Bunch of CEL codes after SD
Old Apr 21, 2014, 06:45 AM
EvoIIIAj's Avatar
Has anyone else had this problem before? My car runs fine and everything but these codes look so retarded it doesn't even make sense lol.
Old Apr 21, 2014, 08:49 AM
wreckleford's Avatar
Those are all ABS and/or AYC codes. I have never seen that happen with an SD ROM. Do they keep coming back when you clear them?
Old Apr 21, 2014, 09:06 AM
todd6027's Avatar
reconnect the abs/ayc connector on + battery terminal You are scanning evo 5/6 ayc faults
Old Apr 21, 2014, 11:09 AM
EvoIIIAj's Avatar
I don't recall disconnecting anything? I switched to a mini battery though.
EvoIIIAj's Avatar
Yes they come back right away when cleared.
Old Apr 21, 2014, 11:53 AM
todd6027's Avatar
check you didnt miss the abs /ayc connector or blow fuses , which evo is it ???
Old Apr 21, 2014, 12:15 PM
german_evoVII's Avatar
These are NOT the actual Error Codes!!!!!!
You ONLY see the List of the codes which CAN BE coming from the ABS / ACD unit so you can determine what code is actually there!
The codes itself is only displayed by the blinking ABS Light or the ACD Leds
It has nothing to do with the engine Ecu or with the SD Rom
You may have switched by mistake to connect to the ABS / ACD unit....
Lower right Corner : MUT II AYC ECU Evo 4/5/6
it doesnt match what ECU will be selected for Logging...
Common Mistake for Beginners.....
Old Apr 21, 2014, 12:16 PM
EvoIIIAj's Avatar
It's worth noting that I have no ABS / AYC lights flashing on my speedo.
Old Apr 23, 2014, 11:49 AM
EvoIIIAj's Avatar
Can you elaborate on where this is?
Old Apr 23, 2014, 02:11 PM
todd6027's Avatar
on the positive battery terminal
Old Apr 23, 2014, 02:28 PM
EvoIIIAj's Avatar
I'll take a pic of how mine looks today.
Old Apr 23, 2014, 04:57 PM
EvoIIIAj's Avatar
maxspeed96ct
Dec 5, 2017 03:03 AM
Evo3573
12
Sep 10, 2016 05:27 PM
EvoIIIAj
Sep 6, 2012 06:03 PM
EvoIIIAj
Jun 9, 2012 07:50 AM
EvoIIIAj
10
Apr 13, 2012 01:07 PM
Quick Reply: Bunch of CEL codes after SD
