LC1 AFR not logging correctly
Old Apr 29, 2012, 06:45 PM
desiromeo812's Avatar
Hello all,
Im trying to log my AFR.. it doesn't let me review it right in the log viewer in evoscan. I tried using 2.7 and 2.8. I have Lc1 tapped into rear O2. Using formula that comes with evoscan..... Priority 1, response bits 2.
Attached is a pic of how it looks.
thank you guys.
Old Apr 30, 2012, 02:27 AM
richardjh's Avatar
That looks right to me... Looks just like mine, anyway...
What do you think is incorrect?
Rich
Old Apr 30, 2012, 05:13 AM
Oh I was under the impression the line should b smooth like the rest of them, instead of being a constant zigzag.
Old Apr 30, 2012, 05:48 AM
richardjh's Avatar
It's just the analogue voltage jiggling a bit. If I feed in a constant voltage, eg. 1.0 volts fixed, the ADC sees it jiggling up and down by +/- 0.1V.
On mine, I've got it interpreting 0V as 10:1 and 5V as 15:1... which means it's accurate to around 0.1 AFR - certainly good enough for me to tune to!
But accuracy would start to become a real issue if you wanted 9:1 <-> 18:1 range. That 0.1V jiggle would really start to hurt for a wider range.
Hope this helps!
Rich
PS. I'm not actually feeding in analogue to the rear-o2. Instead, I've patched into pin 8 of the OP2.0 itself. Seeing as our graphs look so alike, it's quite possible the jiggle is right back at the LC-1 analogue source, rather than an issue at the ADC (ECU, OP2.0). I'm sure we've both got our respective groundings and wiring good.
mrm95
11
Sep 7, 2015 06:40 PM
evo9_jdm
May 7, 2010 09:04 AM
rogue
Mar 1, 2010 06:17 PM
saiyuke
Jul 6, 2008 01:13 AM
sponners
Apr 20, 2008 12:30 PM
Quick Reply: LC1 AFR not logging correctly
