Apr 1, 2008, 06:45 AM
Personal Sales Rating: ( 0)
Drives: Evo 9, 350z TT, 300es lexus
Under steering in Auto X
Hi guys I hops some of the pros around can help in this matter I'm getting a little of under steer in Auto X keeping in mind that my evo has HKS RS suspension Cusco Swaybars front and rear AEM front start bar and Cusco rear strut bar and anti roll front Cusco bridges... Any recommendation from your side on this matter...
Offline
Apr 1, 2008, 07:37 AM
Personal Sales Rating: ( 25)
2003 Mitsubishi Lancer Evolution
Drives: 2003 EVO-2002 WRX-2003 R6 (sold) :(
more negative camber in front, zero your toe if you haven't already done so, increase the stiffness in the rear coilovers, make your rear swaybar stiffer if you can
__________________
Rally Red Evolution 8
Offline
Apr 1, 2008, 08:17 AM
probably the camber and the toe can help, as for stiffing my rear suspension its not adjustable and the sway is already on max
Offline
Apr 1, 2008, 08:23 AM
Personal Sales Rating: ( 13)
Drives: 03 EVO, 89 ZC WAGOVAN, 98 EK, 88 LSVTEC CRX, 02 ALTIMA 3.5L
What size rims and tires are you running?? What offset???
Offline
Apr 1, 2008, 08:31 AM
Stock BBS 17"
245/35/17
Offline
Apr 1, 2008, 08:32 AM
what is a good camber adjuster brand to get from if any can u please supply me with a link.
Offline
Apr 1, 2008, 09:02 AM
Quote:
Originally Posted by I'm blue
Stock BBS 17"
245/35/17
I hope this is a typo
__________________
Offline
Apr 1, 2008, 09:03 AM
your stock eccentric bolts are good for about -2 degrees camber. if you want/need more then i know tien makes camber plates
__________________
Offline
Apr 1, 2008, 09:05 AM
Personal Sales Rating: ( 4)
Drives: 08 Evolution GSR SSS
 Wider wheels and tires will only help you
Offline
Apr 1, 2008, 09:56 AM
Personal Sales Rating: ( 1)
Drives: 06 Evo MR
Don't stomp the brake and turn in at the same time.
__________________
2009 AS Car
[X] Co-drive in a Z0K Solstice
[X] Not spending all my money on racing
Offline
Apr 1, 2008, 11:35 AM
Drives: Evo IX RS
Dial in at least -2.0 camber in front and a small bit of toe out, which will help with initial turn in. For the rear go for -1.5 camber and zero toe.
You also need to play with the tire pressures and damping adjustment on the HKS coilovers. Try higher pressures and stiffer damper adjustment for the rears versus the front and see if that helps.
Offline
Apr 1, 2008, 12:24 PM
Drives: Rally Red 2005 Evolution VIII
Quote:
Yes but in STU class you're limited to a tire width of 245 on an AWD car if I'm not mistaken.
__________________
Autocross junkie! Tuned by KevinD at EvolutionDynamics.
Offline
Apr 1, 2008, 12:34 PM
Personal Sales Rating: ( 3)
Drives: TB Evolution IX SE
Quote:
I'm surprised someone didn't mention this sooner. While a measure of controlled oversteer can be a good thing, understeer is almost never beneficial and almost always means poor technique. I think it would behoove you most to correct your technique rather than just strapping on more expensive hardware that just masks the problem.
By the way, I'm speaking to myself just as much as you.... at Sunday's AutoX down here in H-town I was plowing through turns like a Chicago salt truck!
__________________
EVOLUTION IX SE
-stock powertrain/suspension
-Bridgestone Potenza RE-01R
-Houston Region SCCA class: STB, STU, or AS
XBOX Live: RoBear 834
"I have learned the secret of being content in any and every situation..." Philippians 4 -- Now help me to live it.
Offline
Apr 1, 2008, 03:10 PM
Drives: 98 Saturn , 05 evo
Understeer could be the result of many things including poor set up and can also be driver induced or both.
Since you didn't mention any class and driving variables, the most common cause of understeer in the evo is too much front roll. The weight transfer causes the front to roll excessively resulting in a loss of camber and overload of the outside edge of the front tires that are already carrying most of the static weight.
The condition could be solved by increasing roll resistance through springs and/or roll bar(be carefull the right combination is primordial).
Another cause of understeer is also common on poorly/overly drop evo that messes up the supension geometry to the point that the roll couple is too big and the car rolls over the front wheels at lower loads than it should.
The fix for that is raising the roll center to correct hight(RC correction kit if class permitted)
Having wider front track(up to a point) and a wider contact patch(wider tires) will also help the condition in the sense that it raises the limit(load and speed) where the understeer starts.
Offline
Apr 1, 2008, 06:57 PM
Your entry speed might be too high.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
