Tephra V7 + ICS lamp on USDM
Hi guys,
Is there someone here who have the dash' ICS lamp working on a IX MR?
I know USDM IX does not have ICS but I was experimenting to see if I could get the light flashing on Alt map with the Tephra V7 and I do not get anything yet…
I wired the pin 90 on the ECU and checked any juice but nothing… no 0V, no 5V, no 12V, never…
May be it is necessary for the ECU to have the ICS switch wired too in order to have the sequence working properly but I don't know if pins 66 and 67 are 0 or 12V managed…
I wonder if someone already worked on this…
I also want to wire the pin 56 to see if it will be possible to control any proper ICS system…
Thanks for any feed!
Cheers,
C>
Cheers,
C>
I added the wire and routed to pin 90 but light does not come on. If I ground same wire then light iluminates. So pin 90 is not seem to be doing anything. I change the maps with tps. I get slow flashing for main and fast for alternate, but nothing happens with ICS. Is there anothet setting i have to turn on to make it work?
Alchem1st
Mar 15, 2022 08:47 AM
blacktab420
Feb 2, 2016 09:51 AM
