Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Brakes and Suspension
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 11, 2009, 05:56 PM   #1
Personal Sales Rating: (0)
Drives: 2006 EVO MR
Slid into a curb..
I was misbehaving in the rain last Thurs. and managed to slide my 2006 MR sideways into a curb. The left rear wheel took a pretty substantial hit, but surprisingly enough – I don’t think it’s bent. The curb appears to have just caught the edge of the rim and the tire took a good portion of the impact - I had to deflate the tire to clean out the curb pieces that got crammed in there.
Now have a few unpleasant developments; the car no longer tracks perfect - it pulls slightly to the right - and on right turns I hear a slight grinding coming from what I think is the left rear..
So the question is what have I done? Can an alignment possibly cure the tracking issue - or is this wishful thinking? Maybe a wheel bearing/hub causing the grinding??
Any constructive advice appreciated!
Offline
Old Apr 11, 2009, 06:01 PM   #2
Personal Sales Rating: (8)
wizzo 8's Avatar
Drives: 05 electric Blue Evo, 04 Blue R1, 95 Nissan pickup lowrider
Send a message via AIM to wizzo 8
You probably have a bent lower control arm and possibly spindle.
__________________
3" turbo back exhaust , Forge MBC, Walbro 255 fuel pump ,Helix lower I/C piping, Exhaust Manifold with o2 housing, Synapse BOV , huge I/C, 272 HKS cams, Head studs, Buschur Upper i/c pipe, Braille mini battery, Buschur intake pipe with cone filter, ported and polished intake manifold, 65MM Throttle body, Meth with 50/50 mix, 30psi custom tune by Chris Black at AMS
380WHP
392WTQ
JDM rear bumper
Offline
Old Apr 11, 2009, 06:18 PM   #3
Drives: 2006 EVO MR
Wizzo - thanks for the info - I'll disassemble to see what's going on with the grinding - but for the lower control arm/spindle geometries - is trying to have it aligned even an option?
Offline
Old Apr 23, 2009, 08:17 AM   #4
Personal Sales Rating: (5)
2002 Mitsubishi Lancer Evolution
MadCrix's Avatar
Drives: Mitsubishi Evolution VII GSR
alignment shop will tell u exactly whats bad if u bent anything
__________________
HKS DP,
HKS O2 Housing, HKS Manifold, Apexi N1 Test Pipe & Cat Back exhaust, Apexi Power Fc,
Snow Performance Meth Kit, Walbro Fuel Pump
Low Boost 16psi
High boost 21psi
252 WHP 248 WTQ before ecu and meth
307 WHP 306 WTQ after ecu and meth
Stock Internals
Offline
Old Apr 23, 2009, 08:26 AM   #5
Personal Sales Rating: (12)
Skylineracer's Avatar
Location: Port Orange, FL Lived: Daytona Beach, FL Lived: Clifton, NJ
Drives: Evo IX SE Tarmac Black Drove: Thunder Grey Lancer ES Flies: C172sp Nav III
Send a message via AIM to Skylineracer
if its bent in the back i think u have to just replace parts and chk for damage at where they bolt up
__________________
2006 TB IX SE
Mod List:
1-Up Air Freshener
Agency Power SS Clutch Line
AMS Front Motor Mount \\ Cam Gear Mount
Buschur Inline Boost Controller \\ 3" Cat-Back Exhaust \\ 5-Speed Shifter Bushings
DBA 4000 series rotors
EBAY Test pipe
Energy Suspension Shifter Tower Bushings
AMSOil Cone Filter
Megan Racing DP
Prosport Gauges
Racing Brake ET500's
Rexpeed VG \\ Gurney Flap
Synapse Synchronic BOV
JestrTuned
Offline
Old Apr 23, 2009, 08:47 AM   #6
Personal Sales Rating: (1)
Drives: BBY Evo VIII
Anytime you take a hit like that you need to replace your hub. It might not be grinding at the moment but it will start shortly. You can usually tell what's bent by looking and comparing it to the other side. I'd replace what's bent then take it to an alignment shop and have it aligned. I used to do crash jobs like that on Lexus's all the time. Colorado+people over confident in 4WD/AWD=$$ for me. Good Luck. Post up some pics if you want some help diagnosing
Offline
Old Apr 23, 2009, 09:15 AM   #7
MadCrix's Avatar
yup simply jacking car up adn lookign underneath at teh both sides will tell u clearly if u bent anything
__________________
HKS DP,
Low Boost 16psi
High boost 21psi
Stock Internals
Offline
Old Apr 23, 2009, 09:32 AM   #8
Personal Sales Rating: (23)
yahu's Avatar
Drives: 06 Evo MR
I did something like this last year. There were 4 of us at a 4-way and no one would go so I got impatient and poked it a little too much and proceeded to slide into the opposite curb with my right rear. Nasty damage to my rim but had a local shop fix the rim (they had to weld material since it was banged in so bad) and do an alignment and thankfully that was the only damage.
Offline
Old May 12, 2009, 03:04 PM   #9
Drives: Evolution 8
Send a message via AIM to point&shoot
I did the same thing (but the right rear wheel) when I first got my Evo and didn't know how to drive it.
My damage included smashing one of the vanes on the axle into the abs sensor that uses the vanes to detect axle rotation speed. Destroyed the abs sensor and broke one or more vanes. New axle + new abs sensor.
There is also a sub-frame that the lower arm bolts into. It's held to the frame by about 8 bolts. It can be shifted to the left or right by an impact. Once that happens, you'll never be able to get enough camber on the side that took the hit. You have to loosen the bolts and bang the sub-frame with a rubber mallet towards the side where you hit the curb, then tighten it back up.
I doubt you bent a suspension link. Those things are stronger than a lot of other stuff you would damage first, like the wheel bearings. What you probably did is rotate the camber adjustment bolt and lose all your camber. You may also have damaged the off center washer that goes in a pair of slots and is how you adjust your camber. You can see this set up by looking under the rear bumper. You should probably replace the camber-adjustment bolt (the off-center washer is an integral part of the bolt). It's cheap and easy. They get stripped anyway, by alignment shops overtorqueing them, since the are shaved flat on one side, to fit in the D-shaped hole in the off-center washer.
Speaking of the wheel bearings, I had to replace mine in the wheel that took the hit about 1 year after that. There were no symptoms of bearing damage at the time, but the hit shortened the life of the bearings. All my other wheel bearings are original after 6 years.
Hope this helps.
Mike
Offline
Old May 16, 2009, 12:47 PM   #10
Personal Sales Rating: (11)
tscompusa's Avatar
Drives: 04 evo 8
I just posted a thread regarding grinding from left rear. Pull the wheel off and the dust cover and check everything out. The grind I had was occuring from one of the ebrake springs unsprung. just a thought.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
