Cant find correct definition file
As the title says. I can't find it. I downloaded the latest version of ecuflash, and looked through the rommetadata for an 03 Evolution MT and can't locate it. I am doing something wrong?
Pretty much hit it on the head there. I am following merlins tuning guide. So basically getting familiar with the software before I start logging and tuning. thanks guys.
Hello I am not a stranger to tunning with dsm link, but I am having trouble with my 2003 EVO 8, my issue is that I can get the ROM to load with ecuflash but I am getting an error saying there's no associated xml file that will allow me to open the ROM or save it. I have since made changes to the car and the tune needs attention.The car was tunned by top speed in ATL prior to me owning it if that matters. I just want to be able to save whats there as a reference point to go back to if I mess up along the way. I have ensured that I have the updated software and searched for the XML files was unable to find anything to work. Am I missing something?
The car probably has a tephra Rom on it so you need to download the xml for tephra roms and stick it in your rommedata folder and then I bet it will read it.
Need some help again guy's. Hopefully this is the correct thread to discuss.
I read my Rom from the Ecuflash : using metadata XML ID 88570008 which inherits XML ID evo9base. This is a IX JDM Evo.
I need to make some changes to the Rom but it seems that I have the wrong definition file, because every time I make changes to the timing maps automatically changes the wastegate duty.
Anyway, the car tuned 6 months ago, and tuner won't give me or tell me what definition file he used to tuned my car.
So my question is how do I know what is the right definition? I try to copy/paste tephra v7 but it won't open.
In tephra's page 88570008 still coming soon...so can I use tephra v7 in some way to open the rom file I have now with the correct map numbers, or do I have to do it from the beginning?
I have attached the rom if you guy's want to try.
Thank you
Thank you
save to ecuflash rommetdata
https://www.evolutionm.net/forums/at...d-88570008.zip
its only one i could find on this machine i do have a better def file at work send me your e mail and il send it on.
I can see in that rom why he wouldnt give you a def file
I pulled my rom image off the ecu last night. I have 94170008. I want to upgrade to 94170015. I need to add a mut table for evoscan though. I tried to add the table to the 0015 by looking up the romid in rommedata folder. I copied and pasted the correct xml files, with the correct mut address.
When I go to open up the 0015 file in ecuflash, the mut table is still not there? What I am doing wrong?
siikEvo92
20
Mar 6, 2012 07:57 AM
