Jun 20, 2007, 01:43 PM
Personal Sales Rating: ( 9)
Drives: 94170015 -> 96530706
Motion Ratio
I'm looking for the motion ratio on an VIII, although I'm sure it would be the same for a IX. I was going to measure it but, thought someone else must have done this before.
Offline
Jun 25, 2007, 07:22 PM
Personal Sales Rating: ( 0)
Quote:
I'll go dig them up, I have them all handwritten on paper because for some reason I never got around to saving them on the computer in a database, I really should do that someday. What's it for?
edit: The fronts will 1:1, for all intents and purposes. The springs don't sit at nearly enough of an angle to affect anything.
Offline
Jun 26, 2007, 09:48 AM
I'm trying to determine correct spring rates and suspension frequency. Thanks for the info. Do you know what the rears are?
Offline
Jun 26, 2007, 08:27 PM
Rears came out to .64. Spring angles came out to 3* up front and 13* out back for your angle correction factor.
By "correct", what do you mean? Do you have desired frequencies in mind for the front and rear?
Offline
Jun 27, 2007, 09:05 AM
Much appreciated.
Offline
Tags
calculate, evo, evo8dad, evolution, ix, measuring, motion, prepared, rartio, ratio, rear, suspension, viii  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
