Oct 1, 2008, 05:41 AM
Personal Sales Rating: ( 5)
Drives: 1997 Honda Prelude 2003 EVO VIII
Hard turn causes knocking/popping/skipping
__________________
AMS Stage 1,2,3--HKS 272 I/E Cams--
Turbosmart BOV--Greddy turbo Timer--
RPS Clutch 6-Puck disk--Hallman MBC
Fidanza Cam gears--ARP Headstuds
Shep stage 1 T-Case--w/TTP tune
339 AWHP 302Q
GET YOUR AMSOIL HERE!...
http://www.lubedealer.com/ExquisiteDetails/
Offline
Oct 1, 2008, 05:50 AM
Personal Sales Rating: ( 26)
Drives: 03 TB VIII
Check your lugnuts
CV Joint/Axel
Tie Rod Ends
Ball Joints
TC
__________________
4WS TUNED VIII
Quote:
Originally Posted by Evoryder
Its' the turbo punching out for the day
Offline
Oct 1, 2008, 05:55 AM
Axles were changed last night. The whole assembly. Lugnuts? When I took both front wheels off the acutal lugnuts looked ok and the studs were in there good and tight. Unless I'm missing something. If I am, please inform me on what to look for specifically.
__________________
339 AWHP 302Q
Offline
Oct 1, 2008, 06:07 AM
2003 Mitsubishi Lancer Evolution
Drives: Evolution VIII
i was hearind a clicking or creaking noise from my front driverside wheel and found out it was my stabilizer bar linkage on the end of the bar was loose
__________________
Evolution VIII llllll
AEM / Hallman / QTP / ETS / EXEDY / AMSOIL / AMS / Speed Source / Kelford / GSC / Supertech / APS / 4WS TUNED!
MY EVOLUTION VIII
Offline
Oct 1, 2008, 06:22 AM
bump for more thoughts.
__________________
339 AWHP 302Q
Offline
Oct 1, 2008, 06:35 AM
Theres gotta be someone who went through this. I can't be the first.
__________________
339 AWHP 302Q
Offline
Oct 1, 2008, 07:29 AM
Grasping at straws here. Trying to get a game plan for when I get out of work. I wanted to get this fixed by this weekend to go to Orlando.
__________________
339 AWHP 302Q
Offline
Oct 1, 2008, 07:47 AM
Personal Sales Rating: ( 0)
A simple test is to jack the front end up and spin one front wheel. The other should spin backwards the same. If it doesn't or skips then the front diff is broken. Very common on an 03-04
Offline
Oct 1, 2008, 08:09 AM
Thanks for the input. That will be another test I do after work.
__________________
339 AWHP 302Q
Offline
Oct 1, 2008, 09:07 AM
Silver Sponsor
Personal Sales Rating: ( 97)
Quote:
Chris, i think jshepherd is right, i was thinking front diff th way it sounded when i was there saturday with you, do the test he says and it might lead you in the right path.
i think this is John with Shep transmissions,,, he will be the one i would send the transfer to if there was a problem like that.
__________________
Buy AMSOIL directly from our web site or PM us for direct pricing:
http://www.lubedealer.com/order/
Get Your AMSOIL @
-AWDmotorsports in South Florida
-TTPengineering in Central Florida
-Fynetune Performance in South Florida
-Brevard Super Bikes in Melbourne Florida
-Henrry's Pit Stop in the Saucier City, MI
-Harrison complete auto service, in West Orange City, NJ
-Ultimate CC, in Peekskill NY
-Performance Specialties, in Tucson AZ
Offline
Oct 1, 2008, 09:27 AM
I'm hoping its not something expensive...something I can fix and be able to take it this weekend.
__________________
339 AWHP 302Q
Offline
Oct 1, 2008, 09:33 AM
Personal Sales Rating: ( 4)
Drives: 2006 EVO IX, 95 Talon TSi AWD
CHECK YOUR SWAY BAR BUSHINGS!!!!!!!!!!
if its hard to tell they are warn, on the sway bar if its really clean within 1 cm on each side of the bushing they need to be changed
Offline
Oct 1, 2008, 11:23 AM
Ok...let me make sure I get this right...both wheels off the ground and they should be able to spin 360 degrees? If so then I have an answer. Last night car was in neutral, both front wheels off the ground, could not spin the driver or pass side wheel a full turn. Got a 1/4 turn out of it max.
__________________
339 AWHP 302Q
Offline
Oct 1, 2008, 04:12 PM
Personal Sales Rating: ( 14)
Drives: 06 Evo RS
hey chris i wanna say that when you spun the tire yesterday the pass side turned as well. but i'm not totally certain. might want to check it again.
__________________
Mods:
JunB.L - Espelir - Perrin HFC - K&N - Forge MBC - Walbro 255 FP - Advans
Prosport Amber/ WhiteBoost gauge - GTWorx Springs - 17" Rota Boost - LICP
LC-1 o2 - ETS air filter kit - ACT HD clutch/Flywheel - SpoolinUp COP kit - Tuned by Mellon
12.541 @110.20 and 2nd place in show LOL
312 whp - 312wtq DLL
306 whp - 320wtq DynoDynamics AWD dyno
Online
Oct 1, 2008, 06:00 PM
Personal Sales Rating: ( 28)
Drives: 06 IX MR
Did you have all 4 wheels off the ground?
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
