Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Brakes and Suspension
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 6, 2008, 09:33 AM   #1
Personal Sales Rating: (1)
peteformance's Avatar
Drives: Evolution IX
Asking For Some Advice......On handling
Here is a video of me racing at a track Last weekend and I did pretty could time...Others were doing 55 sec track records form other evos 2.3 and other subarus..They dont have classes everything is accept all open... So you can understand this is greece...So the only thing is i want your opion on what is you see. My time was 56.6 ..And this track is my third time others have raced here since 2005 so there is already a disadvantge...I have on my car Toyo R888 255/35/18 with work cr kai 20 offset and 18x8.5 plus KW 3 suspension and 35psi cold front and back...I had a little oversteer... Plus I was trying to set the car before i put it in the corner as you can see..I try to place it then push it..that is my way...I bought swaybars white line front and back adjustable....Should i put them on or only the rear....and stock front...thanks for your help
http://www.youtube.com/watch?v=85AT4ry22j0
__________________
2.3 arias pistons,cosworth rods, k1 crank 100mm,Precision 6262 billet,AEM EMS PNP,1000cc prescion,KLEFORD CAMS 272,Supertech Valvetrain 1mm oversize,TUBLAR MANIFOLD AFI TURBO,Tail EXTERNAL 44MM,defi gauges,XYZ SUSPENSION,Carbing bars,18X10 AME TM02 CAR IS ALL SIEBION.
LESS10 is a scam artist becarful
http://www.peteformance.gr/ check out my website ...
http://www.sparktechignitions.net/
http://www.afiturbo.com/store/
www.nolimitmotorsport.com chris is my man
www.awdmotorsports.com
Offline
Old Nov 7, 2008, 02:09 PM   #2
Personal Sales Rating: (2)
Killboy's Avatar
Drives: '05 EVO VIII, '02 Dakota R/T 5.9L, '06 GSX-R 750, '04 Ninja 636, '05 Husqvarna SMR450 & SMR510 Supermotos, Sikk MX 150cc Minimoto
Have you checked your alignment settings?
It's possible (probable really) that your suspension geometry is bad now from installing the coilovers which, I assume, lowered the car. If you run the suspension very tight so there is little travel, and align the car with aggressive/race settings, it's not as big of a problem. Have you considered something like the White Line Roll Center correction pieces and Rear Bump Steer correction pieces?
__________________
Best Regards,
Darryl Cannon
killboy.com
My Evo Registry
Offline
Old Nov 8, 2008, 02:45 AM   #3
No i dont know about the white line roll center correction pieces..can you please send me the site to see it..And I have now on the car 4cm lowered and 3 cm rear plus my aligment is 2.5degress camber fron and rear 1.5degress and front toe is 0 and rear toe is zero....
__________________
Offline
Old Nov 8, 2008, 07:54 AM   #4
Personal Sales Rating: (21)
Drives: 05 element, 03 evo (mutating)
Pete, looks to me like you are doing well. I am surprised that your car doesn't push but then your coilovers may be tuned for that.
a two inch drop in front may be a bit much, for sure do the roll center fix, or if you don't mind, try raising the front a cm or so. There is a point at which lowering the front causes more harm than good.
I was impressed when I raised my car from being lowered (got tired of scrapping the bumper on ramps). I also installed the roll center correction kit, between the two it turns some better.
A second or two off the mark is real good. It may be that a ride with one of the leaders would help as much as anything else.
Offline
Old Nov 11, 2008, 07:08 AM   #5
Thanks very much for the good words i need to here some expert advice...Like I asked I am waiting to put on the sway bars white line front and back and I am going to lift the car up 1cm...I see that my car leans too much in to the corners and when i stiffen the front the car seems like it corner better...Plus I see that alot of people fix there rear diff....At TTP does that help alot of the front plowing....I want to make my car into a train on rails...then i can kick some A$$....
__________________
Offline
Old Nov 20, 2008, 05:18 AM   #6
Quote:
Any other opions????It would really help
__________________
Offline
Old Dec 14, 2008, 10:51 AM   #7
ANyone else with a good opion????thanxs
__________________
Offline
Old Dec 15, 2008, 06:15 PM   #8
Personal Sales Rating: (6)
18bora's Avatar
Drives: 01 Jetta 1.8T
A go cart will be a lot more fun on that trak than the EVO
__________________
06 EB IX 13.0@102.7 Bone Stock.
Track Videos NJMP, WGI, Pocono
Offline
Old Dec 21, 2008, 04:12 PM   #9
EvoM Super Moderator
Personal Sales Rating: (3)
2002 Ford Focus
SmikeEvo's Avatar
Drives: 2002 SVTF, 2006 Honda Aero, 2008 Lancer GTS, 2006 Galant GTS
Send a message via AIM to SmikeEvo
1. Alignment settings - did you get corner balanced? Those tires like more camber too.
2. Roll Center Correction Kit
3. Play with tire pressures.
4. Seems you were off line and speed in some turns. Corner entry and position plays into how the car reacts both mid and exit.
__________________
***New Points System and Forum Rules***
Problem with a post or thread? Use the report post button - triangle sign on the bottom left.
SmikeEvo Racing Blog
Sponsored by:
Swift Springs
GTWorx
Offline
Old Dec 21, 2008, 04:16 PM   #10
Personal Sales Rating: (13)
Sharkbite2000's Avatar
Drives: 2006 Evolution IX, 2006 Range Rover Sport SC
Nice run use it all around I just got robi spec he did rear trailing arm bushings front and rear sway bars but you have to adjust them so you get the right feel.
__________________
AMS BUILT 2.3\GT950R
620awhp pump 93 octane all day!!
788awhp C-16!!
Import Tuner baby!!
http://forums.evolutionm.net/evo-sho...e-release.html
She's for SALE!!!http://forums.evolutionm.net/sale-ca...-2-3-950r.html
Offline
Old Dec 21, 2008, 06:54 PM   #11
Personal Sales Rating: (37)
Blue Evo 8's Avatar
Drives: a ~500 AWHP 05 LY EVO 8 like a grandma
Send a message via AIM to Blue Evo 8 Send a message via Yahoo to Blue Evo 8
That track looks small, with a lot of tight turns
Offline
Old Jan 8, 2009, 01:33 AM   #12
Personal Sales Rating: (0)
Drives: evolution 8
in my evo 8 problem come when i m on high boost or heavy braking a nosic come on front right wheel . wheel aligment is perfect . suggest what shoud i do ?
Offline
Old Jan 28, 2009, 01:43 PM   #13
Quote:
it is a track for racing karts...it small andvery technical...I have raced there around 3 times other guys are there from 30-100 times...the track is 2 hours away from me,....But here where i live is a track i rule...I am waiting for the race to come here...then i will let them have it....HAHAHA
__________________
Offline
Old Jan 28, 2009, 01:48 PM   #14
Thankx for the advice and you are right on my speed in to the corners...I need better postioning...I try to brake aim then gas it through...I always try to give it just right...And the tires i have i am still looking for the best psi...other say they need more air and others say they need little air...dam it..I am going to do what ever i think is best for my car..and now this week i am taking off the KW and putting on a new set of Coilovers with camber plates called XYZ...I am going to be dealer here in greece for these coilovers and they are awesome..I have tried them on two other evos here in greece and the are train on tracks....Plus i am going to put on my new white line sway bars front and rear and I will give front 3 camber and rear 2.5 camber...I am going to make it a train.......
__________________
Offline
Old Jan 28, 2009, 01:49 PM   #15
Quote:
I want to get rm bushings too how much did it cost you?????
__________________
Offline
Tags
2008, 450, alignment, camber, coilovers, corection, husqvarna, lancer, lowering, mile, mitsubishi, performance, quarter, siebion, smr, wwwpeteformancegr, xyz
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
