May 12, 2008, 03:47 PM
Personal Sales Rating: ( 0)
Drives: Evo VIII - blew by u
replacement brake pads
it's getting time i change my oem brake pads. i have done the research and it seems like hawk hps are the best bang for the $ (i don't have). i am deciding between the hps (HB453F.585 & HB180F.560) and the performance ceramic pads (HB453Z585 & HB180Z560). any thoughts? pls post asap so i can make decide once and for all.
any thoughts on other pads you think are better in this price range or cheaper (<$200)? pls let us know. thanks in advance!
Offline
May 12, 2008, 05:37 PM
Personal Sales Rating: ( 4)
Drives: Apex Silver IX
How about the Ferodo 2500's?
I'm planning on getting these in the next couple of days...been reading good things about them.
Check out raceshopper.com for good deals.
__________________
-Brett-
---Apex Silver IX---
Jun BL Catback - K&N Drop in - Buschur MBC @ 23lbs - Basic Flash
292whp 294wtq - Mustang Dyno
12.31 @ 113 - April '07
Offline
May 12, 2008, 10:54 PM
thanks for the post. not heard much about ferodo. wish there was a way to compare these products head to head with their specs - coeff. fric, temp range, etc. then it would be easier to select a brand and type within the price you want.
Offline
May 13, 2008, 11:52 AM
Personal Sales Rating: ( 25)
Drives: LY 05--sold! 08 FJ Cruiser
get the ferodo's (ds2500). I hear they are the best in terms of street use. Hit up the vendor "Ravspec"
__________________
20g 5blade /// bigric09 failure tune
12.2@117 1.9 60ft 7.9 1/8th mile on stock clutch and 93
Offline
May 13, 2008, 12:50 PM
thanks! anyone else have an opinion???
Offline
May 13, 2008, 01:25 PM
Personal Sales Rating: ( 7)
Drives: Dust collecting boosted Civic, '03 Evo8, 09 Audi A3
i'm trying centric posi quiet brake pads.
100 bucks shipped for F+R- don't expect anything above OEM performance
__________________
BOOST doesn't get you laid. Roofies and some creativity does however
*STOP* - selling something with an "Easy fix" if it's easy, just freaking fix it then sell it!
*STOP* - posting stock evos, just because you took your wing off it's not new thread worthy.
Offline
May 15, 2008, 07:27 AM
Drives: GG 05 Evo MR, GG 08 Outlander XLS
I put the Hawk HPS pads all the way around on my Evo 2 weeks ago. I noticed an immediate increase in brake performance (better feel, shorter stopping distance) and a huge decrease in brake dust. I don't know if anyone else thinks the stock pads throw off a lot of dust, but it used to piss me off. I'm very pleased with what the HPS pads have done for my car, and will stick with them when it's time to swap em out again.
__________________
Turbo. THE replacement for displacement.
Turbo XS short ram, NGK iridium plugs, Geddy Profec-B II, Tanabe DP, 3" HFC, AMS cat back, Walbro 255, SS brake lines, SS clutch line (restrictor removal), Hawk pads, Weapon R catch can. Mellon tune in progress.
Offline
May 16, 2008, 10:57 AM
Drives: Stock EVO
Hi, About brake pads replacement. For the first Brake Pads replacement, is it the front pads, then afterward front and rears?
Offline
May 16, 2008, 11:03 AM
Drives: 2003 Mitsubishi Lancer Evolution
hit up EvoBrakes he'll hook it up
Offline
May 16, 2008, 11:10 AM
Drives: Stock EVO
Thanks, but I wanted to know what to expect on my first brake job. Cars usually wear pads first on the front, then the rears. Can anyone tell if this is the same with the Evo?
Quote:
Offline
May 16, 2008, 12:03 PM
Personal Sales Rating: ( 12)
Drives: Yes
Quote:
I have the Hawk HPS and they are working for me. I have about 330 HP and run a few HDPE's, and they seem to be holding up well. I'm also planning on getting cooling ducts which should help some too.
They only squeal right as I come to a slow stop, but not bad.
I know another guy who ran the HPS with a little more HP (but only a second less time) and they disintegrated.
So I guess it depends on how hard you plan on running them.
hope that helps
Offline
May 16, 2008, 12:37 PM
Personal Sales Rating: ( 34)
Drives: Evo 8
I have used the hawks & ferrodos.
The 2500s are with out a doubt the best. They are a bit more expensive but are a better product. They are much more quiet also.
__________________
Tuned By Lance at MGW
505 WHP at 25 pounds on 93 & meth
559 WHP at 29 pounds on Race gas
DD stock block
Revised numbers-
527 WHP at 26 pounds on 93 & meth
579 whp at 30 pounds on Race gas
Offline
May 16, 2008, 12:49 PM
Personal Sales Rating: ( 3)
Drives: 2006 Evo IX MR SE -- 2006 Honda Accord Ex-L -- 1998 Honda Accord EX (RIP)
I don't know if you've considered this or not, but I just ordered a set of Endless SS-H specifically design for our Brembo OEM calipers. They should be in mid next week, and believe me, I'll be able to give a good assessment by the following Monday. If you're interested, I'll post up on here a review.
Quote:
Oh it's not just your opinion, the stock pads throw off more dust than a sand storm!
__________________
Stock Cams/Cat/No Boost Controller +BBK
373/309
CBRD Tuned
"My code name is Project 2501. Industrial espionage and intelligence manipulation. I've installed programs to specific Ghosts in order to maximize the strategic advantage of certain organizations and selected individuals." ~Puppet Master
私は私のコードによって住んでいる...
私はうそを憎む...
剣は私の正義である...
Offline
May 16, 2008, 12:56 PM
all input is more than welcome. seems like endless is more pricey and therefore should be higher end. let us know if this logic holds true.
Offline
May 16, 2008, 01:01 PM
who or what is evobrakes? a website/user on evom? i tried the website but doesn't seem like there's much there.
Offline
Tags
brake, distance, evo, gransport, gs5, pads, posiquiet, satisfied, squeal, stopping, tick  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
