Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Brakes and Suspension
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 7, 2009, 03:30 PM   #1
Personal Sales Rating: (3)
Issue with passenger front....
First off I posted this in 2 sections because I cant figure out what could be causing it. My car is a 05 Evo 8 with 59k and when I'm going 40mph I hear humming from the front right side. When I jerk the wheel like 15 degrees right it goes away and when I let it straight it starts again. There is also popping noises over bumps but I think those are bad shocks. Could it be the shocks causing this issue?
Offline
Old Aug 7, 2009, 03:42 PM   #2
EvoM Super Moderator
2002 Ford Focus
SmikeEvo's Avatar
Drives: 2002 SVTF, 2006 Honda Aero, 2008 Lancer GTS, 2006 Galant GTS
Send a message via AIM to SmikeEvo
Check to see if the strut is leaking fluid. If so, strut is toast. Replace. The upper strut mount can also fail over time. Not too bad of an idea to replace after a while too.
And do NOT double post.
__________________
***New Points System and Forum Rules***
Problem with a post or thread? Use the report post button - triangle sign on the bottom left.
SmikeEvo Racing Blog
Sponsored by:
Swift Springs
GTWorx
Offline
Old Aug 7, 2009, 03:46 PM   #3
The car has an o2 housing, boost controller and a tbe. Do you think I should just try visiting a dealer so they check it out under warranty?
Offline
Old Aug 7, 2009, 04:20 PM   #4
2002 Ford Focus
SmikeEvo's Avatar
http://en.wikipedia.org/wiki/Magnuson-Moss_Warranty_Act
Cannot void that work, has nothing to do with the engine.
__________________
Sponsored by:
Swift Springs
GTWorx
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
