Sep 19, 2007, 01:01 PM
Personal Sales Rating: ( 0)
Drives: Evo IX MR
Tein EDFC vs Tanabe TEAS
Tein's EDFC feature where you get to choose the damper of the shocks from the driver's seat is really a good feature. When I was riding in my friend's STI with the Tein Coils w/ EDFC, he was testing out thefeature for me but the response for the damper seemed a little too laggy.
I was thinking of getting the EDFC but I've been hearing good feedbacks about Tanabe TEAS. Far as responsive wise, I heard that the TEAS reacted much faster and the damper was lot more noticeable than the EDFC.
Anyone actually have the TEAS on the Evo's?
Offline
Sep 19, 2007, 10:45 PM
I don't see how the response from the damper seems laggy.... a motor is turning the adjustment mechanism on the shock. those adjustments are effective as soon as the next piston travel inside the shock, where exactly does the lag come in? Unless the adjustments aren't actually effective..........
Also, not for nothing, but I'm not sure I want a computer kicking my damping down to a progressive, soft damping level when I'm diving into a corner at 80mph on the track.
Offline
Sep 21, 2007, 08:45 AM
Personal Sales Rating: ( 6)
Drives: 05 EVO 8 MR
I don't think the EDFC is meant to be "real-time" like the TEAS. It just allows for in car adjustment at the push of a button, but it doesn't react by itself to changing conditions while you are driving like the TEAS. It's an interesting idea, but it totally depends on how good the valving on the shocks is. Many shocks are not consistent in their adjustability, meaning if you change from setting A to setting B and back to A, it will not behave like it did to start with, because there is too much slop in the mechanical adjuster of the valving.
I've used the EDFC with Flex dampers on my old car, and it was a nice toy to play with on a track day (and grocery saver when going over speed bumps), but the settings weren't consistent enough that I would have trusted the computer to do it for me automatically. No personal experience with the TEAS though. If I were to buy another set of coilovers, I'd spend the extra money for the electronics on better shocks instead, ultimately you get more out of it that way.
__________________
Dream of space? Help make it real.
Offline
Oct 3, 2007, 03:30 PM
Drives: Evo IX MR
When it's a real time, that means that it's more active right?
Offline
Oct 3, 2007, 04:28 PM
Drives: 05 EVO 8 MR
"real-time" means it changes the shock settings automatically based on some monitored parameter. For example you can monitor vehicle speed, and it will automatically make the shocks softer for high speed straights, and then harder again as soon as you slow down for a turn. (Just an example, I don't know what parameters the TEAS actually looks at).
Not real-time means you (the driver) need to push a button to change the shock setting.
__________________
Offline
Oct 3, 2007, 09:31 PM
AFAIK it's based off the VSS.
Offline
Oct 4, 2007, 10:52 AM
Drives: Evo IX MR
Quote:
Yeah its based off of the VSS (Vehicle Speed Sensor), their website has alot of info actually, duh http://www.tanabe-usa.com/coilovers/TEAS.asp But still wondering if anyone has run they system or has a first hand review on the product.
Offline
Oct 4, 2007, 10:56 AM
Personal Sales Rating: ( 21)
Drives: Nothing
We use somewhat the same motors in the lighting we build.. they are somewhat fast but doesn't move lighting speed... I would rather have the slow speed to see how it reacts when you are changing the setting...
Offline
Oct 17, 2007, 08:54 PM
Drives: v8 fc rx7
EDFC just uses stepped servo motors on each corner. I'd guess from full hard to full soft is ~5-6 seconds.
Offline
Oct 18, 2007, 08:29 AM
Can you change the stiffness setting while the car is moving or doe the car have to be at a stop?
Offline
Oct 18, 2007, 10:10 AM
Drives: v8 fc rx7
Rolling works fine (and is pretty helpful for fine tuning things on the track). The internals must not be a pure orifice realign or it would seem like you could lock your shock out between positions. This definitely doesn't happen.
Offline
Oct 18, 2007, 10:47 PM
Quote:
What exactly does this mean? Can you explain it in laymen terms?
Offline
Oct 18, 2007, 10:51 PM
Drives: 05 evo 8
I think he means that the internals arent super "tight" together if that makes sense so they are not as accurate but allow for on the fly adjustment.
thats why high end companies like DMS, Moton and Penske do not offer such systems.
__________________
Quote:
Oversteer is when the driver is having fun and the passanger thinks they are going to die. Understeer is when the passanger is having fun
and the driver thinks they are going to die.
Offline
Nov 10, 2007, 05:35 PM
Personal Sales Rating: ( 3)
The EDFC uses stepper motors on top of the shock adjustment knob. It is indeed adjustable in real-time as you move, it is not active however. Similar system are available from Cusco and now GReddy (saw it at SEMA).
Offline
Tags
controller, edfc, evo, evolution, flex, instructions, review, rx7, sale, settings, stiffness, tanabe, teas, tein, vs  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
