no more cam lope after manifold swap
Old Jul 13, 2014, 12:06 PM
stunt2's Avatar
Question no more cam lope after manifold swap
I've changed stock exhaust manifold to custom tubular one, along with turbo and intake pipe and cam lope is comlpetely gone after it
haven't changed anything in the rom, idle is still ~950 rpm, load 30 and timing fluctuates between 5-10
I have S2's and loved the sound of them. how can I get it back ?
Old Jul 13, 2014, 08:48 PM
3SgteGuru's Avatar
You like the Rough idle?
Advance MIVEC timing in Idle Cells by 5* increments itll probably lope at around 10-15
Old Jul 13, 2014, 09:40 PM
stunt2's Avatar
it's not a IX, so no mivec here
Old Jul 16, 2014, 01:52 PM
3SgteGuru's Avatar
Pull ignition timing in idle areas, itll lope more. But youre gonna get higher EGTs.
Old Jul 17, 2014, 06:44 AM
stunt2's Avatar
I'm interested as well, what caused it
manifold swap ?
Old Jul 17, 2014, 09:02 PM
3SgteGuru's Avatar
You changed some stuff, that changed the VE of your motor, with that your idle are VE might have improved. Basically your car is running better at idle. I spend countless hours getting rid of lope for people you want more... all i can suggest is make it run crappy at idle. Pull some ignition timing bend a valve take a spark plug out all these things will give you lope. But they arent gonna make you faster.
Old Jul 18, 2014, 08:05 AM
Ev0ikon's Avatar
Some people seem to get stuck on old-school/muscle car mentality that wobbly idle means more powar!
Tmosser
Sep 20, 2012 01:46 PM
steven121
Aug 23, 2012 07:58 AM
svt_lightning01
Nov 29, 2011 01:59 AM
awdordie
Mar 10, 2011 10:14 AM
j14mp
Jan 23, 2009 10:51 AM
Quick Reply: no more cam lope after manifold swap
