Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Brakes and Suspension
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 12, 2007, 10:04 PM   #1
Personal Sales Rating: (0)
xtremezae's Avatar
Drives: 2005 Lancer RalliArt (CS9A) 4G63
Send a message via MSN to xtremezae Send a message via Yahoo to xtremezae
Compression and Rebound Valving
All suspension Gurus,
Question on Compression and Rebound Valving numbers.
What does the number represent?
Example shocks that have;
3.0 rebound, 3.0 compression valving
or
4.0 rebound, 2.0 compression valving
or others
What valving suitable for street/road use? track use? and combination of road and track?
Thanks,
Offline
Old Oct 12, 2007, 11:16 PM   #2
Send a message via AIM to Noob4life
Please tell me you aren't referring to the numbers you see in driving games like Forza and Gran Turismo.....
Offline
Old Oct 12, 2007, 11:23 PM   #3
xtremezae's Avatar
Quote:
These are Bilstein numbers ....
BTW, I dont play games ....
Offline
Old Oct 13, 2007, 11:05 AM   #4
Just checking. If they only list adjustments in whole numbers, and your adjuster "clicked" each time you turned it, you can assume those numbers refer to the "click" adjustment, but the manual would need to tell you where to begin counting your turns from (clockwise or counterclockwise for example). But since it looks like they give you a fraction then it's possible it just refers to number of turns of the adjuster 3.0 turns, 4.0 turns, 1.5 turns, etc. If your shocks have clicks it'd be easy to figure out which it is.
I wouldn't say they are forces in compression and rebound because those forces are usually represented as force/displacement or force/velocity.
Offline
Old Oct 15, 2007, 05:36 AM   #5
xtremezae's Avatar
Thanks noob4life....
Forgot to mentioned, these are non-adjustable Bilstein with fixed valving. Did some searching and found some info.
You are correct, The numbers represent damping forces measured in Newtons at velocity of 0.52 meter/sec. the number is in 1/10th.
The higher the numbers, the higher "firmer" damping forces. Now, the question is what kind of damping forces is good for street/road, track and road&track.
Wondering if any of the EVO members would have some experience or recommended setup for front/rear. My first guess is to having higer rebound than compression. But at which levels/numbers ?
Offline
Old Oct 15, 2007, 07:20 AM   #6
Personal Sales Rating: (2)
gunzo's Avatar
Drives: Lancer Evolution SST
Send a message via ICQ to gunzo
It will probably have to depend on your spring rates too.. but a good starting guide is to make the rebound 50-75% higher than the compression..
It also makes for a very comfortable ride too
Offline
Old Nov 19, 2007, 09:09 AM   #7
xtremezae's Avatar
BTW, do you know what is the rebound/compression specification for 8MR/9MR Bilsteins ?
Thanks,
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
