Aug 12, 2009, 07:50 PM
#91
Personal Sales Rating: ( 0)
Drives: 05 EVO VIII
I'm looking forward to launching this thing at the track on Friday. I'm used to launching awd 1st gens but I'll start off a little easier with this. I care about this one a bit more
Offline
Aug 12, 2009, 08:14 PM
#92
Personal Sales Rating: ( 2)
Drives: Evo IX RS
Quote:
Originally Posted by boostedwrx
You either need to:
a- slip the clutch
b- rev it so high and dump it, but make sure you spin your wheels
in each scenario the drivetrain is not taking the majority of the abuse. Clutches and tires are cheaper!
I agree with post #8 from back in 2003. Slip the clutch or spin the tires (a little). Keep the load off the hard parts. Raise the two step limit & drop it from there ftw.
Offline
Aug 17, 2009, 10:46 PM
#93
Personal Sales Rating: ( 3)
Drives: 2006 Mitsubishi Lancer Evolution IX MR, 2004 Acura TSX
Quote:
Originally Posted by RallyDSM
The only problem with this technique is that the stock clutch won't always hold the built boost on launch and you will likely burn up the disk while holding the throttle through 2nd gear.
I'm not saying it won't work, because it certainly WILL launch the car hard, but beware of smoking the clutch.
One technique I picked up from racing a Lotus Esprit Turbo (X180R) for a bunch of years... Lotus has glass trannys too, for the record... is that opposite of a heal toe shift for launch.
When testing the new SPD subarus' (with their glass trannys) I used the same technique for what one engineer told me was the the hardest launch he had ever seen in an STi.
Step on the clutch, right toe on the brake and begin the rev with your heel. Start to engage the clutch while building RPMs with the brake ON. As the rpms drop with clutch engagement, the resistance builds boost. Release the BRAKE and remaining clutch as the same time and bury the accelerator.
Like all launching techniques, it takes some practice but when you get it right, it is MUCH easier on the clutch and when you drop a ton on a clutch, you might want to save it as much as you can.
Scott
thats the only way i've ever launched, and 133,000 miles later, it still works every time.
__________________
2006 Lancer Evolution IX MR MODS: Ralliart CF lip, Black painted roof/vg, JDM EVO IX rear, Black UK trunk badge, Spark Tech COP, K&N drop in filter, HKS Carbon Ti exhaust, Buddy Club Racing Spec Coilovers, Stoptech Slotted rotors, ACT HDSS, ACT Streetlite Flywheel, Ingalls Stiffy engine tq damper, HKS Type-1 TT, Hawk HPS pads, tinted windows, honda element antenna
12.82@107.41
1.86 60'
140k miles and still BALLIN
Offline
Aug 23, 2009, 01:20 PM
#94
Drives: 03' blk evo
my 2 step is awesome, love it.
Offline
Aug 31, 2009, 09:30 AM
#95
Drives: Mirraco Fivestar Park (cant drive yet but i want a evo x gsr)
the best way is probably, rev your car until ur in the boost power band, so between 4-6k, then let the clutch slip until the engagement point then rev ur car even higher (about 500 revs higher then wat u were revving at) then u let out the clutch completely =p
Offline
Sep 5, 2009, 06:08 PM
#96
Personal Sales Rating: ( 32)
Drives: 06 Blue EVO IX
Ok first of all launching is something that you have to feel. Its very hard to just read it and go out and do it perfect for the first time. Here is what I have learned and read to safely launch the car.
Note: Never launch the car if you just had to put it in reverse align to the drag lights. If you went over , then reverse the car further back and start rolling forward to re-align.
-Press in clutch
-Pull hand brake
-Raise rpms slowly to rev limit before hitting WOT to bounce on it.
-Slowly release clutch to the point where it grabs ever so slightly but the brakes wont let the car roll forward.
When you do your creating preload. This will set the gears in the drive train to prepare spinning forward. At the same time it will not allow the gears to slap onto each other during the launch. This slap causes a hard shock that is one of the main reasons drive train parts break.
-From this point you can slip the clutch out while releasing the hand brake. You need to practice to learn how fast to release the clutch pedal so that it is not burning the clutch but at the same time not dumping it either.
If you dont want to do the hand brake method, you could just allow the car to inch/roll a little forward right when launching before doing the fast slip. This slight roll will help set the gears with some load before the hard launch.
Good luck,
__________________
2006 Blue EVO IX
3" Down Pipe & Testpipe w/ Stock Catback
TTP Swain o2 housing & Vibrant Cone filter
Forge WGA & Hallman RX Pro (cabin)
CCI Stage 3 clutch
Blox Motor Mount
ShepTrans
Offline
Sep 5, 2009, 06:09 PM
#97
Personal Sales Rating: ( 5)
Drives: '06 GG MR, '98 S14
Quote:
hehe dang old thread
__________________
finally... an evo with no decel noise
340/336 uncorrected Dynojet (Shiv tune) with exhaust
385/336 corrected Dynojet (JohnBradley tune) with BBK
Offline
Sep 5, 2009, 10:54 PM
#98
Personal Sales Rating: ( 1)
Quote:
Originally Posted by hel_if_ino
The best way i have found to launch the evo with MINIMAL burnt clutch smell is to "blip" the throttle from about 3500-4000 about 2 or 3 times, then just agressively slip the clutch on the last blip, should do you pretty good, i have tried all sorts of different ways and this works the best for me. Also, when i was at the evo commercial shoot, i asked Rhys Millen how he was launching the 8, he said he uses the e-brake to keep the car on the line and still while he keeps the clutch right at breaking point, and just slams the gas, it worked pretty damn good for him, he spun all four tires. I cant attest to this process though as i have not tried it yet.
^^I do this and it works flawless
Offline
Sep 24, 2009, 01:27 PM
#99
2006 Mitsubishi Lancer Evolution My Garage
Drives: Evo IX SE
Good luck,[/quote]
This is exactly how i do it. The handbrake method can get confusing.
__________________
Life is an adventure enjoy while you have it!
Evodan2004 Built, Kreionic Tuned, 348.0whp/316.7wtq, 25Psi CBRD Mustang Dyno
Boltons Plus Cams, Stock IM, TB, EX Manifold, 02 Housing, stock head.
Offline
Sep 27, 2009, 01:30 PM
#100
Drives: evo
good advice's
Offline
Sep 27, 2009, 01:46 PM
#101
Drives: Evolution IX SE
I have had really good luck launching my car. Went through an ACT HDSS in about 6000 miles just to learn how to lauch. You definitely do not want to "drop the clutch" that's the quickest way to replacing the tranny or transfer case because of the impact on the gears. I found that having a 2 step rev limiter set in place is perfect for me. I have a bigger turbo on my car so I launch from 6000 RPMs I also set up a 2 step in my buddy's stock evo 9 at 5500 RPMS and I can launch his pretty good.
From a stop I floor the gas (MAKE SURE IT IS FLOORED) Not just bouncing off the rev limiter at half throttle (My mistake when I was learning) that will send you into a horrible bog and you wont go anywhere. Don't be afraid to floor it.
slip the clutch a little until you feel it start to grab and then let off the clutch completely. If you hold the clutch too long you will burn it up. Once you get it down you shouldn't be burning the clutch too bad.
I am able to launch without smelling any clutch at all and I can get off the line quicker than my buddys ZR1 Corvette. I spank bikes off the line pretty well.
just make sure you keep the throttle floored and don't let off when you let off the clutch
just my .02
Offline
Sep 28, 2009, 05:06 AM
#102
Drives: Evo IX SE
just my .02
What 60ft are you cutting?
__________________
Offline
Oct 3, 2009, 05:59 PM
#103
Drives: 2005 EvoVIII RS
-Press in clutch
-Pull hand brake
Good luck,
This is what i did when i launched my supercharged type R with slicks. The only way I wouldnt snap axles. I tried one launch on the street with my 8 RS, and well, that was probably my first mistake... the street. I slipped the clutch a little much and wow did i ever burn it up. It was my first attempt on launching the car.. was paying attention to too many things at once. and the boost response really surprised me. Ive been down the track 250+ times in FWD and RWD cars... I know how to drive but AWD drivetrain is very different.
At the track, i plan on preloading, quick slip to grab then dump... 2step is set at 5800. Wish me luck.
bren
Offline
Oct 23, 2009, 07:16 AM
#104
Drives: 03 Evo, 93 Del sol
launch that ****er....
well, i launched my 2003 Evo @ 6700 rpms.. The cars tires chirrped on the tarmac and i was gone. I guess it depends on your drivetrain and mods...
Offline
Tags
burn, burning, clutch, drop, evo, evolutionm, full, hard, high, lancer, launch, launching, rev, slip, smell, wot  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
