Timing randomization from 2k to 3.5k rpm
Old May 19, 2013, 12:05 PM
worksie's Avatar
Question Timing randomization from 2k to 3.5k rpm
Car is an EDM 2006/7 Evo IX with minimal mods:
- FIC 1100CC High-z (going E85 later)
- Walbro 255, modded
- 3" DP and due to strict legal requirements has standard cat and catback
Original ROM: 88840017
Current ROM: Tephra v7 88580714
I'm having a strange timing issue where my timing is pulled seemingly randomly outside of the timing map. It starts at 2000rpm and ends at exactly 3500rpm. My original EDM ROM is 88840017 and it is equipped with with ALS (software only, the SAS squiggly metal line is missing). The ALS on the old ROM can be accessed with a custom XML, it wasn't visible when initially reading it with Ecuflash. The currently installed ROM is Tephra v7 88580714 with custom maps. Is it possible that the ghost of ALS is somehow active from the old ROM? Below is the log of the problem. Any advice?
Right before and right after this 2000-3500rpm block the timing goes absolutely linear without any jumping around.
Image of the ALS from 88840017 https://i.imgur.com/OgAeEh0.jpg . This does show thought that the activation RPM of ALS is 4k and not 2k.
Code:
TPS	RPM	Tim	Load	KnockV	KS	AFR
100	2031.25	9	106.6	0.2535	0	12.5538
100	2031.25	8	107.9	0.429	0	12.5538
100	2031.25	7	110.5	0.4875	0	12.5538
100	2062.5	5	110.5	0.351	0	12.348
100	2062.5	5	111.8	0.507	0	12.348
100	2062.5	6	113.1	0.351	0	12.348
100	2093.75	4	114.4	0.3705	0	12.348
100	2093.75	3	115.7	0.4485	0	12.348
100	2125	3	117	0.4485	0	12.1716
100	2125	5	118.3	0.39	0	12.1716
100	2125	4	119.6	0.5265	0	12.1716
100	2156.25	5	120.9	0.5655	0	12.1716
100	2156.25	2	122.2	0.273	0	11.9805
100	2156.25	4	123.5	0.5655	0	11.9805
100	2187.5	2	124.8	0.429	0	11.9805
100	2187.5	1	127.4	0.351	0	11.9805
100	2218.75	1	128.7	0.429	0	11.9805
100	2218.75	1	130	0.507	0	11.7453
100	2218.75	3	131.3	0.351	0	11.7453
100	2250	0	132.6	0.39	0	11.7453
100	2250	3	135.2	0.468	0	11.7453
100	2281.25	0	136.5	0.3705	0	11.466
100	2281.25	2	137.8	0.4485	0	11.466
100	2312.5	-1	140.4	0.4095	0	11.466
100	2312.5	2	140.4	0.546	0	11.466
100	2312.5	2	143	0.429	0	11.2602
100	2375	-3	144.3	0.429	0	11.2602
100	2375	2	145.6	0.429	0	11.2602
100	2375	-1	146.9	0.546	0	11.2602
100	2375	2	148.2	0.4485	0	11.0691
100	2406.25	-1	149.5	0.4095	0	11.0691
100	2437.5	0	150.8	0.507	0	11.0691
100	2406.25	2	153.4	0.5655	0	11.0691
100	2437.5	0	154.7	0.7215	0	11.0691
100	2468.75	-1	158.6	0.351	0	10.878
100	2468.75	-1	159.9	0.8385	0	10.878
100	2500	-1	162.5	0.5265	0	10.878
100	2531.25	-3	165.1	0.663	0	10.878
100	2531.25	1	167.7	0.6825	0	10.8339
100	2562.5	-2	170.3	0.429	0	10.8339
100	2531.25	1	171.6	1.014	0	10.8339
100	2562.5	1	174.2	0.4095	0	10.8339
100	2593.75	-3	176.8	0.9165	0	10.6722
100	2625	-1	179.4	0.507	0	10.6722
100	2625	-2	182	0.585	0	10.6722
100	2625	1	185.9	0.6825	0	10.6722
100	2656.25	-2	188.5	0.9165	0	10.6722
100	2687.5	-2	191.1	0.702	0	10.5399
100	2687.5	-2	192.4	0.78	0	10.5399
100	2718.75	-3	197.6	0.6435	0	10.5399
100	2750	-1	201.5	0.7995	0	10.5399
100	2750	-1	202.8	0.6435	0	10.4958
100	2781.25	1	205.4	0.741	0	10.4958
100	2781.25	-1	209.3	0.6045	0	10.4958
100	2812.5	-1	213.2	1.3065	0	10.4958
100	2843.75	-2	217.1	1.56	0	10.4958
100	2843.75	-1	221	0.7605	0	10.4664
100	2906.25	-1	224.9	0.897	0	10.4664
100	2937.5	-1	227.5	0.9945	0	10.4664
100	2937.5	1	232.7	1.6185	0	10.4664
100	2937.5	1	235.3	1.0335	0	10.5105
100	2968.75	1	239.2	0.936	0	10.5105
100	3000	1	249.6	0.78	0	10.5105
100	3031.25	-2	253.5	0.936	0	10.5105
100	3062.5	-1	260	0.78	0	10.5987
100	3093.75	-1	265.2	0.897	0	10.5987
100	3125	1	273	0.4875	0	10.5987
100	3156.25	-3	278.2	0.702	0	10.5987
100	3156.25	1	286	1.014	0	10.5987
100	3187.5	-3	292.5	1.638	0	10.8045
100	3218.75	-3	296.4	1.1895	0	10.8045
100	3250	1	299	1.7745	1	10.8045
100	3281.25	-4	300.3	1.8525	1	10.8045
100	3343.75	-3	301.6	1.17	1	10.8045
100	3343.75	-2	301.6	1.8525	1	10.8633
100	3375	-2	302.9	0.741	1	10.8633
100	3406.25	1	302.9	1.1895	1	10.8633
100	3437.5	-2	301.6	1.521	1	10.8633
100	3500	1	301.6	0.975	0	10.9809
100	3531.25	1	302.9	1.6575	0	10.9809
100	3562.5	1	302.9	1.5795	0	10.9809
100	3562.5	1	304.2	1.3455	0	10.9809
Old May 19, 2013, 02:41 PM
todd6027's Avatar
why so rich ??? show us the timing map
Old May 20, 2013, 02:04 AM
worksie's Avatar
We are in the middle of tuning the car, but upon further inspection the car doesn't respect the fuel map either and richens the mixture even though there is 0 knock.
Due to the maps being worked on by a commercial tuner, I have blacked out the non-essential parts of the maps:
Ignition
Fuel
Old May 20, 2013, 09:49 AM
211Ratsbud's Avatar
Did you check FAA bit 10?
I had a similar issue
Old May 20, 2013, 11:03 AM
worksie's Avatar
Thanks for bringing that to my attention, I disabled bit 10 as well as 9 (cat warmup ign retard). Running logs later tomorrow.
Old May 20, 2013, 03:58 PM
211Ratsbud's Avatar
Tscomp had complained of these rom id's being unreliable in the past. You can always use the 8859 rom with appropriate cel and sensor disabling.
I use a 8858 variant originally on 8859
Old May 20, 2013, 05:38 PM
merlin.oz's Avatar
as above, have you tried 88580014 v5 TephraMod, it seems to work well in my experience.
Note that if you do try v5, Spark maps #1 and #2 are both used, not just #2.
Old May 21, 2013, 06:32 AM
worksie's Avatar
I've been researching this only for few days, so I haven't had time to do drastic ROM changes. This is my first Evo and I was hoping that the tuning could be outsourced as a "fire and forget" solution. It seems that I was wrong Luckily I have been working in the field software and game development since '99, so this is somewhat easy for me to try to comprehend from scratch. The information has been shotgunned all over the internet and this forum, so I have hit Google pretty hard.
I was looking to change from my tuners 88580714 to a Recompile's 88590715 and bring over the values from my current changed tables. I need to do some more reading to see if this is a viable option for an EDM car with a base ROM of 88840017.
"Quote/211ratsbud: You can always use the 8859 rom with appropriate cel and sensor disabling."
^Do you want to go into details what changes are needed in what tables or is there a good source somewhere that I can read up?
[ot]
Is there a good explanation somewhere how the IX's EGR system works?
Old May 21, 2013, 06:55 AM
211Ratsbud's Avatar
Egr disable, map sensor stuff associated with egr, rear o2 , fuel temp, immobilizer
you can post the issues from that. 8859 has a lot of support.
Pretty much been covered one time or another around here.
Would you mind posting your 8858 rom up here with ignition and fuel blanked ?
Does your car have a map sensor and egr as well as a rear o2? I've ran my car on 884, 8857,8858, 8859
IX roms are much more interchangeable
Old May 21, 2013, 01:13 PM
worksie's Avatar
Thumbs up
It would seem that disabling bits 9 and 10 helped. I have been told that disabling bit 9 for a climate that can get rather cold (Helsinki, Finland) is a rather poor choice, so I'm going to enable it and run the logs again, but for now things are as they are supposed to be. Much appreciated!
Code:
100	2000	6	111.8	0.468	0	12.5538
100	1968.75	6	114.4	0.312	0	12.4215
100	1906.25	5	114.4	0.429	0	12.4215
100	1937.5	5	115.7	0.351	0	12.4215
100	1968.75	5	115.7	0.2925	0	12.4215
100	2031.25	5	117	0.4095	0	12.201
100	2031.25	4	118.3	0.39	0	12.201
100	2000	4	119.6	0.429	0	12.201
100	2000	4	120.9	0.3315	0	12.201
100	2031.25	3	122.2	0.3315	0	12.201
100	2062.5	3	122.2	0.351	0	12.1128
100	2093.75	3	124.8	0.234	0	12.1128
100	2093.75	2	126.1	0.351	0	12.1128
100	2093.75	2	127.4	0.5655	0	12.1128
100	2093.75	2	127.4	0.312	0	11.9217
100	2093.75	2	128.7	0.39	0	11.9217
100	2125	2	130	0.2925	0	11.9217
100	2156.25	3	130	0.663	0	11.9217
100	2156.25	3	131.3	0.4485	0	11.9217
100	2156.25	3	133.9	0.3315	0	11.8335
100	2156.25	3	135.2	0.4485	0	11.8335
100	2187.5	2	135.2	0.546	0	11.8335
100	2218.75	2	136.5	0.4875	0	11.8335
100	2250	2	137.8	0.2535	0	11.6718
100	2250	2	139.1	0.4485	0	11.6718
100	2250	2	140.4	0.39	0	11.6718
100	2250	2	141.7	0.39	0	11.6718
100	2250	2	143	0.3315	0	11.6718
100	2312.5	2	144.3	0.468	0	11.4807
100	2312.5	1	145.6	0.3315	0	11.4807
100	2312.5	1	146.9	0.5265	0	11.4807
100	2312.5	1	148.2	0.5265	0	11.4807
100	2343.75	1	149.5	0.3315	0	11.4807
100	2375	1	150.8	0.468	0	11.2749
100	2406.25	2	153.4	0.546	0	11.2749
100	2406.25	2	154.7	0.351	0	11.2749
100	2406.25	1	156	0.4485	0	11.2749
100	2406.25	1	157.3	0.5265	0	11.1426
100	2437.5	1	158.6	0.5265	0	11.1426
100	2468.75	1	158.6	0.468	0	11.1426
100	2468.75	1	161.2	0.936	0	11.1426
100	2500	1	162.5	0.6045	0	11.1426
100	2500	1	166.4	0.468	0	10.9368
100	2500	1	169	0.468	0	10.9368
100	2531.25	1	170.3	0.663	0	10.9368
100	2562.5	1	171.6	0.6435	0	10.9368
100	2562.5	1	174.2	0.5265	0	10.8486
100	2593.75	1	178.1	0.4095	0	10.8486
100	2625	1	179.4	0.819	0	10.8486
100	2625	1	182	0.741	0	10.8486
100	2625	1	184.6	0.8385	0	10.8486
100	2656.25	1	187.2	0.5655	0	10.7751
100	2687.5	1	188.5	0.4875	0	10.7751
100	2718.75	1	192.4	0.624	0	10.7751
100	2718.75	1	195	0.6825	0	10.7751
100	2750	1	198.9	0.741	0	10.731
100	2750	1	200.2	0.9165	0	10.731
100	2781.25	1	205.4	0.624	0	10.731
100	2812.5	1	208	1.131	0	10.731
100	2843.75	1	211.9	0.4875	0	10.731
100	2843.75	1	215.8	0.9165	0	10.7016
100	2875	1	217.1	1.209	0	10.7016
100	2906.25	1	222.3	1.17	0	10.7016
100	2906.25	1	224.9	0.8775	0	10.7016
100	2937.5	1	230.1	0.897	0	10.7163
100	2968.75	1	234	1.053	0	10.7163
100	3000	1	240.5	0.702	0	10.7163
100	3062.5	1	243.1	1.0725	0	10.7163
100	3031.25	1	250.9	1.1505	0	10.7163
100	3062.5	1	254.8	0.975	0	10.7604
100	3093.75	1	258.7	1.3455	0	10.7604
100	3125	1	265.2	1.1505	0	10.7604
100	3156.25	1	271.7	0.741	0	10.7604
100	3218.75	1	279.5	1.131	0	10.8192
100	3218.75	1	284.7	1.3065	0	10.8192
100	3250	1	291.2	1.404	0	10.8192
100	3281.25	1	292.5	1.2675	0	10.8192
100	3312.5	1	296.4	0.975	0	10.8192
100	3343.75	1	297.7	1.1505	0	10.9074
100	3375	1	297.7	0.78	0	10.9074
100	3437.5	1	297.7	1.521	0	10.9074
100	3437.5	1	300.3	1.6185	0	10.9074
100	3437.5	1	300.3	1.248	0	11.0103
100	3500	1	299	1.6965	0	11.0103
Old May 21, 2013, 02:29 PM
211Ratsbud's Avatar
Good to hear
Old May 21, 2013, 04:49 PM
merlin.oz's Avatar
Can you do a power log, with air temp included, and FAA bit 10 on and off.
It would be interesting to see if your chilly Helsinki air temps are getting into the game.
It should not be Acceleration Spark Retard, as the gain byte is set to zero on that rom.
Old May 21, 2013, 05:38 PM
211Ratsbud's Avatar
What is the gain byte and any known rom it does have an effect on?
Is it a factor of acceleration ?
Old May 22, 2013, 02:47 AM
merlin.oz's Avatar
Its used in most of the atmo cars, but I cant think of an evo that has the value other than zero, but ther may be some.
The other control parts are there though.
Old May 22, 2013, 03:13 AM
worksie's Avatar
I provided the full logs where the above snipped has been extracted to my tuner who still informs me that the timing issue persists. I'm a novice in this still so I'll take his word on it. Any other ideas that I can take a stab at while he is busy with more modified cars than mine?
Also, any idea why 88840017 was never "Tephra-ized" for the EDM faction?
Quick Reply: Timing randomization from 2k to 3.5k rpm
