Sep 13, 2005, 05:30 AM
Personal Sales Rating: ( 12)
uhm... iunno if this is gonna sound like abummer but i left foot brake with ease, of course i have a racing seat, sparco corsa, that helps a LOT so i totally know where you're coming from. i guess racing seat is important?
uhm... iunno if you want tips on practicing but the way i got into it really well was actually by brake boosting on the freeway, just like when you needa pass a car... instead of downshifing brake boost instead, or.... downshift and brakeboost. cuz it's a lot less strenuous when you have wide open spaces.
also when i left foot brake i tend to first "settle" my foot, the ball part, on the lower left corner of the brake pedal, then i ease into the braking and then transfer the whole foot. and then most of the time for setting up the left foot brake i hold my foot over the brake but don't touch it.
this is of course all easier if not only possible with a racing seat.
Offline
Nov 17, 2005, 06:50 PM
Personal Sales Rating: ( 1)
lfb is weird, ive never came into this part of the fourms, i do lfb when im driving because i get bored.... but it feels weird, i slam on it to hard....
__________________
Cerious RA CF trunk, PM if interested
RRM RA Evo9 Body-Kit , PM if interested
06 G7 Rasta Fly 45 frame, PM me if interested
JVC everio HDD, PM me if interested
Offline
Nov 17, 2005, 06:51 PM
off topic, did you know the brake lever thingy for your foot brake is the strongest metal on the car. It sin the manual somewhere, if you slam on your brakes in an accident or preaccident you dont want that ot brake hehe
__________________
Offline
Nov 17, 2005, 07:21 PM
lfb is all about finesse takes lots of practice... the whole point of lfb is to not upset the car wtih jarring throttle lift + brake application but to be able to slow down without incurring any balance change.
Offline
Nov 18, 2005, 08:35 AM
Personal Sales Rating: ( 0)
Drives: WW IX MR
Quote:
Originally Posted by kevin_stevens
Don't forget to move it over before you stab the clutch.
KeS
I did that in a race at Sebring in January on the warm-up lap....I looked in the mirror right after I did it and I saw three cars going different directions
__________________
IX WW MR
Offline
Nov 20, 2005, 01:49 AM
Personal Sales Rating: ( 2)
Drives: GG IX
Quote:
holy cow i hope those drivers were alright!
__________________
06 GG IX
Works CBE/RSR DP/Cosworth M3/PTE 780cc/K&N drop-in
Tuned by Bryan (razorlab) @ GST Motorsports
Offline
Dec 2, 2005, 01:11 PM
Personal Sales Rating: ( 5)
Drives: Lighting Yellow Evo8
I find it hard to do since I have long legs and It makes my ankel really uncomfortable after a while. Especially with the G-force added in I no longer can use my left leg to make my body more still and due to I have to move the seat back more. my body moves a lot more too.
Offline
Dec 2, 2005, 04:25 PM
this is when you find it necessary to get the proper equipt to aid driving comfort and stability. racing seat with an adjustable slide and mounted nice and low for a tall guy like you sounds like what the doctor is ordering.
Offline
Dec 7, 2005, 05:37 PM
Drives: '03 Black Evo VIII
when u apply some brakes mid corner, weight shifts from the rear to the front, providing more traction up front than in the rear = oversteer to neutralize the natural understeer.
Offline
Dec 7, 2005, 05:48 PM
mmm i don't know exactly your point for saying this but there are varying situations to which the above philosophy can't exactly be applied.
most of what you said this is assuming that for one your front tires aren't overloaded, which means you have enough traction to both steer and brake. when you are over the limit of adhesion... the braking will only cause more understeer.
left foot braking is beneficial when you DON'T want this extra weight to go onto the front causing an overload. for instance in a varying radius turn... if you have a reducing radius turn you progressively have to brake more while going into the turn adn sometimes it works VERY nicely just as you described... but sometimes you lose too much speed and the corner exit is weak or sometimes the decrease in radius and the need for deceleration overloads your front tires. so in these cases left foot braking are good.
also... you should never apply brakes mid corner. you should be braking into mid corner but never starting to brake while you're mid corner, that's when you know you f'ed up and it's a hairy situation because if you brake you're screwed but slowing down if you don't brake you have some more control (not much) but you're still screwed. at that point you're just heading for something hard and ti's gonna hurt.
also... initiating a brake midturn also upsets the balance of the car... which might bring your traction bias up front... but will most likely overload the tires at least for one instat if not for hte rest of the turn.
Offline
Dec 7, 2005, 06:58 PM
Drives: Ducati 1198s, Ducati 916, KTM 520mxc and an Apex Silver Evo
You don't use it to slow the car (let that sink in)...but to affect the balance of the car and to add torque to the drivetrain (puts power to the outside tires) which help the car turn. You can be accelerating the car (cars speed is increasing) while dragging lfb which keeps the car from running wide (understeering). I use it all the time in the snow it works wonderfully but it takes time to develop the sensitivity so it does not unduly upset the balance of the car. You can make a car act like it has tight limited slip diffs with lfb even if it only has open diffs (like the 03-04 front)
On an AWD car it will tighten the line of the car
On a FWD can you car actually cause substantial usefull oversteer with lfb
On RWD you can minimize entry oversteer and use it as traction control on the exit
On turbo cars use it as anti-lag
I find the EVO seat good enough to lfb. Harnesses certainly help though and as does a good seat like an OMP (not Sparco IMO).
Offline
Dec 7, 2005, 08:54 PM
mmm points taken!
Offline
Dec 9, 2005, 05:19 PM
Drives: 2005 Evo VIII
sounds really complicated for me
think i will stick with normal day to day driving techniques
Offline
Dec 9, 2005, 06:34 PM
but it is :]
Offline
Dec 22, 2005, 04:52 PM
Drives: 2004 Black Ralliart MT
There's some good info here... I've been teaching myself LFB in the past couple of days and it really is an amazing technique, especially for FWD cars that understeer entirely more than desired (like the RA). If you're about to learn the technique, I suggest finding a long stretch of parking lot or empty road in which you won't have to focus on traffic or objects, that way you can put most of your attention on pedal placement and sensitivity of your left foot. For your first few attempts to LFB in a straight line (just for accustomization) it might be a good idea to rev it up to more than cruising RPM (maybe 3k or 4k) in case you brake harder than intended and have to suddenly switch to clutch in order to not kill the engine.
Last night I found a parking lot with enough space to practice and one nice sweeping turn. Though it was really wet and not very uneven, I was able to get a good sense of LFB in my car. I kept the car in a constant LFB almost drift-like state for several rotations around some objects and my left foot was on the brakes for at least 10 minutes in total. Once I parked I thought of checking how hot the brakes were so being the dumbass I am I just dabbed the front disc with my thumb not really taking any precautions. They were so hot that I still have a big patch of discolored skin right now! Yeah so don't touch your brakes after LFB for a long time, but I guess everybody here cept me would think of something like that  .
From what I've learned (in the car), it's all about giving it enough pressure to keep the back end as loose as you want it, but without lowering the vehicle speed lower than you want. I'm sure this practice in an N/A car will help for once I get a turboed car (hopefully) sometime in the future.
Just one question: when using LFB to balance suspension state through a constant-radius corner, would you guys normally make slight ongoing adjustments to brake pressure, or just mainly with gas and steering? I know that I use every control to adjust the car, but how do you guys do it?
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
