Go Back   evolutionm.net > Competition > Drag Racing
New! Use your Facebook to securely log into this site, click logo to login
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 25, 2009, 10:53 AM   #1
Personal Sales Rating: (1)
PATRICK B.'s Avatar
Drives: 2006 EVO RS & 2003 F150 SCREW
Pat's Evo 9 runs a personal best but ...... UPDATED W/ VIDEO
Made a trip out to the track after putting in the 5point bar and switching to 1450's and E85.
Was just going to make a few passes to fine tune and log info and had some good and bad news.
I was one of the first 20 cars and the 10th car oiled down the track for an hour
Finally got to make a pass and the car left a little soft and was making a decent pass but for some reason my gutt said to lift in 4th gear
Get back to the pits and shut her down and then i see coolant coming from the front timing assembly area so i think the water pump said goodbye
The over flow was not filled and the tube itself totally dry. Car never overheated and logs showed normal coolant temps however i did have the heater blowing after the pass which i do every time possibly masking the rising temps???
The car did run a personal best (not by much lol) but does give me great hope to get the car deep into the 10's w/ a possible 9 sec pass in the near future.........
Enough w/ the excuses here is the breakdown:
Temp - 79*
Hum - 51
Baro - 30.00
60' - 1.609
330' - 4.400
660' - 6.717 @ 104.20
1000' - 8.721
1320' - 10.435 @ 125.25
I have a vid that will be posted as well as the slip i know it's not much but it's def progress now i gotta start researching water pumps and failure and why.......if you have info on that please do share links etc.
Video:
__________________
Sponsored by :
FFTEC MOTORSPORTS
www.FFTEC.com
SPARKTECH IGNITION SYSTEMS
www.SparkTechIgnitions.net
FUEL INJECTOR CLINIC
www.FuelInjectorClinic.com
Quickest ET = 9.902
Fastest MPH = 146.505
http://www.youtube.com/watch?v=C6vaJhFy9pg
http://www.youtube.com/watch?v=1nM_l669Ads
Offline
Old Jun 25, 2009, 01:09 PM   #2
Personal Sales Rating: (20)
SpoolnupTuning's Avatar
Drives: E-85
Send a message via AIM to SpoolnupTuning
Temp - 79*
Hum - 51
Baro - 30.00
60' - 1.609
330' - 4.400
1000' - 8.721
congrats Patrick! you still running the qm? sorry to hear about the wp though. should be a easy fix though.
__________________
E85 Guru and stock ecu Guru!!!
Offline
Old Jun 25, 2009, 01:19 PM   #3
Personal Sales Rating: (38)
Gusl's Avatar
Drives: Evo 8
Nice!
Congrats.
__________________
Tuned By Lance at MGW
505 WHP at 25 pounds on 93 & meth
559 WHP at 29 pounds on Race gas
DD stock block
Revised numbers-
527 WHP at 26 pounds on 93 & meth
579 whp at 30 pounds on Race gas
Offline
Old Jun 25, 2009, 01:39 PM   #4
PATRICK B.'s Avatar
Quote:
YUP
The QM has been treating me very well aside from its low speed tendancies it is flawless at the drag strip.
I wana switch to some 24" slicks to see what effect it will have.....and maybe some diff lowering springs.
Wish i knew how to go about getting some other sponsors for some of this stuff......it sure does get expensive
Kool thing was all the old skool domestics in comp rod class were TRIPPIN when they saw my car leave a Cuda like it was standing still
__________________
Sponsored by :
FFTEC MOTORSPORTS
www.FFTEC.com
Quickest ET = 9.902
Offline
Old Jun 25, 2009, 02:39 PM   #5
Personal Sales Rating: (0)
Fathouse's Avatar
Drives: WWevo9rs
Send a message via AIM to Fathouse
Good job man, you will get it sorted out and a full pass out of it soon.
__________________
2006 Evo9 RS
New build in process! (mostly done!)
http://forums.evolutionm.net/evo-eng...ld-thread.html
Magnus v5, Shep racing, Shearer fab, MAPerformance, QM clutch, FP cams, spoolinup.com COP, Fatfab 6765kit, Blevins tuning, BFF racing, and CORN FED!
First track trip, best et 10.06, best mph 150.65 NEW TIMES COMING SOON!!
http://www.youtube.com/watch?v=_m_fq43FGJk
Offline
Old Jun 25, 2009, 02:53 PM   #6
Personal Sales Rating: (64)
evovin's Avatar
Drives: Evo 8
60' - 1.609
330' - 4.400
1000' - 8.721
1320' - 10.435 @ 125.25.
How early did you lift?(what rpm)
__________________
10.90@129mph(sunnoco 116)
best trap 135mph
best 60ft 1.58
PT6262
Tuned by Mark @ TTR
TurboTrix Racing
http://www.turbotrix.com/wordpress/
SparkTech Ignitions
http://www.sparktechignitions.net/
Fuel Injector Clinic
http://www.fuelinjectorclinic.com/
Offline
Old Jun 25, 2009, 03:45 PM   #7
Personal Sales Rating: (41)
Drives: 06 RS
Good luck Patrick, I'm sure you will get it sorted out. It must feel good to have a safer car and not have to worry about getting the boot. Props to you for doing things the right way. BTW we bent up a six point for use at a later date . Indy
Offline
Old Jun 25, 2009, 04:23 PM   #8
Personal Sales Rating: (6)
wtmodnar's Avatar
Drives: flexfuel evo 8
congrats, hope everything works out for u gl.
__________________
Personal Best (stock 9 turbo)
12.30 @ 114
Thanks to
Trevtec motorsports
Offline
Old Jun 25, 2009, 04:52 PM   #9
PATRICK B.'s Avatar
Quote:
Thanks ..............not too bad for a year and a half of racing, dynoing, and street driving everything else seems to be ok motor wise
Quote:
Logs showed right at 6900-7000 and vehicle speed showed 130mph.......a little bench racing if you don't mind but what do you think it would have gone guys?
Quote:
Being strapped in tight w/ the harness sure made me feel like a real race car driver
Quote:
Thanks
__________________
Sponsored by :
FFTEC MOTORSPORTS
www.FFTEC.com
Quickest ET = 9.902
Offline
Old Jun 25, 2009, 06:25 PM   #10
congrats on your personal best!
__________________
^5
Offline
Old Jun 26, 2009, 07:53 AM   #11
PATRICK B.'s Avatar
Quote:
Thanks
Here's a quick little vid a friend filmed for me.
Funny how you can barely hear the car w/ the full exhaust on it but they are strict about noise as they restrict you to just over 100db
__________________
Sponsored by :
FFTEC MOTORSPORTS
www.FFTEC.com
Quickest ET = 9.902
Offline
Old Jun 26, 2009, 08:00 AM   #12
97EclipseGSX's Avatar
Drives: 2003 Evo VIII
Just a guess but 10.0 - 10.1
__________________
1997 Eclipse GSX - SOLD
7.0 @ 101 (1/8 Mile)
2003 Wicked White Evolution VIII RIP
7.6 @ 94 mph 11.8 @ 117 (US 41 AMS Event, 1st Place)
7.64 @ 90 mph (1/8 Mile, pump gas)
2003 Tarmac Black Evolution VIII
7.53 @ 93.71 mph (1/8 Mile, pump gas, methanol injection, stock turbo)
7.46 @ 95.61 mph (1/8 Mile FP Green pump gas w/ methanol)
AMS 950R 700+ AWHP on 39 psi on E85
www.Automotosports.com
www.TeamRip.com
Tachyon Performance
Blevins Tuning
Offline
Old Jun 26, 2009, 08:07 AM   #13
MOREPSiTEHBETT4's Avatar
Drives: 01' BMW K1200RS Blue/Silver, 04' STi sold
very nice pat, the launch looked very good, nice eighth and 21 mph back half; you got lower ten's coming
__________________
I Support/Recommend GST Motorsports(STi/EVO), Buschur Racing, Aaron@Enlish Racing's Tuning, Mellon Flash Tuning, LIC Motorsports(STi).
STill deciding on powerplants: 4g63, 4g64, or 2jzge or 2jzgte
Decisions, decisions...
Offline
Old Jun 26, 2009, 08:22 AM   #14
Silver Sponsor
Personal Sales Rating: (124)
SparkTech's Avatar
Drives: 03 evo 8
Send a message via Skype™ to SparkTech
I'd say lifting and running 10.4's is a good day at the track. Congrats on lowering your best time that also qualifies as a good day.
I definitely see a high 9 for you before the end of the year
__________________
Congrats Douglas Auto 9.97@143 first full pass | English/ETS/Jeff Bush 8.674@167 | Evosick2332/Strictly Mod 9.93@141 | M.A.P STOCK ECU HP RECORD 1053whp 721TQ | EvoDan 10.37&141MPH PRO CDI | lillev23 9.959@138.67STOCK BLOCK RECORD NON-CDI COP | [ Speedtech NZ World record 8.34@169.72 |
Innovation distinguishes between a leader and a follower.
New Product : NonCDI Sequential
Offline
Old Jun 26, 2009, 08:22 AM   #15
PATRICK B.'s Avatar
Thanks for posting up guys!
The launch was so-so in my book was just trying to make a good pass and not bog or crazy spin since it was the first pass off the trailer.
It has gone 1.5x in past runs but i feel it will take a good solid 1.4x to break into the 9.99 area that's why i'm considering a switch to 24" full slicks.
Comparing to other posted slips w/ the 6.7 1/8mi i think it would have been good for 10.2x at least.
__________________
Sponsored by :
FFTEC MOTORSPORTS
www.FFTEC.com
Quickest ET = 9.902
Offline
Tags
evo, las, patrick, vegas
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
