Sep 25, 2005, 10:22 PM
Personal Sales Rating: ( 24)
Drives: EVO 8, Spotr Trac
just buy the ikeya formula sequential shifter. DONE
Offline
Sep 26, 2005, 01:29 PM
Personal Sales Rating: ( 2)
Drives: EVO8
thanks blackhawkRA. i went to autox at ca speedway yesterday and i found it's so fun to race my car. it's my first event and i improved 4 secs from my 1st run. i didn't try my best to get the best time but feel my car in different situation(under and over), which i don't wanna try at street. thanks for the great advice, it did help.
Offline
Sep 28, 2005, 01:48 PM
Personal Sales Rating: ( 12)
Drives: 05 RR Evo, 06 Range Rover Sport
Quote:
Originally Posted by purecoda
gently depress clutch, put car in first
take a deep breath and floor it
yank first into second, no clutch
punch second into third, no clutch
jerk third into fourth, no clutch
thrust fourth into fifth, no clutch
i do it because i like the smell (and the sound) of grinding gears.
 Thats the best thing i've heard all day!!!!!
Offline
Nov 18, 2005, 09:42 PM
Personal Sales Rating: ( 31)
Drives: Evil
i drive better when driving aggressively...duno why...maybe because i shift at high rpms
__________________
STOCK PARTS FOR SALE:
STOCK INTAKE
STOCK TARMAC BLACK HOOD(DAMAGED) $100 PICK UP CHICAGO
STOCK EVO VIII P/S TAILLIGHT PM WITH OFFER
P45R GOLD WITH POLISH LIP 18X.9.5 +30MM WITH CUSTOM HUBCENTRIC 8MM SPACER UP FRONT WRAPPED IN AGGRESSIVE ADVAN NEOVA 265/35/18 - ONLY LOWERED $900 PICK UP!! WILL SHIP FOR REASONBLE PRICE..PM WITH OFFER
P45R TIME ATTACK 18X9.5 +20 FRONT +30 REAR..WITH 255/35/18 TIRES! NO SPACER NEEDED AND CLEARS STOCK FENDER WITH NO RUB! $1150 PICK UP!!
Offline
Dec 8, 2005, 02:46 PM
Personal Sales Rating: ( 4)
Drives: 08 Lancer GTS on steroids.
some good info here.
Offline
Jan 1, 2006, 05:18 PM
Personal Sales Rating: ( 0)
Drives: Black Evo 8 Black 636
people that ride with me when i drive fast always tell me i can't drive bc its not smooooooth and they get jerked around a bit. So i tell them to drive their civic instead of askin me for a ride
__________________
03 Evo 8 black *SOLD* :(
06 Kawasaki ZX6R that same black color
03 Frontier crew cab long bed BLACK
Offline
Jan 1, 2006, 06:30 PM
Drives: 03 8 Vishnu stg 2
Offline
Jan 1, 2006, 06:48 PM
Personal Sales Rating: ( 52)
Drives: 04 Graphite G35, Blk Evo 8 W/35r, Vespa Scooter w/ a Jet Engine (Daily);-)
Quote:
Originally Posted by DaWorstPlaya
Mind over matter, even when racing you have to stay calm and shift smoothly. You really don't save much time by ramming throught the gears but do cause accelerated tranny/synchro wear ...
Im with this guy, its all in your head. If you think your an aggresive driver than you'll get aggresive results. Rather than Being smooth and calm and accurate. You'll enjoy your driver alot more. When driving think ahead of your next shift,next turn so on. there are tons of ways that you could improve your driving, or mind set. I think its alittle bit of everything
Offline
Jan 2, 2006, 03:00 AM
Drives: 05 Evo
heres my input, ease the clutch when you shift dont put it all the way in.
Offline
Feb 12, 2006, 03:40 AM
Drives: 2003 Mitsubishi Lancer Evolution VIII, 1995 Chevy Blazer LT requireing a new windshield, stereo, valve job, ignitation system, ... 1968 Pontiac Parisenne 327 V8 wide track with limited slip
Emotion: Feel the car. Feel the road. Fall into the natural rhythm. I believe the vehicle should be an extension of you, not as a seperate entity. Be relaxed and calm and in good spirits. Put on a some music to get in the mood: "The Ride Of The Valkyries".
Behaviour: Treat her gentle like a little lady. Use the pads on your fingers to pull from 1-2, 3-4. Palm up for 2-3 and 4-5. Let her take care of herself. Grabbing with a closed fist tightens up the muscles in your arms. Why get tense? Use your knee and ankle both to adjust the rate of clutching. Let it fall into a natural sinusoidal response. The closer the clutch plates are together, the slower you clutch. Let it fall into nature's natural beat. If you clutch on and off like a square wave, things are going to get jagged and you're going to upset the car.
Technical: Match the RPM to the gear changes. Know your gears. Note that the gear change from 3-2 is larger than the gear change from 4-3. That means if you are shifting from 4-3 at 4000RPM and you need to blip up to 4800RPM. Then to go from 3-2 at 4000RPM you might need to rev up to 5200RPM. Note also I performed no calculations here and the numbers are for the sake of argument. Higher RPMs seems to be more stable for shifting.
Even when I think I'm doing good, regardless of the type of driving, I still observe the movements of my passanger(s). I find you get a false sense of stability when you're holding tight to the wheel and depressing the floor board. Or just fill a paper cup with red or yellow oil based paint 0.75" from the rim, place in your cup holder and don't spill.
Offline
Feb 12, 2006, 04:23 AM
Drives: 2004 Black Ralliart MT
+4 tcollins
__________________
Romans 1:16-17:
"For I am not ashamed of the gospel of Christ, for it is the power of God to salvation for everyone who believes, for the Jew first and also for the Greek. For in it the righteousness of God is revealed from faith to faith; as it is written, 'The just shall live by faith.'"
Offline
Feb 22, 2006, 10:41 PM
Personal Sales Rating: ( 8)
Drives: your mom crazy with my striking good looks
first, check out the link to the diy on the clutch block in my sig.
second, smooth is good- I use the finger tip/palm method when I am shifting and it makes the shifter do the work for you almost. If you are being real jerky you are hitting the throttle too soon. you have to be COMPLETELY engaged before you go back to WOT. unless you have a SMG you can't expect the car to shift instantly, try slowing down a tad on the throttle application.
lots of good advice--looks like I used too many anacronyms
__________________
wtb 4g69 bottem end. pm me.
Offline
Mar 9, 2006, 05:32 PM
I picked up the book titled "Bob Bondurant on High Performance Driving". I'm not "bad" for shifting, but there's something in my movement to/from 2nd that has always tripped me up, spirited driving or not. One thing that Mr Bondurant taught me so far reading his book is that shifting is not just a journey from 1st to 2nd. Its a journey through N. The LanEVO isn't a drag car, so take your time. Depress the clutch, shift from 1st to N, let your heart beat once, shift from N to 2nd, engage the clutch. This is something new and it has been working for me. I'm wondering, though, if double clutching is neccesary, or recommended for a car with 3 synchros for 1-3 and 2 for 3-5. Thoughts, anyone?
Abrupt changes or difference in direction and/or force on anything causes a rapid change in acceleration which ends up as disruption. Disruption causes stress, heat and lost energy. Stress and heat causes accelerated wear and tear, on both you and the car. Do you and your car a favour and smooth it out....
Then again, what is "driving agressively"? If you're slaming gears, sure its aggressive and angry and you might not be going anywhere. Or you can get gentle, yet firm and take the corner as you like. Or maybe you're doing a constant +15MPH over the speed limit which your friendly Man in Blue calls "agressive driving" and pulls you over LOL.
Offline
Tags
car, cars, driving, fast, gears, make, manual, quickly, race, racing, shift, shifting, shifts, smooth, smoothly  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
