Sep 16, 2007, 07:33 AM
Personal Sales Rating: ( 0)
Drives: evo 8
whats the max neg camber on a evo for street?
hey guys, how much neg camber do you recomend to street evos before uneven tyre wear starts to happen?
long time reader first time poster good to see such a big community.
Thanks guys
Offline
Sep 16, 2007, 08:25 AM
Personal Sales Rating: ( 1)
Drives: 03' Evo 8, 84' bmw 528e
it depends how you drive.... if you are very hard on tires by turning a lot then more camber (-2 to -3) will SAVE you tires. If you do mostly highway and are easy on your car then you want less then that..
so to conclude, what works for one person will not work for another and thus there is no single correct answer.
put another way... if you're one of these people getting over 10,000 miles from your stock advans then you don't want much camber... if you tires were dead at 6-8K then you want -2 or maybe even more.
__________________
previous evo owner...
currently BMW 328ic sport
Offline
Sep 17, 2007, 07:43 PM
Personal Sales Rating: ( 3)
Drives: GG Evo9 SE
^absolutely right. I think -3 might be on the extreme side, but I run -2.5 front -1 rear. Tire wear up front sucks because I have to do so many highway miles. The wear I experience is only on the inner tread block. I mean only. It's all worth it in the corners though. 8k miles for the advans. If you can get a tire company to do rotations off the rim, you can extend that.
__________________
ROBISPEC
Offline
Sep 18, 2007, 05:12 PM
Drives: evo 8
thanks guys thats what i needed to know, don't you wish there were such things as in cabin adjustable wheel alignment systems?
Offline
Sep 18, 2007, 05:53 PM
Thanks guys
How much camber is necessary depends on two things:
1. The type of tire you are running. Some tires prefer more, some work better with less.
2. What the car will be used for. Negative camber generally will improve grip during cornering. A STREET car won't/shouldn't be taking corners in such a way that it will see the benefit of increased negative camber. A street car CAN and WILL benefit from as much contact patch as possible in a straight line, eg. no camber at all, for braking and acceleration purposes.
Secondly, camber is not what wears the tires. This is so basic, I'm not sure why this topic is in the advanced section. Toe is what wears the tires, not camber. Get your car aligned and set toe at each corner to zero, and your tires will wear normally.
Offline
Sep 18, 2007, 07:45 PM
Drives: GG Evo9 SE
The innermost tread blocks on my front tires wear a whole lot faster than the ones on the rear. I have zero toe all around. -2.5f/-1.2r. The outer treadblocks wear much slower.
__________________
ROBISPEC
Offline
Sep 18, 2007, 08:17 PM
Silver Sponsor
Personal Sales Rating: ( 20)
Drives: 2004 STi
Noob4life is right.....toe kills tires, not camber. Camber decides more where on the tire the wear occurs. But excessive toe is gonna eat them up.
Of course, a ton of camber will wear the insides faster, so the key is to find the sweet spot for your set-up and driving style. Sometimes more camber will help the tire wear more evenly.
How much camber is also dependent on how stiff your suspension is, in addition to what he listed.
- Andrew
Offline
Sep 20, 2007, 12:41 AM
Gotta disagree here. Too much camber definitely kills the inside of the front tires. Toe just does it faster.
I've been running lots of camber on my street cars for years, and have found that anything over 2.0 deg. of negative camber will start to wear that inside tread block noticeably faster. I run 2.5 on my street cars that get tracked occasionally.
__________________
David Bongiovanni
GoodsportRacing.com
NASA 25hr/PTE/TTE '08 Lancer
NASA 25hr/PTA/TTA Evo
Offline
Sep 20, 2007, 09:55 AM
Silver Sponsor
Drives: 2004 STi
Right, past a certain point, too much camber will definitely accelerate wear on the inside of the tire. Still, too little camber will accelerate wear on the outside of the tire, so you have to find the creamy middle.
- Andrew
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
