Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Brakes and Suspension
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 4, 2009, 06:28 AM   #1
Personal Sales Rating: (2)
Drives: Evo IX
Added Cusco braces and now understeers....now what?
Add the Lower Arms Bar Version 1 and 2, and Front Center. Currently, I have Ohlins coilover - lower about 0.5" from stock height...so don't think that the geometry is off. I have stock front tower brace and DC Sport rear tower brace. This is an Evo 9 with setting Tarmac on road course. The tires are Continental SportContact 2.
Before adding the brace, it has a minor understeer. Now, the understeer is very noticeable...same shock/center diff setting.
I brake/double clutch downshift....turn the wheel....trailbrake into the corner...hit apex.....gently increase the gas. Standard procedure. The understeer exhibits heavily in the turn in.
Any idea?
Increase front sway bar size?
Add their complete brace kit?
Change the front tower bar?
Increase front Camber?
I would've expected increase rigidity in the front would help the front to get more grip, inducing oversteer....
Offline
Old May 4, 2009, 07:51 AM   #2
Personal Sales Rating: (14)
Ludikraut's Avatar
Drives: 03 Evo VIII, 04 A8L, 00 A4 1.8T, 08 R32, 82 YF750
You may want to also ask this question in the "Evo Tires, Wheels, Brakes & Suspension" or "Motor Sports" section.
I didn't notice you saying anything about currently having upgraded front or rear sway bars or any other suspension mods. Have you considered replacing the rear trailing arm bushings and installing a rear bump-steer correction kit? I suppose that for the time being you could adjust your front rear camber settings (i.e., more front camber, less rear), or adjust your tire pressures.
l8r)
__________________
"Learning is the beginning of knowledge ...
knowledge is the beginning of understanding ...
understanding is the beginning of wisdom."
Suspension book for sale, NEW
Quote:
Any society that would give up a little bit of liberty to gain a little bit of security will deserve neither and lose both.
- Ben Franklin, Thomas Jefferson -
Last edited by Ludikraut; Jul 21, 2009 at 03:52 PM. Reason: remove shameless ad :)
Offline
Old May 17, 2009, 02:31 PM   #3
Personal Sales Rating: (1)
rovanpera's Avatar
Drives: 9 mr
i have NOT seen much of an effect on under/over steer by installing rear heim joints for end links and whiteline bump steer.
check toe!!. re-check alignment for camber, you did not post what it is and it may have been affected by the mere process of installation.
also, i am not trying to be a dick, but you may be experiencing slower turn in more, as the car is now a bit more direct in the steering feel (since you made it more rigid).
Offline
Old Jun 2, 2009, 06:48 AM   #4
jplgsx's Avatar
Drives: 2006 Evolution IX MR SE
Send a message via AIM to jplgsx Send a message via MSN to jplgsx
Before you do anything else you MUST have the car's alignment checked. The toughest thing to find is a good alignment shop with calibrated alignment eauipment, but it will make all the difference in the world.
Alignment WILL affect your car's handling.
Since you have lowered your car did you compensate for the lowered roll center with a Whiteline roll center kit? Lowering your front suspension will bring the roll center BELOW GROUND and even though you have a lower center of gravity it will understeer. The kit bring it back up above ground level.
What you want is about -2.00 degrees camber on the front with zero toe and -1.7 degrees camber on the back with 1/16 degree toe. Try that before you do anything with anti-roll bars.
The Whiteline rear bumpsteer kit is also a good idea.
Offline
Old Jun 20, 2009, 11:38 AM   #5
Personal Sales Rating: (0)
Drives: EVO
Well, before the braces......the body flexes to compensate for the force that put on the outer wheels. Now, the body is stiff, therefore more force will transfer to the outer wheels..so it's easier to break loose. There are few options..... Get a bigger rear sway bar, change the camber settings, and coilover settings......
Offline
Old Jun 20, 2009, 07:09 PM   #6
Personal Sales Rating: (5)
Drives: '06 GG MR, '98 S14
Sell me your coilovers that will solve your problem!!
__________________
finally... an evo with no decel noise
340/336 uncorrected Dynojet (Shiv tune) with exhaust
385/336 corrected Dynojet (JohnBradley tune) with BBK
Offline
Old Jul 1, 2009, 04:40 PM   #7
AKEVOIX's Avatar
Drives: loser sellout
+1 for good alignment
Offline
Old Jul 3, 2009, 11:32 PM   #8
NWM_Tech's Avatar
Drives: Honda Civic
pushing means the rear end is getting better traction than the front
improve the front,
concur with need to align, factory settings may/will not apply
dropping 1/2" will change geometry and align
some of the strut braces are more for looks than anything, if it doesn't go straight across it's not doing much. The factory front works because it's straight from the towers to the firewall. The front ones that go from tower to tower with a kink in either end to clear the engine are most likely not doing much.
sway-bars are a last resort but sometimes necessary.
__________________
Mitsubishi dealer tech
Pacific Northwest
the funniest thing about this message is that by the time you realize it doesn't say anything it's too late to stop reading it.
Offline
Old Jul 3, 2009, 11:53 PM   #9
Personal Sales Rating: (4)
Pure EvoIX's Avatar
Drives: 2006 Evo IX GSR GG
Send a message via AIM to Pure EvoIX
What are your springs rates? To make car rotate better, you want to have the rear to have higher spring rate than front. 7k/8k, 8k/9k 9k/10k is a safe DD setup for Ohlins.
Obviously have the rsb setting, tire pressure to match and fine tune as well as dampening. +1 to alignment, makes a big difference. Camber: -2.5/-1.4 Toe 0/0 or 0 / -1/32 . Try that.
__________________
GST (MD)
294 whp/ 290 wtq
22.8psi on 91oct
Power
Megan Racing TBE---Nisei LICP---K&N Drop In Filter---Walbro 255 FP---RC 750cc Injectors---EIP Boost Pill---Dyno Tuned
Suspension
Muellerized JIC FLT-TAR Coilovers 7k/8k---Perrin 25mm Adj RSB---Perrin Rear Endlinks---Cusco Rear Trunk Bar---Whiteline Rear Bumpsteer Kit---Whitelines RCA Shock Bushing---Energy Suspension Rear Trailing Arm Bushing
Offline
Old Jul 14, 2009, 03:31 PM   #10
DEVO330's Avatar
Location: MotorSportRanch/DFW http://www.ntexasevos.org/
Drives: '03 Evo8, '91 Turbo Miata, HondaHelixScooter, '76 GMC RV
I added 1mm to the rear sway bar size when i first started tracking my 8
that added just a little oversteer that i needed to learn the car...
since then I've removed it and love the stock handling
adding all of the stuff up front evidently gave it more 'push' as i would of expected
Offline
Old Jul 21, 2009, 01:35 PM   #11
Drives: Evo IX
Thanks for the responses. Since then, I'm going to remove all the braces back to where it was.
I got 1.7 deg camber on the front, 1.1 deg in the back.
My spring rates are 12k front 10k rear - they are factory Ohlins rate. Ohlins said I got the early Road and Track kit that was made in Sweden. So the valving and rate are different than the current Road and Track kit.
Offline
Old Jul 21, 2009, 01:46 PM   #12
Pure EvoIX's Avatar
^ so there is your problem. Try flipping the springs around if they are the same diameter. You want the rear spring rate to be stiffer than the front in order for car to rotate better.
__________________
GST (MD)
294 whp/ 290 wtq
22.8psi on 91oct
Power
Suspension
Offline
Old Jul 21, 2009, 03:53 PM   #13
Ludikraut's Avatar
^ Bingo.
l8r)
__________________
Offline
Old Jul 21, 2009, 06:02 PM   #14
Personal Sales Rating: (-3)
word...10k/12k here and its amazing.
Offline
Old Jul 22, 2009, 02:39 PM   #15
solng-V8's Avatar
Drives: EVO 8 MR, Datsun 510 SR20DET
No, no, no! Are you kidding? Swapping around the springs is going to make the understeering even worse!
Just to keep this simple and not going into pages of detail we can all do this Mythbusters style. Now I'm sure all you guys have Gran Turismo or Forza or some other racing simulator that you can change suspension settings on right? Most of the simulators noadays represent very closely what happens in the real world.
- Ok, First race your car (preferably an Evo) around a twisty turny technical track. The more turns on the track your racing on the easier to see results on smaller changes to the car's setup. Race around the track for at least 20 laps and record your best time.
- Go into suspension settings and lower the spring rate, compression and anti roll on the front of the car (usually at the same rate aggressively but not to the limits). Do the opposite to the rear of the car. Stiffen up everything on the rear. Go out and try to achieve a best time with this setup and record.
- Now go back into suspension setup and stiffen up the spring rate, compression and anti roll on the front of the car (aggressively from the default stettings). Do the opposite to the rear of the car. lossen up everything on the rear of the car. Go out and try to achieve a best time with this setup and record.
Let me know what your results are.
Offline
Tags
510, bumpsteer, cusco, datsun, evo, evolution, inside, ix, kit, lancer, lifting, rear, road, trailing, understeer
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
