Openport 2.0 logging via SD card
There really isn't one. Search for "logcfg" and you'll find a few like this one:
https://www.evolutionm.net/forums/ec...ogcfg-txt.html
Put SDCard into Openport
Plug Openport into Laptop
Format SDCard to Fat32
Create and define a logcfg file and place it on the root of the SD Card
Assuming there is no trigger, just install openport on car and it'll start doing its thing. Check out one of the examples in the ecuflash folder and it should be pretty self explanatory. If you're having issues logging specific items, yet you can log them in Evoscan.. then you most likely have it incorrectly defined in the logcfg file.
Can you explain to me what does the "paramid" line is, and where I can find that information in ecuflash or evoscan?
OK I think I almost have it figured out....If I want to log my 4 bar omni sensor, how do I make the line look in the logfile?
The eval is 0.2369*x-14.7
And the request ID is 38
Shouldn't matter with ECUFlash version as long as you're able to see the SDCard and drop your configuration file on it.
I know this is for my Evo 8, but it should give you some ideas. Boost is for Omni 4 bar.
Code:
type=mut2 paramname=TPS paramid=0x17 scalingrpn=x,0.39215686,* paramname=RPM paramid=0x21 scalingrpn=x,31.25,* paramname=Timing paramid=0x06 scalingrpn=x,20,- paramname=Speed paramid=0x2F scalingrpn=x,1.242742384,* paramname=Load paramid=0x41 scalingrpn=x,1.2,* paramname=AFR paramid=0x12 scalingrpn=x,0.03913,*,10,+ paramname=IPW paramid=0x29 scalingrpn=x,0.256,* isvisible = 0 paramname=Boost paramid=0x38 scalingrpn=x,0.2369,*,14.6,- paramname=IAT paramid=0x11 scalingrpn=x,1.8,*,40,- sampgroup=1 paramname=WGDC paramid=0x86 scalingrpn=x,2,/ paramname=O2Voltage paramid=0x12 scalingrpn=x,0.01952,* ;-------------calculated parameter--------------- ; ; you can derive calculated parameters from other parameters ; using RPN expressions ; type = calc paramname = IDC scalingrpn = IPW,RPM,*,1200,/
<value1>,<value2>,<operation on first values>
So multiplication looks like x, 2, * which in simple maths is 2 * x. Mutiple calculations would look like:
<value1>,<value2>,<operation on first two values>,<value 3>, <operation on output of first calculation and value 3>
You also a typo on line 48.
hey guys. i've been doing the same research and only find evoX stuff. i got the sd card logging working but i want to be able to log my innovate LC-1 wideband with the tactrix to sd as well. i get an output file but my AFR is all 0's. anybody with an evo 8 or 9 get the lc1 logged to sd? if so how?
Following should be in your logcfg-file:
;----------------inno----------------
type=inno
; log from an innovate bus via the 3/32" jack
; currently the LC-1 is the only supported device
; in the "inno" case the parameters are already pre-defined, you just
; need to reference them by name so that they are included in the log
; output. note that these parameters won't become valid until the LC-1
; has been calibrated and the sensor is warmed up.
paramname = inno.afr
paramname = inno.lambda
And then you need to connect your LC-1 to the OP2.0 by the stereo jack.
type=inno
