Whats your fastest Stock turbo/stock cams trap speed?
Old Apr 18, 2005, 06:54 AM
EvilDylan's Avatar
I did a new best trap speed this weekend.
ET was 12.09 trap speed was 117.1
This is with stock cams and stock turbo and no standalone.
Old Apr 18, 2005, 08:34 AM
matt55's Avatar
D*MN , 117 mph , thats crazy , 113.1 was my best , What were your 60'' times on the 12.09@117.1 run ?
Old Apr 18, 2005, 08:44 AM
EvilDylan's Avatar
1.73
Old Apr 18, 2005, 08:47 AM
SJ EVO 8's Avatar
Was there some killer tail wind or something.That seems almost impossible without cams.What mods do you all have done???
Old Apr 18, 2005, 09:11 AM
EvilDylan's Avatar
no, actually there was a slight head wind.
mods are
intake
TB exhaust
boost controller
ECU+ piggyback I was on my race gas map
cam gears -5/-5
10.5 hotside and a fuel pump
ACT street disc.
Old Apr 18, 2005, 09:17 AM
Whoosh's Avatar
12.09 just seems incredible! What boost were you running? Having run a few times with the stock turbo and cams, 12.09 is impossible for me to get to.
Old Apr 18, 2005, 09:24 AM
EvilDylan's Avatar
i was running 25 lbs tapering to 19
Old Apr 18, 2005, 09:57 AM
Warrtalon's Avatar
Originally Posted by EvilDylan
1.73
With a 1.73 60' and 117mph, you must have missed a shift (or two), right? I've run 12.1@110 with a 1.65 60'. 117mph is good for 11.7 or so, especially with your good 60'.
Either you're capable of a much better time, or something is wrong with that mph. It seems extremely high, but it could be a nice result of race gas and crazy boost level (25psi on 16g??).
For reference, there's a guy on here with similar mods who ran 12.1@115 only after he added a 40-shot of nitrous.
Old Apr 18, 2005, 10:09 AM
EvilDylan's Avatar
uh no
if you look at dsmtimes.org you'll see that 117 is about right for the time i ran.
with a few exceptions.
110 is a very low trap for a 12.1 time no one on dsmtimes.org has a 110 trap and that low ET.
Old Apr 18, 2005, 12:48 PM
Warrtalon's Avatar
uh no
I also ran a 12.1@113 on the same car. The 110mph example was just to show the opposite extreme. 117mph has _never_ been a standard for 12.0 or 12.1 (you are basically 12.1). Buschur's Evos ran 11.65@117.8 and 11.7@116. You are way off on your ET with that MPH...or the MPH is wrong somehow.
Out of 27 times between 12.0-12.1, only 7 have an equal or higher MPH than you. Of those 7, 6 have lower 60' times than you. The one ridiculous anomaly claimed a 12.1@124 with a 1.69 60', but that's obviously not normal.
There are also 37 people with equal or SLOWER MPH with ETs between 11.6-11.99
Old Apr 18, 2005, 02:06 PM
matt55's Avatar
To add some fuel.... my time slip for my 12.09 , 1.72 60''s , 7.76@89.04 1/8 , 12.09@114.4
soo my run isnt in line with Evildylan , not trying to take anything from you
Old Apr 18, 2005, 02:21 PM
EvilDylan's Avatar
Well that day of my good runs a majority of my runs were 113-114 mph but i had two right at 117
also buschur cars make much more torque than i do, that might have something to do with it.
i only make 260 ft lbs at peak and 300 whp at 7000 rpm.
Old Apr 18, 2005, 02:30 PM
matt55's Avatar
seems odd that you would gain 3 mph from 1 run to the next ? But what do I know your whopping my as$ and you dont have cams and i do
Old Apr 25, 2005, 01:18 AM
GREDDY's Avatar
Matt, what kind of power are you seeing with your setup if you don't mind me asking.
Old Apr 25, 2005, 05:38 AM
MalibuJack's Avatar
Sounds about right.. I've run similar times with a stock turbo and no cams..
117 mathematically computes to over 400whp, but then you look at your ET.. A mathematically perfect run for 117mph should be 11.70 or so.. so if your car is making the power to trap 117, then you can possibly pick up a bit on your ET.. Sounds more like the 114 or so trap speed would be more "normal" and 117 was an anomoly..
FWIW if you can somehow sustain 21psi through redline (and your tuned for it), you should be able to break a few 10ths into the 11's pretty nicely...
Quick Reply: Whats your fastest Stock turbo/stock cams trap speed?
