P0325 and 8-9 counts of off throttle knock
Old Nov 1, 2011, 01:29 PM
Svendiesel's Avatar
Ok so Ive had this code for a while now. I have a brand new OEM knock sensor ready to go in if I need it, but I feel like somethings up and it IS NOT that the knock sensor is busted. It only happens while cruising at part throttle/no throttle.
Will a lot of knock cause this code to throw or is it really a fault somewhere, either it being the connection itself or an actual bad sensor? I really need to double check the connection first and foremost. I know its very rare for the knock sensor to actually go bad, which is why I want to really make sure its not something stupid before I replace it all together.
Old Nov 1, 2011, 02:28 PM
tscompusa's Avatar
that code is knock sensor circuit malfunction.. i mean theres nothing more that would cause the code to trigger unless the circuit was literally malfunctioning. ive never seen that code on a evo before.
did you torque it to tight into the block when you installed it possibly? either that or something is damaged on the wiring to it where it plugs in maybe on the ecu end?
Old Nov 1, 2011, 03:38 PM
Svendiesel's Avatar
I didnt install the knock sensor myself a friend did. I guess Ill have to just double check everything.
Old Nov 1, 2011, 07:48 PM
JohnBradley's Avatar
They are very fragile and break easy. Its loose or there is something wrong with it. The next easiest way to do know is log knock voltage and see if there is any. It could be loose and you get lucky but I have seen that code enough to know that if it trips its time for a new one.
aaron
Old Nov 2, 2011, 08:59 AM
Svendiesel's Avatar
Im going to be checking it today, I know its undertorqued now. So I will check that and recheck connection and make sure its snugged up properly
Old Apr 20, 2014, 10:02 AM
Ude Lose's Avatar
I am having the p0325 code as well. Also i am getting p0325 p.
Malfury
Oct 5, 2015 09:20 AM
RalliMark
Nov 16, 2013 01:01 PM
EvocentriK
14
Jun 19, 2013 08:05 PM
Svendiesel
Oct 27, 2011 10:43 PM
fireroasted
May 22, 2011 05:17 PM
Quick Reply: P0325 and 8-9 counts of off throttle knock
