Go Back   evolutionm.net > Competition > Drag Racing
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 21, 2007, 01:51 PM   #31
Personal Sales Rating: (7)
AZ EVO IX MR's Avatar
Drives: 2005 Evo 8 SSL 11.86 @ 116 1.7 60' Stock turbo 26lbs
Paul, you should try the hks kansai intake manifold, i bet you would get more power.
Other than that go 2.4 with a final drive lol
__________________
Evo Sold!!
Single Turbo Supra
Online
Old Aug 21, 2007, 06:17 PM   #32
Plat Vendor
Personal Sales Rating: (140)
Mike@AwdMotorsports's Avatar
Drives: 2005 Evo RS.. 1st Street Evo in the 8's!!
Send a message via AIM to Mike@AwdMotorsports Send a message via MSN to Mike@AwdMotorsports
Quote:
Originally Posted by e.shelman View Post
What details would you like to hear? He plans on attending Maxton. This was done on gas with no juice. Mike says the car has alot more in it. The 215.9 run was on a bogged launch.
well ill be at maxton next month i hope he comes.. i saw his car on a vette site that was discussing the event.. im just amazed at the speed for a car that has horrible aeros.. in the mile, aeros are everything not just hp..
__________________
The #1 Buschur Racing Dealer in the US
Tel. 954-753-6006
AIM= mikeatawd
www.AwdMotorsports.com
  • 2003 Black Evo GSR - 8.75@163mph (US Quickest 4g63 Evo )
  • World's Quickest Evo 8 Street Car - 8.98@156mph
  • World's Quickest / Fastest Stock Ecu & Maf - 9.33@146mph
  • World's Quickest Stock Frame FP Black - 9.33@146mph
  • World's Quickest / Fastest Stock Turbo Evo - 10.21@133mph ( Most-Wanted )
  • World's Quickest Mivec Evo 9.05@157mph( Most-Wanted )
Offline
Old Aug 22, 2007, 09:48 AM   #33
Personal Sales Rating: (5)
R/TErnie's Avatar
Drives: TB Evo IX
Send a message via AIM to R/TErnie
Switch to a full coilover setup and corner balance the car.
Run less than 14psi in your slicks! I think Eric@shep mentioned this.
Work on getting air to flow OVER the car and NOT under it. A belly pan for the front and the rear of the car would work great.
Maybe a 'moly cage instead of a DOM Mild steel cage.
some1 mentioned before...lexan windows. (tons of weight to be saved there)
Your driveshaft? Are you running a lightweight shaft?
Lug nuts... see if you can get lighter lug nuts rather than steel ones. make sure you studs are only as long as they need to be.
Lighter rotors. Maybe switch to a wave rotor like the bikes use with an aluminum hat. Your brake pad material can be made to have less bite during acceleration.
switch to an aluminum exhaust instead of a FULL 3.5" Stainless steel unit.
a little math for you on weight of piping...
Comparison between 4" SS, 3" SS, and 4" AL tubing.
Weight
Stainless Steel 4" tubing is .086" thick (14awg)
Stainless Steel 3" tubing is .065" thick (16awg)
6061 Aluminum 4" tubing is .065" thick (16awg)
Circumference of a 4" pipe 12.57"
Circumference of a 3" pipe 9.43"
Density of 304 Stainless Steel (lb / cu. in.) 0.285
Density of 6061 Aluminum (lb / cu. in.) 0.098
for a 4 foot section of downpipe (assuming its straight)
4" ss.... 12.57*48*.086= 51.89 cu. in.
3" ss.... 9.43*48*.065= 29.42 cu. in.
4" Al.... 12.57*48*.065= 39.22
(4" SS) .285*51.89= 14.79 lbs.
(3" SS) .285*29.42= 8.38 lbs.
(4" Al) .098*39.22= 3.84 lbs.
Melting Points
304 Stainless Steel (Deg F) 2650
6061 Aluminum (Deg F) 1090
Aluminum Oxide (Deg F) 2054
Highest EGT (Deg F) 1700
Also...if you would've used teh TiAL housing on your 42R...bunch of weight savings. Also if you do your manifold in 16 gauge inco or 316ss...bunch of weight to be had there as well.
Liquid to AIR IC.... you have a race car right? why not use it?
Nitrous? I know you have nitrous paul. Nitrous ALWAYS picks up MPH
__________________
FOR SALE
http://forums.evolutionm.net/sale-en...l-flanges.html
Quote:
Originally Posted by My boss
If you wait until the last minute to do something, it will only take a minute.
Offline
Old Aug 22, 2007, 03:53 PM   #34
Personal Sales Rating: (0)
Send a message via AIM to DSMu4ia
Lose the mirrors.
Alignment, alignment, alignment.
Weight, while important, isn't everything.
Tape or block every orifice/opening/hole in the front of the car.
__________________
96 Mitsubishi Eclipse GST
600whp/392wtq - GT35R/TiAL .82 V-Band Housing
Sunoco 94 Pump Gas
720whp/486wtq - GT35R/TiAL .82 V-Band Housing
VP Q16 Race Gas
www.BrooksTuned.com
www.ShearerFab.com
Offline
Old Aug 23, 2007, 06:46 PM   #35
Personal Sales Rating: (1)
Paul Nelson's Avatar
Drives: Evolution 8
Weight
Melting Points
Working on allot of this just takes so much time Thankyou for the input
__________________
Extreme Turbo Systems & English Racing Got me into the 8's
-Weight-2780 lbs with me and NHRA Safety Equipment
-1.3 60ft 128mph thru the 1/8th 8.9 et & 166mph (42R)
-Dynojet 1117whp 2.0 ETS 45R Turbo Kit
[b]Proud To Be Sponsored By
English Racing - Extreme Turbo Systems- GSC - Driven Innovations- Spark Tech- AMS
End of the year highlight video
http://www.youtube.com/watch?v=PTs-VhHfosk
NW Fastest 4G63
Offline
Old Aug 23, 2007, 06:48 PM   #36
Drives: Evolution 8
Quote:
Originally Posted by DSMu4ia View Post
Lose the mirrors.
Ive been using the white ducktape to close up the front end. Im going to put some lexon on the holes on the bumper looks much better
__________________
NW Fastest 4G63
Offline
Tags
304, density, stainless, steel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
