Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Brakes and Suspension
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Dec 19, 2007, 07:35 AM   #1
Personal Sales Rating: (2)
lan_evo_mr9's Avatar
Drives: 88590715
coilover valving
If you have a set of coilovers that came with a relatively soft spring (8kg front and 6kg rear) would you need to worry about revalving them if you wanted to put on a set of harder springs? What damage would be done to the shock if harder spring rates would be put on without revalving?
__________________
E85 duel tephra V7 map/ J O T switch/ Fast Freddie UEGO harness adapter/ GM 3 port and some other stuff
Attempting SD in a couple of weeks
Quote:
Originally Posted by leethaxor
My motors always were more tolerant to detonation when I ran with blown headgaskets. They were always faster.
Offline
Old Dec 19, 2007, 09:07 AM   #2
Bishop Motors's Avatar
Drives: 2004 Evo RS
It really depends on the brand coilover you have. Most companies allow for a +or-2k spring change right out of the box. If you need more spring rate you will have to revalve. The higher spring rate will be too much for the stock valving and the car will bounce over bumps instead of absorbing them. Eventually you will blow out the shock. I suggest contacting the manufacturer of the coilovers and see if they can revalve them for the sring rates you want to run. I speak from 10 years autocross experience. I have had this problem early on in my autocrossing days and it is not fun or fast around a track when your shocks can't handle the spring rates.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
