View Poll Results: POLL: Front and Rear Spring Rate Ratio
Lighter in front than rear
44 |
58.67% |
Same front and back
5 |
6.67% |
Stronger in front than rear
26 |
34.67% |
Jun 2, 2006, 07:01 PM
Personal Sales Rating: ( 17)
Drives: 03 EVO
OK Guys what do you prefer for your spring rate ratios front to back for Autox?
A. Lighter in front
B. Same front and back
C. Stiffer in front
Vishnu/Chronohunter likes softer in front by about 100lbs.
Most damper companies use higher in front.
Give your reasons to support your choice!
Offline
Jun 4, 2006, 04:35 PM
Personal Sales Rating: ( 0)
What are the motion ratios front and rear?
Offline
Jun 5, 2006, 06:32 AM
Drives: 03 EVO
Quote:
Please give us your insight...
Offline
Jun 5, 2006, 05:07 PM
Its pointless discussing spring rates until you know the motion ratio. I don't hence the question, but I'd expect the rear multilink has a much lower MR than the front struts.
Offline
Jun 5, 2006, 10:10 PM
Personal Sales Rating: ( 48)
2003 Mitsubishi Lancer Evolution
Drives: 03 EVO VIII White
Define Motion Ratio for us. What does it descibe exactly? Displacement at the contact patch vs. shock stroke?
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Jun 6, 2006, 02:16 AM
Personal Sales Rating: ( 2)
Drives: '05 EVO VIII, '02 Dakota R/T 5.9L, '06 GSX-R 750, '04 Ninja 636, '05 Husqvarna SMR450 & SMR510 Supermotos, Sikk MX 150cc Minimoto
Quote:
Quote:
The motion ratio is the leverage factor of the suspension arm that the spring is pushing against.
Further explanation and formula are in the third section here called:
Finding Wheel Rates
Offline
Jun 6, 2006, 07:07 AM
Drives: 03 EVO
The conversation about wheel rate is all well and good BUT to my knowledge none of the manufacturers provide this data. The purpose of this poll was to establish the general philosophy of the spring rate ratio front to back.
Not that we cannot go into wheel rate but let us not get distracted from the intent of the original question--i.e. in your opinion does the car handle better with higher rates in the front, same or higher rates in the rear.
Besides if the suspension arms used to calculate the motion ratio are the same (factory suspension) the are a constant and can be temporarily ignored so that we can find out a trend for front to back spring rate preferances.
If you want to do something usefull someone should measure the suspension arms so we can take the spring rates and do the calculation.
Offline
Jun 6, 2006, 02:45 PM
Personal Sales Rating: ( 1)
Drives: 2005 RS, 2002 S2000, 2003 Mazda Protege5, 1998 Honda VFR800
Quote:
Good point - although a car with greater track in front will have different rates than a standard car with the same track f/r.
That being said I tried a ratio of 1.25 f/r and found that it understeered a bit too much - especially through T6 at Sears Pt and T2 at Laguna. I upped the rear and ended up with 1.142 f/r and found that slightly better. 3mm spacers in front also helped. Now I've decided to drop the front down so I'll end up with 504/500 f/r. I debated for weeks whether to go with bigger spacers in the front but decided I wanted a slightly softer ride for the street, hence my decision to drop the front.
Very important to give the rears at least 1.5 laps of warmup with this setup.
Offline
Jun 13, 2006, 09:21 AM
Drives: 03 EVO
bump
Offline
Jun 16, 2006, 03:41 PM
Since our cars are mac struts up front, the motion ratio is more or less 1:1.
We measured the rears back when we first designed our Evo coilovers, but I haven't got the data in front of me atm.
Currently a rear-biased spring rate setup is working well for us, but the actual rates of the springs is just as important as the ratio.
Offline
Jun 16, 2006, 04:05 PM
Drives: 03 EVO
If you can please post your rates.
Offline
Jun 16, 2006, 04:21 PM
The setup in particular I'm talking about uses 10kg/mm springs up front, and 14kg/mm in the rear, which we dubbed the Select R2's.
Offline
Jun 16, 2006, 05:39 PM
Drives: 2003 blue EVO
A. Lighter in front
C. Stiffer in front
I just upgraded my Ohlins to use the latest vishnu spec valving.
FWIW, the vishnu spec valving and spring rates maintain a similar spring rate ratio that the EVO has from the factory.
quoting off the top of my head, the front spring rates are about 7/10th of the rear spring rate.
I have experimented with different ratios, but keeping close to the stock ratio has always offered the best results.
The more important question is motion ratios, and the proper ride height to keep the roll center where its supposed to be. That has a greater impact on the rider performance than how stiff your springs are.
__________________
autocross nut SFR SCCA #52 SM
Offline
Jun 19, 2006, 10:37 AM
Quote:
It turned out to be 500/500 and so far I'm much happier with the ride on the street. A couple of mildly fast corners on the road suggest better balance but I won't know for sure until July 6th (next track day).
Offline
Jun 19, 2006, 03:07 PM
Drives: 03 EVO
So are you saying that you get better rotation/understeer with equal rates vs. higher in the front?
Offline
Tags
cr, effect, evo, front, higher, husqvarna, increasing, motion, rate, ratio, rear, s2000, set, spring, versus  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
