Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Brakes and Suspension
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Dec 3, 2008, 08:18 AM   #1
Personal Sales Rating: (2)
lan_evo_mr9's Avatar
Drives: 88590715
wheel size advantage
Is there a benefit to running an 18" wheel over a 17" wheel as far as driving dynamics or weight transfer? I'm trying to decide on a wheel setup for the track and I'm thinking the RPF1 17-8.5 or NTO3M 18*9.5. Obviously the rpf1 are a lot lighter and I was thinking that would be better. Not using a big brake kit or anything- running DBA5000 with race pads. Just curious on the logic behind running a bigger wheel is. Not talking about wider but overall diameter.
__________________
E85 duel tephra V7 map/ J O T switch/ Fast Freddie UEGO harness adapter/ GM 3 port and some other stuff
Attempting SD in a couple of weeks
Quote:
Originally Posted by leethaxor
My motors always were more tolerant to detonation when I ran with blown headgaskets. They were always faster.
Offline
Old Dec 3, 2008, 08:24 AM   #2
2003 Mitsubishi Lancer Evolution
casper980's Avatar
Drives: '03 Evo VIII, '91 240sx HB
17 x 9.5'' with 255 40's RA-1 would be nice. Stretching the tire over the larger wheel will give you a larger contact patch and is recommended by various suspension tuners for maximum grip. Oh, the RPF-1's are the best bang for your buck rims when it comes to light/strong, and yes the come in 17x9.5. To run that rim you may have to roll the fenders
Offline
Old Dec 3, 2008, 08:32 AM   #3
Personal Sales Rating: (4)
Protostar1's Avatar
Drives: 2006 Mitsubishi Evolution SE, 1970 Porsche 911T
The supposed advantages of running a larger diameter wheel is to firm up the side wall (essentially by making it smaller) and allowing for less slip angle between the rim and the ground. While this will always be the case with larger rim with smaller sidewall, much of that performance gain can be quickly canceled out and resulting in a worse performing rim/ tire if the rim is excessively heavy resulting in a significant increase in unsprung/ rotational inertia. Hope some of that helps
__________________
350 awhp 321 awtq @ 24.5psi on 93oct (SAE Correction)- AMS Tuned
- ETS 4" IC - ETS LICP - ETS UICP - ETS Intake - Perrin Filter -
- BR 3" TBE w/ test pipe - Buschur o2 Housing -
- AMS MBC -
- ETS Battery - Walbro 255 - S-M DC3 - ETS Radiator Hose -
- EnduraTech Coilovers (7k/9k)-
- AMS Brake Ducts - Hawk HT10/ PF Metallic Z - Technafit SS lines -
- Enkei RPF1 - Nitto NT05 -
- APR Splitter -
- Motul RBF600 - AMSoil -
- Stri Gauge -
Offline
Old Dec 3, 2008, 09:29 AM   #4
Drives: 88590715
Absolutely- thanks for the info. My mind is made up.
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
