Best MAP to use?
Best MAP to use?
Hey guys,
I drive a 2014 Evo MR with currently 8,000 km's on it.
Just installed yesterday:
Using COBB AP v3.
Currently flashed on Stage 2 - 93 Octane - v403
PROBLEM:
When i drive it in Manual and let off the gas when i change gears(like a manual, not ideal for the MR) it works perfectly and i can feel amazing gains.
When i drive it in Auto and dont let off the gas when it changes gears (like the sst should be able to handle) it peaks my boost at 15psi and sounds soooo bogged down and actually starts letting out air when im still accelerating.
SOLUTION?
Im going to try changing my MAF scales, using the ETS intake numbers. Maybe that will help??
Any help would be greatly appreciated!!
Thanks!!
- ETS Intake
- Turbosmart Dual BOV
- ETS Intercooler
- ETS LICP
- Ultimate Racing UICP
- AMS Test Pipe
- AMS Single Exit Exhaust
Using COBB AP v3.
PROBLEM:
SOLUTION?
Thanks!!
Its always recommended to scale your map to your intake but that should not cause shifting issues. 403 maps should not be shifting like that. Can you provide a log of a wot run through the gears?
-Chris
-Chris
I will do that. It isn't causing shifting issues exactly. The intake system isn't working correctly while in auto. That's all. I beleive at least. Haha. I'll try the scaling and rebooting ecu. Then if it still doesn't work I'll let you know. Thanks!!
So i managed to use Access Tuner Race and set my MAP to use ETS Intake tables.
It seems to have helped. I cant say its 100% though, So perhaps a trip to a tuner is in order. I would like to wait until i have more installed though. Injectors, pump, etc....
FS[Pacific NW]: 2005 Evolution MR Time Attack Build
Jhurley_EvoVIII
For Sale - Cars For Sale
Dec 12, 2016 09:53 AM
Jhurley_EvoVIII
Sep 28, 2015 04:58 AM
FS[Northeast]: Part Out! For Sale!
Evod350z
23
Dec 13, 2014 01:34 PM
Boost Demon
47
Jun 9, 2012 05:07 PM
