________
Quote:
Originally Posted by DynoFlash
Anyone buying a $30,000 car is a fool if they dont have it custom tuned by a good tuner
www.houston-imports.com
Offline
Old Jul 30, 2006, 01:14 PM   #15
Silver Sponsor
Any 2.0 with a larger turbo that needs to go over 8000RPM, a better solution will be needed.
If you max the air sensor at 26psi or so on a certain turbo, what do you do for load exceeding that? Do you just run it on the last load column? Now when you optimize it for that higher boost, how do you handle it when you lower the boost. For all intents and purpose the ecu is seeing the same load at different boost levels once you max out the air sensor, not acceptable for me, but to each his own.
What about the ability to get proper driveability with the larger cams now available for the evo.
Nitrous control?
Antilag rev limiting for drag launch?
Various inputs and outputs for auxillary functions.
There is so much more you are really comparing apples to oranges.
I am not trying to strongarm anyone into seeing it my way but I tell you, the stock ecu is great up to a certain point but there are limitations, which in some cases can be worked around.
I have a dyno sheet sitting here with a stock 2.0 with HKS cams, and head studs.
It made 593 WHP/480 FTLB STOCK BOTTOM END! (c16 and meth inj)
You need to have control to allow the engines to live at this level with soft internals.
Sean
__________________
WWW.IVEYTUNE.COM
HKS PRO DEALER!
Offline
Tags
550, 950, airflow, al, antilag, blaha, c16, cc, clutch, dsm, forum, injectors, mass, mustang, recalibrating, sensor, subaru, switch
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
